Rattling sound taking off in 1st gear
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nguyenc777, Jul 7, 2020.
  1. Jul 7, 2020 at 6:44 PM
    nguyenc777
    nguyenc777 [OP] Active Member
    2020 Toyota Tacoma TRD Offroad
    Hello all. So I recently bought a 2020 tacoma trd off road with a manual transmission. During my test drive, I never noticed a rattle when taking off in first gear. Its not extrememly loud so you cant really hear it with the windows up. I noticed it one night driving with the windows down. Sounds like dice rolling around in a tin can. Doesnt happen all the time either but the condition usually present itself when taking off in 1st gear, no AC, with the windows down. The car only has 600 miles on it so Im not worry since warrenty should cover anything wrong. It's just odd hearing that. I stumbled upon another guy with thesame problem in an older tacoma so figure I ask here if this is common. Below is the link to his post.
    https://www.tacomaworld.com/threads/rattling-sound-when-taking-off.388744/
  2. Jul 8, 2020 at 10:52 PM
    nguyenc777
    Anyone with a manual tacoma with a similar sound?
  3. Jul 8, 2020 at 11:21 PM
    tcjacado
    tcjacado Well-Known Member
    Possibly a heat shield is loose or making contact
    Black DOG Lila likes this.
  4. Jul 8, 2020 at 11:25 PM
    C41n
    C41n KDMax Pro Authorized Tuner | Portland, OR
    Anthony
    Portland, OR
    2020 DCSB OR MT
    Happen to have a trailer hitch in?
  5. Jul 9, 2020 at 4:34 AM
    Burro09
    Burro09 Well-Known Member
    Miami, FL
    2017 Tacoma TRD Pro Cement MT
    Mine does it since new. To me it sounds like 2 cooking pans rattling together. It sounds terrible next to walls such as wating at a drive thru. I also get the same sound when coasting over bumps if the transmission is in neutral. All in all, the engine and the drivetrain sound like a bucket of bolts. Its fine.
    Jpalafox likes this.
  6. Jul 9, 2020 at 5:18 AM
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    totaled...part it out :D
    I'd check heat shields just based on your description.
  7. Jul 9, 2020 at 5:32 AM
    Winch
    Winch Well-Known Member
    2019 TRD OR MT V6
    None yet
    Do you have anything stored in the bed storage box? Also trailer hitch.
  8. Jul 9, 2020 at 7:47 AM
    Shellshock
    Iowa
    The MT makes noise. Mines done it since new and I’m currently over 100k miles with no issues.
    Trans fluid and the ADM definitely help though.
    G8R_Taco, C41n and Lucifer1 like this.
  9. Jul 9, 2020 at 8:21 AM
    JFriday1
    JFriday1 Well-Known Member
    Jesse
    Lakewood, CO
    19 Taco TRD-Sport, 16 4Runner
    Mobile Mechanic in Denver Instagram - "Jfriday123"
    I would peak under by the gas tank and look at the heat shield by it to make sure that there isnt an ear section of it making contact with the yoke of the drive shaft. Mine did that once and i had to have the whole shaft replaced under warranty.
  10. Jul 9, 2020 at 8:53 AM
    nguyenc777
    So I just installed a bike rack on my hitch but did noticed the noise before putting that on. I'm going to take a peak under the car maybe this weekend and check out the heat shield like everyone is suggesting. If that's not the case, I may take off the bike rack for a week and see if I can still hear it. Based some members on this forum, it also appears to be a comment sound. If it doesnt go away, I will wait until 10k mile service and ask the dealership to look into it.
    I love the truck but it drives pretty different from all the other manual transmission cars and trucks I previously own. Even my 1996 mazda B3000 almost feel and drive better than this. The biggest thing that bugs me is shifting into first while the truck is still in motion. Almost sounds like I'm grinding gears and going over two metal bumps. I guess it just takes some getting used to. Still loving the purchase though.
  11. Jul 9, 2020 at 9:07 AM
    Lucifer1
    Lucifer1 Well-Known Member
    Lucifer
    Plano TX
    2023 Silver TRD Sport Access cab V6 automatic
    Toyota Bed divider
    In March of this year I did the ADM and added a quick shifter, Very happy with the results. Would certainly do both again.
  12. Jul 9, 2020 at 9:12 AM
    nguyenc777
    Lucifer1, I've been seeing more and more ADM recommendation. I'm going to drive this truck for a bit more before doing that just so I can get a better feel of the differences. As for the short shifter, did you do the URD? I've installed short shifters in all my cars but never in any of my trucks. I'm guessing that you are pretty happy with it and it's not giving you any trouble.
  13. Jul 9, 2020 at 9:14 AM
    Metal Toy
    Metal Toy Well-Known Member
    2021 2.7L AC 4x4
    As other have suggested, I would look into the ADM. I had the clutch pedal/master cylinder TSB completed then did the ADM and it was like driving a new truck. I can shift in to first before coming to a stop now and the shifts are so much smoother.
  14. Jul 9, 2020 at 9:18 AM
    Metal Toy
    2021 2.7L AC 4x4
    I changed out my transmission oil with Amsoil at 7k which also helped smooth it out a bit.
  15. Jul 9, 2020 at 10:16 AM
    C41n
    Anthony
    Portland, OR
    2020 DCSB OR MT
    ADM and redline make a huge difference in how the truck drives. Super easy and cheap. Not sure it will help the noise but it will make it more fun to drive.
  16. Jul 9, 2020 at 11:26 AM
    nguyenc777
    I think everyone convinced me into the ADM and it's a must. I'm going to start looking into this.
    Junkhead and C41n like this.
  17. Jul 9, 2020 at 8:05 PM
    Lucifer1
    Lucifer
    Plano TX
    Toyota Bed divider
    @nguyenc777
    yes I took a chance on the URD shifter, at the time I purchased it it was $150.00 less than the other two on the market, quick and easy install, big change in feel , no regrets, would certainly do it again.
  18. Jul 12, 2020 at 7:56 PM
    nguyenc777
    Well, I took off thr bike carrier on my hitch and crawled under the truck and inspected the heat shield as suggested. Everything looks good and the rattle is still there. As another mentioned, its also on his truck. Im guessing it is common sound on this clunky transmission. Im going to see if it progressively get worst and bring it up on my first maintenance with the dealership at 10k miles.
    C41n likes this.
  19. Jul 12, 2020 at 8:26 PM
    AKGSD
    AKGSD Warranty denied
    Joe
    Alaska
    2019 QSDCSBTRDOR4X4V6MT
    Dog hair, metaltech 4x4 rocksliders, KBVooDoo bed risers, Smittybilt RTT, 3” spacer lift (Removed!), caliraised ditch lights, amazon rock lights, OVtune, Skewp
    With the truck off & windows down, Rapidly move the shifter side-to-side in neutral. If thats the noise you’re hearing, it’s normal.
    Not sure /why/ they designed it with enough slop to rattle, but here we are
    Junkhead likes this.
  20. Jul 12, 2020 at 9:42 PM
    Myles G
    Myles G Well-Known Member
    Myles
    My truck makes so many weird noises I stopped worrying
    it’s a toyota it’s probably fine, I’ve had check engine lights come on for 3 days then turn off. It’ll fix itself.
