Rattling type noise (Diesel sound)?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Terrier, Aug 21, 2009.
  1. Aug 21, 2009 at 6:15 PM
    Terrier
    Terrier [OP] Well-Known Member
    2008 SR5 Access Cab 4x4 2.7
    I have this rattling like noise at idle. It almost sounds like a diesel at idle but much milder. The noise is even more pronounced when the A/C is on.
    When I press in on the clutch, the noise goes away. The question is whther it is normal for the pressing in of the clutch to eliminate the noise. Do your manuals do the same thing? Thanks.
  2. Aug 21, 2009 at 6:22 PM
    uood8
    uood8 If You Search...You Shall Find.
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    mine does it, guess its normal...sounds like its falling apart though
  3. Aug 21, 2009 at 6:49 PM
    InfidelTaco
    InfidelTaco No better friend,No worse enemy...
    G
    PNW
    Prerunner
    AFE, Fox, Built Rights, Moog, SpiderTrax, Icon progressive, Grabbers
    i have the same noise as well. got use to it so i barely notice its there.
  4. Aug 21, 2009 at 7:37 PM
    Terrier
    Thanks for your responses. For clarification, does the noise go away when you press in on the clutch?
  5. Aug 21, 2009 at 7:55 PM
    uood8
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    never paid attention...i'll listen tomorrow if i remember.
  6. Aug 21, 2009 at 9:42 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2008 F-350 Powerstroke
    sounds like a throwout bearing? haha.... I sure hope not.
  7. Aug 21, 2009 at 11:27 PM
    jiles111
    jiles111 Well-Known Member
    Abilene, TX
    09 RegCab 4x4 Super White
    It makes the sound in neutral with the AC on.
    If you push in the clutch it goes away until you let it go
    If you turn off the AC the sound disappears completely.
    I know, the AC and clutch has nothing to do with each other, but this is what happens. Its getting quieter now. I don't notice as much as I use to.
    Mine does this also.
  8. Aug 21, 2009 at 11:55 PM
    Carson
    Carson Well-Known Member
    Carson
    Modesto, California
    05 TRD Sport 4x4 SR5 V6
    Garage Fabbed +2 LT, FOA 2.5 RR w/ Comp Adj, 35 XMTs on Level 8s, 50T Spring Under w/ 13" Shackles, Elite Front Bumper, AP Rear, Retrofitted, Wicked Flow, Custom Roof Rack, Custom Sliders, Custom Scratches, 12" JL and an Audiopipe amp.
    Maybe our tacomas are secretly gasoline powered diesels somehow, :O jk
    I have it to, so don't worry, at least i think i do, i will listen for it.
  9. Aug 22, 2009 at 6:12 AM
    Terrier
    Initially, I thought mine only did it with A/C on; however, upon closer inspection, I noticed it did it with A/C off as well, just less pronounced.
  10. Aug 22, 2009 at 7:39 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    If it goes away when you press the clutch in, it's most likely the throwout bearing. The A/C shouldn't really have any effect on anything other than it's causing additional load on the engine.
  11. Aug 22, 2009 at 7:49 AM
    uood8
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    possible, but doubtful....my truck as done it since brand new and only has 3k miles on it now. if all these trucks are coming out of the factory with bad throwout bearings we have a big problem.
  12. Aug 22, 2009 at 7:52 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    I'm pretty sure there is a known throwout bearing issue, but I'm not sure if it's for the 4bangers or the v6's. There's be quiet a few threads on it... It's been on new trucks as well...
    It's not really that massive of a deal, my G35's throwout bearing was going out for the 25k I owned it...
  13. Aug 22, 2009 at 9:34 AM
    Terrier
    Followup: Went to the dealer this morning; alot cooler than yesterday afternoon. I could not get the sound to duplicate in the presence of the Tech (it figures). He said to bring it back in later when it is warmer to see if we can hear it. I will keep you posted.
  14. Aug 22, 2009 at 9:37 AM
    ttylerr
    ttylerr Well-Known Member
    Tyler
    Fort McMurray, Alberta
    09 MGM 4Banger 4x4
    5% tint all around, Alpine IVA-W505, 16x8 Mojave Teflon Rims w/Hercules Terra Trac 265/75, Grillcraft Grill, Slimcubby HIDs, Front 5100's @ 0 w/Eibach 1.6" springs, URD Short Shifter, Extang Trifecta Tonneau Cover, Uniden Pro510XL and K30Mag Mount, Relentless Fab Bumper soon to come
    mine makes the same noise at idle a/c on
  15. Aug 22, 2009 at 9:49 AM
    InfidelTaco
    G
    PNW
    Prerunner
    It does go away when u step on the clutch.
  16. Aug 22, 2009 at 10:12 AM
    06dak
    06dak Well-Known Member
    Central Ohio
    05 PreRunner SR5 4cyl
    Undercover hard tonneau, Husky front liners
    Mine has the same noise... I've only had the truck for 6 months or so but I noticed it once I started using the AC. Seems to only make the noise at idle - when I rev it, it goes away, then when it settles to low idle it comes back.
    I tried taking it in too - they couldn't duplicate it either!
    Just for a noob sake - what does a throwout bearing do?!?
  17. Aug 22, 2009 at 10:27 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
  18. Aug 22, 2009 at 8:28 PM
    Terrier
    Update: Went to tech this afternoon. although not as obvious as yesterday, the noise was there and he says he heard it, with and without A/C on. He said he did not know what it was ( might be throw out bearing)and that he wanted to take it apart to try to see if there is anything wrong. He was concerned that he did not hear it in the morning but did then in the afternoon (I could not hear any difference when I stepped on the clutch). He did get under the vehicle this time.
    I told him that I was not ready for him to take it apart just to check it out. He said he would set it up as a test case and call Toyota on Monday to see if they had any information. He told me to call back late Monday or on Tuesday. He also said that he has never taken a 5 speed apart but has the 6 speed a few times (something about some aluminum part in the area of the throw out bearing on the 6 pseed). In fact, he said that he has never seen any problems with the 5 speed.
    I will follow up report once I hear anything. However, I have trouble accepting that there is a problem if so many are doing the same thing (as described in the responses to this topic).
    Again, I am not at all concerned over the diesel like rattling. It is the fact that the noise stops when the clutch in pushed in and starts again when out that has me concerned. I forgot to mention that I only have about 13,000 mile on the truck and I baby it.
  19. Aug 23, 2009 at 8:08 PM
    Terrier
    ttyler, 06dak and uood8, does the sound go away when you depress the clutch and come back when the pedal in the up position?
  20. Aug 24, 2009 at 3:38 PM
    uood8
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    Yes it goes away when the clutch is depressed, and comes back when i let it out.
