Rattling/Vibrating rear window
Discussion in '3rd Gen. Tacomas (2016-2023)' started by KileBillyV, Nov 2, 2022.
  1. Nov 2, 2022 at 9:39 PM
    KileBillyV
    KileBillyV [OP] Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro
    Just finished sound deadening my front doors and the whole back wall, and now all I can hear is the rear power sliding window rattling super loud. The bottom left of it seems loose and the rattling half stops when I put pressure on the bottom left. Is there a screw that could be loose or could I fix it by pushing some foam in the bottom?
  2. Nov 3, 2022 at 4:45 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Are sure put back panel on correctly? If it didn't rattle before you had it apart, and now does. I would look into that.
  3. Nov 3, 2022 at 5:41 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Sometimes the passenger seat belt clip will rattle against the plastic pillar in my truck if not secure. I've got a power sliding back window in my access cab but its very quiet.
  4. Nov 3, 2022 at 9:39 AM
    KileBillyV
    I still haven’t put the back together, the back sliding window is definitely the issue and it did it before i even touched the back
