rattling
Discussion in '1st Gen. Tacomas (1995-2004)' started by YotaDude01, May 24, 2010.
  1. May 24, 2010 at 10:50 AM
    YotaDude01
    YotaDude01 [OP] Kentucky Boy
    KY
    01' TRD off-road
    i have been noticing when i accel hard in my 01 tacoma 3.4L i hear a rattling sound on the drivers side of the motor. It kinda sounds like a heat shield or something but im not sure. Does anyone else hear that on theres or does anyone have any insight as to what it could be. thanks
  2. May 24, 2010 at 12:01 PM
    Barnone
    Barnone Guest
    Someone here isolated a similar rattle to the heat shield on the catalytic converter.
    You might take a look underneath your truck.
  3. May 24, 2010 at 12:59 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    could be heat shield even though thats on the passenger side but they can come loose.
  4. May 24, 2010 at 1:09 PM
    subtleshift
    subtleshift Noob
    Dallas
    Irvine, Ca
    01 Tacoma TRD
    K&N high flow filter, 2x Yakima bike mounts
    mine has a squeel/rattle but it sounds like its coming from the rear, everyone I know that knows anything about trucks has said the same thing,
    probably exhaust!
  5. May 24, 2010 at 5:19 PM
    YotaDude01
    KY
    01' TRD off-road
    ok thanks guys
  6. May 25, 2010 at 6:23 AM
    Space Wrangler
    Space Wrangler Well-Known Member
    JCT
    Ga
    04 DC 4x4
    04 Tacoma 4x4 Double Cab SAW 2.0's Alcan's Ion 171 wheels 15x8 (-27mm bs) 32" BFG AT's
    i had the same issue with my current truck ...turned out to be a bad cat.
    if it's not the heat shield, try tapping the cat with the back of a screwdriver and listen for the rattle.
  7. May 25, 2010 at 6:37 AM
    YotaDude01
    KY
    01' TRD off-road
    ok ill have to check all that out. thanks guys.
  8. May 13, 2011 at 7:21 PM
    cdavi060
    cdavi060 Well-Known Member
    Virginia Beach, VA
    2016 TRD Sport 4X4 DCSB
    Full OME Lift (887), 275/70/17 BFG KO2
    Did you ever figure out what this was? I have the exact issue...
