Rav4, Highlander or 4Runner?
Discussion in 'General Automotive' started by Hilborn, Jan 5, 2012.
  1. Jan 5, 2012 at 10:48 PM
    Hilborn
    Hilborn [OP] Adventure First. Safety Second.
    Michael
    Utah
    2009 Tacoma DCLB TRD Sport 4x4
    ADD W1 Oil Catch Can. AFE Magnum FORCE Stage-2 Si Cold Air Intake System. Anderson Engineering Solutions Manifold Spacer. ARK Splash Guards. AVS Door Sill Protectors. BAMF Bolt-On Rock Sliders. BAMF CMC Plates. BedRug. Brute Force HC Rear Bumper. C4 Engine Skid. C4 Transmission Skid. C4 Transfer Case Skid. C4 Fuel Tank Skid. C4 Rear Diff Skid. Cooper Discoverer ST Maxx LT285/70R-17. Dirt King Ball Joint Upper Control Arms. Dirt King Lower Control Arms. Dirt King Spindle Gussets. Dobinsons D59-318 Coil Springs.* Doug Thorley Y-Pipe. DRT Fabrication Shackle Hanger Kit.* Eaton Detroit Trutrac Rear Differential. ECGS Bushing. Expedition Essentials Bedside ARB Air Compressor Mount. Garmin Overlander. Genesis Gen 3 Dual Battery System w/ G Screen. HCF Delete. Husky Floor Liners. Hypertech In-Line Speedometer Calibrator (@1.038). IGGY Switch Panel. Ironman4x4 Foam Cell Pro Shocks and Struts.* KPOffroad Alignment Cam Upgrade Kit.* Leer 100XQ. Magnaflow Overland Series Cat-Back Exhaust w/ 10416 Muffler . Method Vex Titanium 17x8.5. Yukon 4.56 Gears. Odyssey Performance Group 34 Batteries (2). OME Carrier Bearing Spacers. OME CS047R Dakar Leaf Springs w/ D29XL. Overland Torque Tune. Pakrax Tailgate Panel. Pinch Weld Mod. Pop n' Lock. Power Stop Z36 Truck and Tow Brake Pads. rcbs204 Illumited 4x4 Switch. Rear Differential Breather Relocation. Rexing V1 Dash Cam. Scanguage 2 w/ TFT. Stahlbus Oil Drain Plug. Stoptech Cryo-Treated Rotors. Sway Bar Delete. Total Chaos Bed Stiffeners. Toyota 70mm Throttle Body. ToyTec Axle Degree Shims. URD 170° Thermostat.* URD 65 to 70mm Throttle Body Adapter. URD Exhaust Cam Gears. USA Spec IPod Interface. Voltage Booster Pro. Wheeler's Brake Lines. Wheeler's Front SuperBumps with 3/8" Spacers. Wheeler's U-Bolt Flip Kit w/ SuperBumps.
    Looking at buying a daily driver in the near future. I like my Tacoma so much I want to stay with Toyota. Looking at getting a small to medium sized SUV. My top 3 choices are the Rav4, Highlander and the 4Runner. My requirements are V6, AWD/4x4, and Auto. Not looking to do any offroading but I would like to be able to jump a curb here and there. What's your opinions?
  2. Jan 6, 2012 at 6:07 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    They're all decent, depends on your budget and how much room you need. If you're getting the V6, you'll probably have more luck finding one in the Highlander or the 4Runner. The Rav4 is small and does pretty well with the 4 banger. The 4Runner is just as big as the Tacoma so unless you need something that big, I'd stick with the smaller ones.
  3. Jan 6, 2012 at 6:20 AM
    Hilborn
    Michael
    Utah
    I believe that the Rav4 with the 269hp V6 is currently Toyota's fastest vechile. My opinions were Rav4 Limited, Highlander SE and either SR5 or Sport for the 4Runner(09).
  4. Jan 6, 2012 at 6:29 AM
    Pugga
    Massachusetts
    What's your criteria for a daily driver if you're keeping the Tacoma? You won't gain any MPG's with any of those (maybe the Rav4) and the 4Runner is just as big as the Tacoma. Most people who have a Tacoma, their daily driver is either smaller or more fuel efficient but it sounds like yours will be more of a second vehicle :notsure: Any of those vehicles will jump a curb, it just comes down to size. They're all nice for what they are but they're 3 different classes of SUV, how big of a vehicle do you want? Kind of an apples and oranges comparison in my opinion vs. comparing say a 4Runner to an Explorer or a Pathfinder.
  5. Jan 6, 2012 at 6:33 AM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    If I was getting one of those as a DD it would be a 4cyl Rav4 sport. Although my overall Toyota pick would be a 4cyl Camry SE.
  6. Jan 6, 2012 at 6:35 AM
    ontarioyota
    ontarioyota Well-Known Member
    @scott777taco INSTAGRAM
    SW Ontario, Canada
    2001 Reg Cab 4x4
    Blacked out badges-rims OME lift with 881's & dakar pacs, summer tires=BFG 31x10.5x15 on 93 4runner rims,winter= 265 75 16 DURATRACS on stock steelies,Flowmaster exhaust, deck plate mod, ARB front bumper
    The rav with a 6cyl is a rocket but your mpg will suffer over the capable 4cyl!
  7. Jan 6, 2012 at 6:40 AM
    oldtacomaguy
    oldtacomaguy four forty four
    Dave
    SE Conn.
    08 SR-5 4WD Impulse Red Pearl
    Alpine deck and amp, Polk speakers front and rear, Kenwood subwoofer, windows tinted to 20%, Sockmonkey decals, TSB, Eibach springs and Bilstein 5100's
    When my wifes 02 4Runner needs replacing, we are going with a 4 cyl. Rav 4. We have had them as rentals on vacation quite a few times and they seem to be real nice and economical. I've never driven one in snow, but it looks like you don't need to deal that in Texas. They are pretty pricey new, that's the drawback. We will probably look for a used one.
  8. Jan 6, 2012 at 6:46 AM
    cevaes
    cevaes TOYOTA
    Cesar
    Tampa
    14 PreRunner SR5 DC V6
    the piece behind the steering wheel ;)
    HIGHLANDER!!!! i had one and i loved it!!, it was the sport and it was pretty fast, confortable and good looking ;)
  9. Jan 6, 2012 at 6:49 AM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    4cyl RAV4 ... that's what I've got in mind when my wife is ready to replace her Escape.
  10. Jan 6, 2012 at 6:51 AM
    tegdog
    tegdog Taco Lover
    Indiana
    09 Tacoma Dbl TRD Sport
    ventvisors,seatcovers, bug shield,TRD CAI,TRD CAT BACK,blacked out emblems,bed extender, TSB leaf pack,Pro Dry filter, Grill craft upper, lower, & triangles, Hella 500 Black magics
    We have owned a 07 4 runner & traded it on a 11 highlander, the 4 runner rode like a taco but the highlander drives more like a camry. Never driven a RAV4 but I know I miss my 4-runner when on a bumpy gravel road but I am glad I have the highlander on long trips its so comfortable to drive.
  11. Jan 6, 2012 at 10:57 AM
    Hilborn
    Michael
    Utah
    It's funny you should say that the Highlander drives like a Camry, It shares the frame of the Camry. Rav4 the Corolla (I believe).
  12. Jan 6, 2012 at 11:01 AM
    himmie
    himmie No.
    Sarah
    AZ-WI
    08 TRD Off Road 4x4
    Yes.
    Highlander=Avalon, Venza=Camry. As far as I know. I like the Highlander SE, personally. But the RAV4 is not bad either. I prefer it with the sport effects, or whatever, package... No spare on the rear. The 4Runner seems a bit large for a daily, especially if you already have a Tacoma for off-roading.
  13. Jan 6, 2012 at 11:04 AM
    MyYota05
    MyYota05 Well-Known Member
    Muskogee, Oklahoma
    2005 Toyota Prerunner w/ TRD Offroad Pkg.
    3'' Lift Kit, Bed Rug Liner, Black Rims
    I have test drove a Rav4 before and though it looked nice, it rode rough compared to the other Toyota SUV's due to the short wheel base, I would go with the 4Runner or the Highlander, just my opinion though good luck with your decision.
  14. Jan 6, 2012 at 11:12 AM
    Hilborn
    Michael
    Utah
    Gas milage improvement over the Tacoma isn't a top priority. It would be nice. But most of my driving is in the city, having a DCLB some times becomes a pain in the ass when you have to park it in parking lot made more for something like a smart car. Being able to go over a curb is my way of saying, for some reason here, our roads are always under construction and having some thing that can easily get over a curb will help you get around a 2 hour delay.
  15. Jan 6, 2012 at 11:24 AM
    Pugga
    Massachusetts
    Based on that, Highlander or the Rav4. I wouldn't count out the 4-cylinder Rav4, they're pretty peppy. My girlfriend is currently looking for an AWD Rav4 and test drove a couple. I thought they rode pretty nice and had plenty of 'get up and go'. All the ones she test drove were 4 cylinders.
  16. Jan 6, 2012 at 9:46 PM
    shampoop
    shampoop Well-Known Member
    southwest WA
    08 tacoma extracab v6 auto trd offroad 4x4
    4 runner for medium-large interior, highest towing capability, highest offroad capability
    (08+) highlander for biggest interior, comfiest ride,
    Rav4 (v6) for smallest size, fastest and best handling by far, good gas mileage.
  17. Mar 19, 2013 at 9:44 AM
    ag8889
    ag8889 New Member
    Lori
    Texas
    I know this thread is a bit older, but I'm wanting opinions/experience with 4Runner vs Highlander as a daily driver, given my "daily drive" includes at least 2 miles each-way of bumpy road (gravel, pot holes, etc ) from our house (live on a farm).
    Am shopping now to replace a totaled '10 Camry :(
    I know Highlander has a bit smoother ride, but wondering if 4Runner would be better suspension & durability on bumpy roads.
    Looking at staying in $15K- $20K range max, so probably '08/'09 at newest & under 100K miles.
    Have 4 kids (ages 7-19), so must have 3rd row.
    Looking for leather & all options I can get for the money.
    Put about 15K-20K miles a year on a vehicle, but will probably want to trade in about 3-4 years anyway.
    Need to count on a few years of hauling active kids, friends, sports gear, etc.
    Any comments? Thanks in advance!
  18. Mar 19, 2013 at 11:56 AM
    snoope
    snoope Well-Known Member
    Winter Haven Florida
    2002 Tundra Limited 4x4
    This is going to be a "FIND" decision....What you FIND that fits price and options....a loaded up highlander will give you everything BUT the "curb jumping" abilities plus better MPG's while the 4-Runners speak for themselves it is based on a Truck idea....3rd row seat options should be looked at and tried as they do differ between them..
    Good luck...
  19. Mar 19, 2013 at 12:01 PM
    hard2kill
    hard2kill Well-Known Member
    Rhinebeck NY
    06 4door trd sport white 6spd
    ...315's,2in bora wheel spacers,safari snorkel,wheel spacers,bruteforcefab rear bumper and sliders,afe filter,hi-lift jack,5100 with OME 886 & 1/2in spacer,allpro expo's,icon 10in rear shox,flip kit,ss brake lines,cobra cb,fog light mod,yellow fogs,weathertech mats,fullsize spare tire and extra sport rim,tinted windows,aeroturbine 2525 muffler dumped over axle...rear diff breather mod...removed factory spare...removed 2nd air filter...THULE roof rack and fairing....bud builts front to back,allpoo front bumper,BAMF lca skids,overland Offroad roof and bed racks,
    road in and drove all........4runner hands down is the only one i could drive everyday....i miss my 97
  20. Mar 19, 2013 at 12:09 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    If you are buying new you can score on the RAV4 since the new generation is out. There are still a fair amount available. If you want a V6 RAV4 then now is the time since it isn't offered in the new model. My wife's '08 V6 Limited is a rocket. She hates it when I drive because the throttle is touchy.
    I am looking at a used '08 Highlander Hybrid Limited right now. I am still on the fence about a couple of issues but the MPG improvement would be a nice benefit.
