Razorblade fell behind dash..
Discussion in '2nd Gen. Tacomas (2005-2015)' started by flash23, Aug 20, 2011.
  1. Aug 20, 2011 at 5:26 PM
    flash23
    flash23 [OP] Member
    Jordan
    Texarkana, Arkansas
    2008 4x4 Access Cab
    I had a sticker on the bottom left corner of my windshield from the previous owner, and I went today to see if I could remove it with a razorblade today, and I was testing to see if I could reach it, I hit my hand on the dash and the razorblade fell out of my hand. I thought it just slide in between the glass and the dash, but it looks like it actually fell behind it. My hand is too big to feel around, but I looked and I can't see it. Any suggestions on what to do? Is there anything that it can possibly tear up by being back there?
  2. Aug 20, 2011 at 5:28 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    ur trucks done, that shit probably fell into the engine and cut up your ecu wiring harness on the way down
  3. Aug 20, 2011 at 5:29 PM
    GotLift37
    GotLift37 Bangers Runner
    North East AL
    07 4Runner 4WD
    2.5" front lift (leeper coilover) 1" body 16" Dick Cepek DC1 Black/polished 295/75/16 General Grabber AT2 Tinted Taillights 5% tint OEM Acura TSX HID Retrofit White LED dash light conversion WMW roof rack
    Me personally I would leave it lol. Yea sure there are a few wires back there but do you think it will cut any wires by itself. I would worry about it hitting your feet while driving. Making its way all the way to the floorboard
  4. Aug 20, 2011 at 9:26 PM
    VanCity4x
    VanCity4x Well-Known Member
    AB
    05 Tacoma
    3link on tons
    Yep, sell that sucker for scrap and buy a new one.:pout:
    Thins theres a link here http://www.tacomaworld.com/forum/2nd-gen-tacomas/168002-oem-dash-removal.html read the thread, that shit is crazy. Razor is sitting between the dash and the windshield, it cant fall, its all sealed.
  5. Aug 20, 2011 at 9:28 PM
    Stubbs95tacoma
    Stubbs95tacoma Well-Known Member
    Blake
    Wichita
    07 SR5
    6 Inch Lift
    Big ass magnet?
  6. Aug 20, 2011 at 9:37 PM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    You could try one of these to pull it up if it's steel like most are. If you don't want to buy one you could rub a magnent onto a screw driver and magnitize it? If not I wouldn't think that there is too much to worry about. At very most you could remove the dash and get at it. My s10 had a drinking straw covering my VIN and I got a fix it ticket for it that's what I had to do 45min to get it off but if it's anything like replacing the radio it soudn't take but a third of that time.
  7. Aug 20, 2011 at 9:54 PM
    charles08tacoma
    charles08tacoma Well-Known Member
    Santa Cruz, CA
    08 Prerunner SR-5 Access Cab
    White Snug Top shell
    Don't drive barefoot.
    Tatts521 likes this.
  8. Aug 21, 2011 at 5:06 AM
    tx_shooter
    tx_shooter This place is a cesspool of bfo and spacer lifts
    Quit working your lines on the dash and start using the arm rest like the rest of us.
    As for the danger of the razor blade back there - your in more danger stuffing your hand in there to find it then it doing damage back there. Leave it alone and it will find it's way back out the bottom some day.
  9. Aug 21, 2011 at 10:26 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    I would be worried about two things, as mentioned it making its way to the floorboard and not realizing it until its to late and you have sliced your foot. Or, having the razor fall blade down, resting on wires, and with normal driving vibrations the razor slowly makes it way thru the wire's protective coating and creates a short in the system. Maybe a slight chance, but it could happen. I would try to lay on the floorboard and look up with a flashlight and see if you can spot it. The only other thing to do is take the dash apart. :(
  10. Aug 21, 2011 at 12:06 PM
    SampleFool
    SampleFool Three Percenter
    Ga
    Silver
    08 off-road
    Wear your saftey glasses when looking up!
  11. Aug 21, 2011 at 12:09 PM
    TurfTaco
    TurfTaco Is there a long john silvers on the island?
    URE
    07 Deer Collector
    285/75-16 BFG KM1's, AVS vent visors, AVS hood shield, pioneer avic F900BT, pac steering wheel control adapter, Boyo rearview camera, pac ipod interface, tinted windows, Toytec 1.5 AAL, Bistein 5100s (front set to .85) Eibach coils, Black headlights, grillcraft black billet insert, N-fab light bar, 4 Hella FF700 lights & color matched grille, Sockmonkey bedside decals. 16x8 MT sidebiters, Weathertechs, Fabtech spare carrier.
    Its proly totaled
  12. Aug 21, 2011 at 12:14 PM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    Get another blade. Wrap the end of a wire around that and leave a few inches hanging from the end. Take masking tape and wrap the blade in it, sticky side out.
    Using the wire end, gently try to maneuver the tape covered blade back down to where the other blade is. The old blade edge may stick to the tape and you can use the wire to pull the whole thing out.
    Pigpen likes this.
  13. Aug 21, 2011 at 12:17 PM
    CanisLupus
    CanisLupus Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    This. Sucks for you and you should sell it and get this:
    b_r_o likes this.
  14. Aug 22, 2011 at 3:25 PM
    flash23
    flash23 [OP] Member
    Jordan
    Texarkana, Arkansas
    2008 4x4 Access Cab
    Thanks for y'all's suggestions. I'll see if I can rig something up and get it out. If I can't, I'll wait and see if it'll fall out. I'm not a mister-fix-it type a guy, so if I take the dash apart, chances are I won't be able to get it back on.
  15. Aug 22, 2011 at 5:06 PM
    Tigahshark
    Tigahshark Senior NEWBIE
    Isaac
    On a volcano, literally!
    2011 DC TRD off road 4X4
    Tint Weathertech floor liner, weathertech window visor Roll n lock tonneau cover Rubber bed mat Smoked license plate covers
    Your screwed! just throw your truck away infact ill be a real good friend to you give it to me and ill throw it away for you he he he
  16. Aug 22, 2011 at 6:50 PM
    ST3VE
    ST3VE IG: @fishsohard
    MD --> SC
    Tint, car seat, baby wipes
    Just pretend you never took the sticker off and lost the blade...
    out of site, out of mind.
  17. Aug 22, 2011 at 6:52 PM
    jgwheeler17
    jgwheeler17 I'm a zit. Get it?
    NC
    07 Double Cab TRD Off-Road 4x4
    neglect, mostly.
    :rofl:
  18. Aug 22, 2011 at 11:33 PM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2021 TRD OFFROAD 4x4
    ^^^ Best suggestion yet.
  19. Mar 2, 2025 at 8:24 PM
    tacoooking
    tacoooking Well-Known Member
    Dana Point, CA
    2016 TRD Off-Road
    This same exact thing just happened to my 3rd gen... any update lol?
    Relaxinslax likes this.
  20. Mar 3, 2025 at 4:16 AM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    Still a Toyota lol!
