RBP Air intake
Discussion in 'Performance and Tuning' started by Nizz11, Mar 28, 2012.
  1. Mar 28, 2012 at 9:48 PM
    Nizz11
    Nizz11 [OP] New Member
    Matthew
    Colorado
    11 TRD
    Tires/rims, Lift
    I was looking at cold air intakes and came across the RBP and ir thought i would ask if anyone on here has one or have any info on them... one of the things i like about it is that it does not require oiling i live in a area were the wind blows alot.....any suggestion would be appreciated!!...Also the RBP exhaust? Thanks
  2. Mar 28, 2012 at 9:56 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    Buy a trd nuff said
  3. Mar 29, 2012 at 12:07 AM
    Manwithoutaplan
    ID
    or dont waste your money at all
  4. Mar 29, 2012 at 12:11 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    If you want a filter that doesn't require oiling get a Afe pro dry s drop in. They're proven to work better than a lot of those other "cold air" intakes on the market.
    Also, RBP charges several fuckloads of cash for their products. I mean, more than 100 bucks for a damn RBP badge? I cant imagine how much their cai would cost. Or their exhausts.
    Do your research and choose what works best for you. If you have tons o money to throw away and you just want something that looks cool, go with RBP. Otherwise, there are better ( and cheaper) alternatives out on the market
  5. Mar 29, 2012 at 4:35 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    It is pretty cool looking. If you really want it, and want something different, then go for it. Just see if someone else sells it. Might be a better price.
  6. Mar 29, 2012 at 4:45 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    OP - you already have a CAI from the factory. If anything I would just do a drop in aftermarket filter and be done.
    IMO RBP is trash and expensive trash at that.
