RBWL is pissing me off
Discussion in '1st Gen. Tacomas (1995-2004)' started by mackattack07, Feb 28, 2011.
  1. Feb 28, 2011 at 4:31 PM
    mackattack07
    mackattack07 [OP] Well-Known Member
    william
    Jacksonville NC/Graceville FL
    99 Prerunner 3.4/2000 4Runner3.4/85 Pickup22R
    OK when i turn accelerate decallerate or hit bumps my red brake warning light comes on. the fluid level is full before someone points out something obvious i have new rotors. the problem was there before and is still there i also have all new springs and hardware and the sort in the rear drums. it was doing it before that and is still doing it. im getting kinda angry almost to the point of just snatching the blub out and forgetting it. but any help diagnosing would be appreciated
  2. Feb 28, 2011 at 4:32 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    try unplugging and cleaning the sensor for the brake fluid reservoir. may not have a good connection since the brake fluid is full.
  3. Feb 28, 2011 at 4:33 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    or lubing all the linkages/cables leading from the handle to the rear end.
  4. Feb 28, 2011 at 4:35 PM
    mackattack07
    william
    what should i lube them with pb blaster
  5. Feb 28, 2011 at 4:36 PM
    mackattack07
    william
    anyone know how to drain and flush the whole brake system fluid is looking a little brown i mean its been in there for 340,000 miles
  6. Feb 28, 2011 at 4:37 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    I would use WD-40 myself but PB Blaster would work fine. Just crawl under there and trace the cable up from the rear end. You'll see some linkages that have to rotate on bolts, soak that thing with lube and see if that helps.
  7. Feb 28, 2011 at 4:45 PM
    mackattack07
    william
    ok next is cleaning the sensor and i think i could possibly need drums
  8. Feb 28, 2011 at 4:52 PM
    rhodehard09
    rhodehard09 sometimes nonsense is the only sense someone has
    tampa, fl
    09 TRD Off Road 4x4 doublecab
    3" lift, allpro u-bolt flip kit,285/75/16 km2s, hella hid lights, hid conversions for headlights and foglights, led everything, debadged, 9145 reverse light bulbs, black tail lights, black headlight mod,trail-gear rock sliders, dynomax ultra flo muffler,satoshi with custom woven stainless grill,hella 100watt floods in grill, pioneer 4100 in dash dvd player, pioneer 800watt 4 channel amp, pioneer 4way 6x9s, pioneer 4 way 6.5s, 2 rockford p3 10's,rockford power 500.1 mono amp w/bass knob, 7 pin relocated, highlift and mount in bed, diff breather mod, led bed lights, secondary air filter removed,t-rex eyelids, mefab bumper bar, muddy under carriage
    first. check fluid level. second, bleed the brake system according to the fsm. third, check the sensor connection and the sensor.fourth, replace rear brake shoes. fifth, remove the bulb from behind the dash and forget there was ever a problem. this may not be the right way to progress through the diagnosis procedure, but this is what i would do. when all else fails, you could check the FSM????
  9. Feb 28, 2011 at 5:40 PM
    mackattack07
    william
    FSM???? not to up on that lingo
  10. Feb 28, 2011 at 5:41 PM
    mackattack07
    william
    im guessing service manual
  11. Feb 28, 2011 at 6:06 PM
    rhodehard09
    tampa, fl
    fsm=factory sevice manual
  12. Feb 28, 2011 at 6:13 PM
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    ok before u start replacing parts for no reason. the only reasons the brake light comes on is one: fluid level u got that part right/. that sensor could be bad???? and it comes on with the e brake. theres a possition switch on the e brake handle (inside end. if this switch is bad or misaligned or misadjusted it could turn the light on. id start with checking out this switch...
  13. Feb 28, 2011 at 6:19 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    This ^^^
  14. Feb 28, 2011 at 6:20 PM
    bowyer2002
    bowyer2002 always tinkering
    NE Missouri
    01 Taco SR5 D-cab 4WD
    OME 882s, OME shocks all around and OME Dakar spring packs, ARB, Warn 8000, ARE shell, Custom rear bumper w/ reciever, 5-235/80R17 Cooper Discoverer ST MAXX on FJ wheels, grey wire mod, Hi-Lift, Hellas, Red-Line hood lifters, Scion radio, sliders, Safari snorkel & LED Ditch lights on CBI mounts.
    WD-40 is NOT a lubricant.
    Use something that is teflon or silicon based.
  15. Feb 28, 2011 at 7:03 PM
    pt law
    pt law Well-Known Member
    Concord, NH
    04 xtracab 4x4 TRD
  16. Feb 28, 2011 at 7:29 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    thanks, good to know.
    And OP Change that brake fluid! 340k is way too long on the original fluid.
    probably not your problem though.
  17. Feb 28, 2011 at 7:48 PM
    mackattack07
    william
    anyone know how to drain and flush the brake fluid
  18. Feb 28, 2011 at 7:53 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    basically bleed the brakes and just keep doing it until it comes out of the bleeders clear... make sure the reservoir is full so you dont pump air into the lines...
  19. Feb 28, 2011 at 7:53 PM
    mackattack07
    william
    im thinkin vaccumn pump to the bleeders till its dry then refill with clean fluid and keep on going till i get clean fluidto the pump then refill and bleed it all
  20. Feb 28, 2011 at 7:54 PM
    Yoytoda
    Roland
    completely stock
    my suggestion uses more fluid but you wont ever have air in the system.
