RC60F Transmission swap including 4th Gen Taco
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jowett, Sep 12, 2019.
  1. Dec 12, 2024 at 6:03 PM
    #261
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Whoops, I skimmed that line 3 times and didn’t even comprehend what it was saying! Yep, I should be better off with new bolts to the torque spec. Plus it saves me from having to chase down a one time use sealant that will dry up before I ever use it again.
  2. Dec 12, 2024 at 6:06 PM
    #262
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    Easy to do. Ask me how I know!!!:anonymous:
    Just for thread info, the threadlocker equivalent is Loctite Blue 242
  3. Dec 12, 2024 at 6:09 PM
    #263
    moon22
    moon22 :-|
    SW Mitten, for the moment..
    '12 TRD OR ACLB 6MT
    FJ AWD Swap & 3G Pro Suspension
    I mean, that could be interpreted as removing any corrosion inhibitors or oil, etc. from the bolts. Either way, new is the way to go; but I don't think having a torque angle spec'd necessarily means they're TTY - if they were, I can't imagine reuse would be endorsed in an official manufacturer's procedure.
    CygnusX191 and BLtheP like this.
  4. Dec 12, 2024 at 6:11 PM
    #264
    BLtheP
    Plano, TX
    Agreed that new is the way to go, although new is $65 for 8 of them, so that kinda blows. PartSouq for the win again, they had them for $4 each and they didn’t add to the shipping cost…
    I’m not sure about angles and how they relate to TTY, I do know that my Jeep’s flywheel bolts were TTY, one time use, and were a straight 105 ft lbs.
    CygnusX191 likes this.
  5. Dec 12, 2024 at 6:33 PM
    #265
    Cetacean Sensation
    Cetacean Sensation Never lost in a parking lot
    PNW
    6MT ELM Taco (slow) // N54 BMW 135 (fast)
    Torque + angle is pretty typical for TTY bolts in my experience. The angle is how you get them to yield.
  6. Dec 13, 2024 at 8:13 PM
    #266
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    Torque + Angle is just a more accurate way to achieve a target clamp load. It is used more often in torque to yield applications because you have a smaller target you’re trying to hit. Torque + Angle and Torque to Yield do not imply the other to be true.
    Toyota uses Torque + Angle for bolts that can be reused quite frequently, and very rarely uses Torque to Yield.
    Regarding the sealant, what was said is likely correct. That said, the sealant called for is really for oil sealing purposes, while what is pre-applied is more of a thread locker. Probably not a big deal, but if it was mine I’d maybe still add a bit of sealant to the bolts if they are through holes — don’t want an oil leak.
    Jeff
  7. Dec 13, 2024 at 9:22 PM
    #267
    Cetacean Sensation
    PNW
    Thanks for the clarification. I've mostly experienced TTY bolts on German cars since they love them on engine and suspension parts.
  8. Dec 14, 2024 at 11:29 AM
    #268
    BLtheP
    Plano, TX
    Didn’t think about the sealing part because I didn’t think they’d go all the way through to the crankcase. Guess maybe I will use some sealant.
    Have a recommendation for anything oil resistant?
  9. Dec 14, 2024 at 4:06 PM
    #269
    moon22
    moon22 :-|
    '12 TRD OR ACLB 6MT
    Flywheels contain an insane amount of kinetic energy; I 100% replace them whenever I am in there. Maybe not a common failure point, but cheap insurance relative to the havoc they can unleash on your vehicle (and body, depending on application).
  10. Dec 20, 2024 at 7:17 AM
    #270
    BLtheP
    Plano, TX
    Well, barring any unforeseen changes, tomorrow will be "the day," with this evening hopefully starting the job with some teardown (simple stuff: exhaust removal, shifters, undoing wiring, driveshafts, etc.)
    I've been vetting any potential snags and think I'm good to go. The only 2 real concerns I had were about the clutch release fork support (where it mounts on the RC62F), and about what the clutch line-up tool I got from Centerforce will index to.
    Fork support concern:
    The RC60F out of the 2024 uses a new design where the fulcrum is between the bearing and the slave cylinder. So the slave cylinder is mounted ahead of the fork and pushes backwards, which pushes the bearing forwards. They accomplish this by mounting the release fork support on the front transmission cover plate. Whereas on the 2016-2023 RC62F, you can see there is nothing in that location on the cover plate. See comparison below:
    RC60F:
    RC62F:
    As you can see, it's hard to tell where the support is actually mounted on the RC62F, as most photos you can find are covered by the fork still being installed. I reached out to @tonered who has been inside his bellhousing a couple times, and luckily he had a very helpful photo that shows a little more of what's going on:
    Looking closely, you can see there is a tab as part of the bellhousing that the support fastens to. It is hard to tell 100% for sure though. In addition, I found this diagram from the FSM that made it seem pretty certain that the support did mount to the bellhousing:
    Still just the tiniest bit unsure, I reached out to @Jowett and @Jeff Lange. They resolved my fears by confirming it does mount to the bellhousing. The reason for the concern was that, if the support was indeed mounted to the transmission casing, the new transmission would not have a way to accommodate that. Unlikely problem to have since these transmissions are so similar, but worth vetting out anyways. Thankfully, not a problem since the bellhousing holds the support. This means the support will just move over when I swap the bellhousings and I'll be good to go.
    Clutch alignment tool concern:
    This one is not specific to the transmission but just a general concern I had. The factory service manual recommends SST: 09301-00220, which I had trouble finding. Alternatively, I bought a Centerforce tool stating to be for the 3.5L (21 spline, no pilot bearing). I received it expecting it to index into the bore of the flywheel based on things people have said over the years. That didn't work, which sent me into a small panic:
    I made a post on FB, but that got nowhere so I took it down. People kept telling me that the tool goes into a pilot bearing, or that it is meant for the clutch splines, or that it locates to the flywheel. I know it's for the clutch splines, we don't have pilot bearings, and clearly it doesn't index to the flywheel. So what then?
    Reached out to a few folks including @tcmd and @Jowett and they confirmed the tool ends up working fine in the crankshaft bore. That is what I expected but had no way to test beforehand. With that confirmation, that resolves any concerns I have.
    The game plan now is to start the teardown tonight, if time allows. My garage looks like a tornado hit it. My Jeep sits on one side (the short side paired with a toolbox in front of it), so the truck can't just pull in there overnight, it's too long to shut the garage door. Going to pull out the Jeep, move all the stuff over to the Jeep side including organizing loose tools and such, and then pull the truck in and hopefully start teardown this evening. Hopefully it goes smoothly. I'm excited for the swap results!
  11. Dec 20, 2024 at 7:38 AM
    #271
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    :bowdown:
    :popcorn:
    :playball:
    BLtheP[QUOTED] likes this.
  12. Dec 20, 2024 at 7:44 AM
    #272
    Supr4Lo
    Supr4Lo Well-Known Member
    Surprise, AZ
    2020 DCSB Offroad MT, Supercharged, NWF Eco-Crawler, 4.88's Locked F&R on 37's
    Right?
    In for the results. I'm interested!
    CygnusX191[QUOTED] and BLtheP like this.
  13. Dec 20, 2024 at 12:42 PM
    #273
    Jowett
    Jowett [OP] Well-Known Member
    Brian
    North Adams, MA
    If I neglected to cover it, the shift lever housing (Toyota speak) needs to be swapped (If I am remembering correctly) from the RC62 into the RC60. The nub at the bottom of the Taco shifter is larger, so the part is different. Easiest to do on the shop floor.
  14. Dec 20, 2024 at 12:54 PM
    #274
    BLtheP
    Plano, TX
    I think that is the case with the Hilux RC60, but supposedly not the 2024 Tacoma version. @Jeff Lange covered it when he first announced the fitment of the new trans in our trucks. My guess is he made that determination from looking at that piece and seeing it’s the same.
    My guess is with the new shifter extension housing being different from the Hilux version, that is probably one of the differences, as well as possibly the length/throw. We’ll see when I get to mine. If I do have to swap it, I hope it’s easy to do.
  15. Dec 20, 2024 at 1:12 PM
    #275
    BLtheP
    Plano, TX
    Okay, I yanked the extension housing. Hard to compare just off of memory but definitely looks like the Tacoma version. Either way, will be very easy to swap since it comes right off after the bolt removal. That would really suck if it was internal.
    Canadian Caber and CygnusX191 like this.
  16. Dec 20, 2024 at 1:19 PM
    #276
    BLtheP
    Plano, TX
    Does this transmission get gear oil slung up into the shifter? I’ve been filling this one by dumping the oil in through the shifter hole. It always worked because there is a small hole at the bottom of the shifter pocket, but I’m not sure gear oil ends up in there naturally during self lubrication. Hard to tell. Wondering if I should quit filling up that way, although the oil always made it down into the bottom via the hole, relatively quickly too…
  17. Dec 20, 2024 at 1:57 PM
    #277
    BLtheP
    Plano, TX
    Time to party!
  18. Dec 20, 2024 at 2:03 PM
    #278
    Jowett
    Brian
    North Adams, MA
    Filling that way is fine.
    If that piece needs to be swapped, it should be quick.
    Get after it!
  19. Dec 20, 2024 at 2:21 PM
    #279
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Jealous about the wheel dollies.
  20. Dec 20, 2024 at 2:51 PM
    #280
    BLtheP
    Plano, TX
    They are pretty sweet. I’m not massive but certainly not skinny. It’s not fun to get under my truck at stock height. This makes it way way easier. I haven’t struggled at all lol, so that’s a win. I originally bought them for my jeep so that while it’s parked in the garage, I can roll it to the other side to sweep under it :D
    tonered[QUOTED] and CygnusX191 like this.
