RC60F Transmission swap including 4th Gen Taco
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jowett, Sep 12, 2019.
  1. Sep 2, 2020 at 2:46 PM
    #81
    Jowett
    Jowett [OP] Well-Known Member
    Brian
    North Adams, MA
    Everything is out but the transmission... I'll probably drop it tomorrow, then the drum roll leading up the comparison. I'll take plenty of pics, hopefully they are celebratory.
  2. Sep 2, 2020 at 2:51 PM
    #82
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    What does it mean that the RC transmissions have a separate clutch housing? Apparently this is one of the main differences to the RA trans.
    mcharfauros likes this.
  3. Sep 2, 2020 at 2:53 PM
    #83
    Jowett
    Brian
    North Adams, MA
    The RA bellhousing is built into the front case and bearing support of the transmission, so it can't be easily swapped for another. The RC has gone back to the traditional bellhousing that can be easily unbolted and swapped.
    shakerhood and mcharfauros like this.
  4. Sep 2, 2020 at 2:57 PM
    #84
    jowybyo
    Joe
    Baltimore, MD
    Ah, I see. I hadn't considered that the bellhousing wasn't removable. Thanks.
  5. Sep 2, 2020 at 3:03 PM
    #85
    Jowett
    Brian
    North Adams, MA
    Anytime.
  6. Sep 2, 2020 at 4:16 PM
    #86
    Jowett
    Brian
    North Adams, MA
    Transfer case slips on and bolts up...
  7. Sep 2, 2020 at 4:23 PM
    #87
    COTacoTime
    COTacoTime Well-Known Member
    Jack
    2016 TRD Sport BBP
    Icon stage 2 lift, Goodyear UltraTerrains, Tepui RTT
    Sub’d
  8. Sep 3, 2020 at 3:03 PM
    #88
    Jowett
    Brian
    North Adams, MA
    No go, the input shaft on the RC60F is substantially shorter....
  9. Sep 3, 2020 at 3:11 PM
    #89
    su.b.rat
    su.b.rat broken truck
    damn. this was the post i was hoping to not see here.
  10. Sep 3, 2020 at 3:11 PM
    #90
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    I would think input shaft 33311-26110 should be the right length for the RC60F with the Tacoma bellhousing. It's not very expensive either.
    Jeff
  11. Sep 3, 2020 at 3:16 PM
    #91
    Jowett
    Brian
    North Adams, MA
    Lol! I just found that... like 2 minutes ago!
  12. Sep 3, 2020 at 3:21 PM
    #92
    Jowett
    Brian
    North Adams, MA
    Now the issue lies with compatibility, many other gears and parts have different part numbers than the Hilux... will the input shaft alone be enough?
  13. Sep 3, 2020 at 3:30 PM
    #93
    ian rogers
    ian rogers Well-Known Member
    Ian
    Sf Bay Area
    69 fj40, 2019 OR manual
    Locked Sliders Roll cage H41
    if the input shaft works its basically a full transmission rebuild to swap it?
  14. Sep 3, 2020 at 3:33 PM
    #94
    Jowett
    Brian
    North Adams, MA
    Nearly a full break down...
  15. Sep 3, 2020 at 3:37 PM
    #95
    Jeff Lange
    Calgary, Canada
    I doubt more than the input shaft would be needed. Most of the part numbers are different because the Hilux RC60(F) is built in Thailand and the Hiace RC60 is built in Japan.
    Jeff
    Jowett[OP] likes this.
  16. Sep 3, 2020 at 3:40 PM
    #96
    Jowett
    Brian
    North Adams, MA
    I hope you are correct! Shaft is already ordered....
    We'll make lemonade here... after verifying fit up, we'll send some parts to WPC Treatment, maybe add an oil pump and spray bar to cool the gears.
    mcharfauros and Jeff Lange like this.
  17. Sep 5, 2020 at 1:39 PM
    #97
    Jowett
    Brian
    North Adams, MA
    Verified that the bearing retainer and bellhousing swap over w/o issue. The input shaft should be here by week's end.
  18. Sep 5, 2020 at 2:21 PM
    #98
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    This kinda shit makes me happy. Especially with people like @Jeff Lange helping on the back end with part numbers. Good job guys.
    splitbolt and su.b.rat like this.
  19. Sep 5, 2020 at 3:35 PM
    #99
    su.b.rat
    Jeff has helped me do a FJ pedal swap in my 2017 after suffering with the crap plastic assembly for 3 years. he made it so clear and in the end every little thing was right on to the detail. invaluable help.:thumbsup:
    shakerhood and Karminski like this.
  20. Sep 5, 2020 at 4:36 PM
    #100
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Its so fuckin important. People like him are invaluable.
    su.b.rat[QUOTED] and VB25 like this.
