RCA Input Cable help
Discussion in '1st Gen. Tacomas (1995-2004)' started by PaceTaco, Dec 15, 2010.
  1. Dec 15, 2010 at 9:19 AM
    PaceTaco
    PaceTaco [OP] Member
    Jackson
    Auburn, AL
    2001 PreRunner Single Cab
    Rain guards, Realistic TRC-473 w/PA speaker, Ipod cable dash mod, front window upper tint, BedArmor bedliner
    I noticed two RCA input cables hanging down below the ash tray. So I thought: "I can plug in my ipod through those". However the CD player does not switch to an AUX mode. I tried surfing through the radio channels to see if the iPod would play through those but couldn't get it to work. However, only if the ipod is playing and I shut the truck off and crank it back up, the screen shows "TEL CALL" but no music plays. I guess it thinks theres a telephone call coming in and it won't play cd's or radio. If I unplug the iPod the message goes away and CD's and radio play fine. Can anyone tell me what I'm doing wrong? Are these input cables even meant for that? I can't find anything about the radio or its maker online. It is a Samson AV flip screen Radio, CD/MP3 player. Any kind of help would be appreciated.
  2. Dec 15, 2010 at 9:48 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    I'd pull the head unit out and make sure those RCA wires are even attached and that they're attached to inputs on the stereo. If you had the exact model you could google it and find it if it's even compatable with an Ipod. How are you connecting an Ipod to RCA cables, is there some sort of interface device you're using?
  3. Dec 15, 2010 at 9:50 AM
    ExpoSpy
    ExpoSpy Well-Known Member
    Brian
    S.D.
    08 DCLB 4X4
    They could be outputs for a subwoofer.
  4. Dec 15, 2010 at 9:53 AM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    If it was just an aux input it wouldn't have to be "compatible" with the ipod since it would just be playing audio out of the headphone jack probably
    This. Just pull the HU out and see where they go and if there's any labeling.
  5. Dec 15, 2010 at 10:08 AM
    Pugga
    Massachusetts
    F-150 Mod
    That's why I asked my next question if he was using something as an interface between the Ipod and the stereo. If he doesn't have an aux setting on his stereo, you can't just plug in an Ipod and expect it to work, you'd need something like the USA Spec device.
    The other guy is right, there's a good chance those are extensions of the pre-amp outputs for a sub.
  6. Dec 15, 2010 at 10:16 AM
    JoshO
    JoshO Well-Known Member
    Josh
    Baltimore MD
    2012 Double Cab 4x4 TRD Sport (Silver)
    Pop a Lock Bolt Codeable Tailgate Lock, Tyger Tonneau Cover, Stubby Antenna, Led Interior Lights, K&N Series 63 CAI, AVS In-Channel Visors. Upcoming Cat-Back Exahust and Lift kit
    x2
  7. Dec 15, 2010 at 8:11 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Is that a piece of antler I see on your passenger side floorboard?
  8. Dec 16, 2010 at 2:00 AM
    PaceTaco
    Jackson
    Auburn, AL
    The cables have a tag that says "RCA Input". I was running only a cable that goes from those inputs to the ipod headphone jack. I think i'll pull the HU out and take a look though.
    And yes I had antlers laying on the floorboard. 16 point, but extremely non-typical.
  9. Dec 16, 2010 at 2:04 AM
    TACOMA TRD
    TACOMA TRD Well-Known Member
    Tom
    PA
    2011 MGM SPORT DC 4x4
    Alpine HU, Apline 6.5 3 way Speakers, Access Cover.
    x 3
  10. Dec 16, 2010 at 2:45 AM
    Canadian Girl
    Canadian Girl Well-Known Member
    Kim
    Ontario, Canada
    07 X Runner
    Billet 5 piece Grille, Pink X-Brace, Pink Devil Horns, Stereo with Sub-X, short shifter, URD intake, Xii street drop, Vinyl custom interior dash,......... for now ;)
    Ok
    I did the same set up on my deck in my old civic. The two RC jacks are for a sub/amp or whatever you really want to use it for (xbox, ps3, wii, dvd......).
    You can use those but u need to buy a R/C cable hook up that plugs into the bottom of the ipod. These can be expensive. You can't just use a head phone jack.
    If you want to use the headphone jack in the ipod the check to see if the deck has an aux out and that is what you plug into, forget the R/C plugs.
    Then your ipod will play through the aux setting on the deck :)
    Hopefuly this helps and I didn't confuse :)
  11. Dec 16, 2010 at 9:52 AM
    PaceTaco
    Jackson
    Auburn, AL
    Thank yall for the help but I am kind of confused. Is there a reason you can't use a headphone jack to rca cable? I would think that the signal would be the same that goes to the hu. The HU was made by Samson a while back, and I can't find a manual for any of their products except for guitars.
  12. Dec 17, 2010 at 12:06 AM
    Canadian Girl
    Kim
    Ontario, Canada
    07 X Runner
    any model number or serial numbers on the head unit?
  13. Dec 17, 2010 at 7:48 AM
    PaceTaco
    Jackson
    Auburn, AL
    No. I can't find a single serial number on the whole unit! I took it out and looked all over the damn thing. Oh well. But anyways when I took it out I saw the wiring diagram on top and apparently it only has AUX out cables. So either the wires are labeled wrong as "RCA input" or they go to something else, which is next to impossible, because theres nothing else there. But heres a few pictures of the back. I don't see any possibilities of hooking up any type of AUX setup. Thanks for the help.
  14. Dec 17, 2010 at 8:21 AM
    Pugga
    Massachusetts
    F-150 Mod
    I seem to remember there being a piece of hardware that T's into the antenna and adds an aux port. This was some time ago and they say memory is the first to go but that might be a route to look into. I know nothing about them but if they work hopefully someone else will give their thoughts.
  15. Dec 17, 2010 at 8:28 AM
    JoshO
    Josh
    Baltimore MD
    Did you install this stereo yourself? It may be RCAs that were running to an amp/sub that is no longer in the vehicle. Normally there should be a place to plug the into the back of the HU to give a subwoofer it's own non fading feed.That HU may have been swapped with another unit that used the RCAs. Sometimes people get lazy and do not pull all the wire out, when I sold my Frontier I left all of the wiring and took the Amp, Sub and HU.
  16. Dec 19, 2010 at 3:22 PM
    Canadian Girl
    Kim
    Ontario, Canada
    07 X Runner
    Sorry but I agree. That head unit doesn't look right to have aux ports. There should be more connections in the back of the unit. Maybe time to upgrade?
  17. Dec 19, 2010 at 3:34 PM
    joes06tacoma
    Joe
    Central Coast, CA
    x2
    Plenty of good deals on new head units. Even the cheap ones have front panel aux input now.
    I have one of the antenna adapters that gives an aux input. Cost me 35 bucks I think, not really worth it. It works fine, but too much money when you can get a new deck for 100 bucks. Only reason I went that route is it was for a company vehicle that I'm not allowed to modify. I can hide the adapter, can't hide a new deck.
  18. Dec 19, 2010 at 8:23 PM
    PaceTaco
    Jackson
    Auburn, AL
    Where did you get the antenna adapter? I don't really need a new HU, as cheap as they are. Im trying to save all the money I can for some Cooper Discoverer STT tires.
