rcbs204 4x4 Illuminated Switch!
Discussion in 'RCBS204' started by rcbs204, Jan 4, 2010.
  1. Apr 20, 2013 at 9:21 PM
    #1981
    byrd
    byrd Unknown
    David
    Kansas
    '06 Access SR5 4x4 6 speed
    Good to hear, if I come across anyone that is looking, I will send them your way. :thumbsup:
  2. Apr 20, 2013 at 9:29 PM
    #1982
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    What's changing in Rev 4?
  3. Apr 21, 2013 at 5:57 AM
    #1983
    rcbs204
    rcbs204 [OP] Well-Known Member Vendor
    Nothing big, just a resistor.
  4. Apr 21, 2013 at 9:32 AM
    #1984
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    What's the advantage of that
  5. Apr 21, 2013 at 9:33 AM
    #1985
    Sandman614
    Tim
    '06 SR5 Off Road
    more resistance :p
    :canada: don't smack me.
  6. Apr 21, 2013 at 10:14 AM
    #1986
    Only Danks
    Only Danks TRUKWERX : Desert Racing Products
    Bryant
    San Diego, CA
    05 Black TRD O/R 4x4
    3" MID-TRAVEL LIFT: Fox 6x2.5 Front RR C/O's, Fabtech unibal UCA, Fox 10x2 Rear RR Shocks, All-Pro Leaf Pack, Fox 2x2.5 Air Bumps all 4, Strapped all 4, TC Gussets:, Lower Arm Cam Tabs, Front C/O Bucket Tower, Spindles, OTHER: Custom Front Bumper skid, Custom Rear Tube Bumper, McNeil Racing 3" Fiberglass Fenders, McNeil Racing 4" Fiberglass TT Bedsides, 2 Matching Vertical Spares, GrillCraft black mesh, 07 LED Tails(black), Headlights (black), Viper 5204 Alarm, Remote Start, Cobra 19 CB Radio, 6 ft Red LED Firestick Whip, High-lift jack, Black Emblems, STEREO: Custom Nexus7 inDash, Rockford 3sixty.3 to SPDIF, Rockford T1 6.5 Comp Front, Rockford T1 6x9 rear, Rockford PBR300x4 Amp, Rockford P310 (x2) rear seats, Alpine 1100w amp, USB DAC via SPDIF, USB Audio ROM, FUTURE MODS: TC +2" LT Kit, 8" LT Coilover, 16 Rear Piggys, L/T CV Axle Shafts, Heim Steering, DMZ SUA kit, Bedsaver cage, Shackle Crossmember, Motor Mount Gussets, Box Frame
    Stoked to hear youl be making more LED boards.
    Question: are the LEDs the same PLCC-2 1210 / 3528 SMDs as the guage cluster?
    I was considering buying whatever color you had available and customizing it.
    But if your making more can i be the first order request!?
    I Just changed my guage cluster to red/white,
    Thanks in advance
    -OnlyDanks
  7. Apr 21, 2013 at 10:15 AM
    #1987
    rcbs204
    I increased the R7 to a 2 watt SMD pads, so it easier for me to solder, I had a few units where the current limiting resistor was soldered poorly because the pads were too small for the resistor I was using. In order for me to ship Rev3 boards, I had to slightly lift the resistor to make sure there was ample solder under the resistor so it would not fail in the field (Cold Solder Joint). So I increased the the foot print, and now it will be more manufacturable.
    Always improving!!
    Wiki:
    (Cold Solder Joint)
    The most common defect when hand-soldering results from the parts being joined not exceeding the solder's liquidus temperature, resulting in a "cold solder" joint. This is usually the result of the soldering iron being used to heat the solder directly, rather than the parts themselves. Properly done, the iron heats the parts to be connected, which in turn melt the solder, guaranteeing adequate heat in the joined parts for thorough wetting. In electronic hand soldering the flux is embedded in the solder. Therefore heating the solder first may cause the flux to evaporate before it cleans the surfaces being soldered. A cold-soldered joint may not conduct at all, or may conduct only intermittently.
  8. Apr 21, 2013 at 10:17 AM
    #1988
    rcbs204
    Yes they are PLCC-2, When I get the new rev of boards I will be happy to customize you a board. The new boards will be available in about a week.
  9. Apr 22, 2013 at 9:17 AM
    #1989
    miacevedo
    miacevedo Well-Known Member
    SoCal
    SuperWhite 4X4
    All Pro Hybrid front bumper. All Pro rock sliders. Warn Winch. Icon 2.5 Remote Resi Coilovers & Rear Icon 2.0 Extended Remote Resi's. AP Standard leafs. Rear SuperBumps. OEM bed mat and All Weather floor mats. Pelfreybilt IFS Skid. Method NV wheels on 285/75/16 Toyo Open Country AT2.
    Received my switch over the weekend. Thanks!
  10. Apr 22, 2013 at 7:14 PM
    #1990
    rcbs204
    :thumbsup:
  11. Apr 22, 2013 at 7:38 PM
    #1991
    45longcolt
    45longcolt Well-Known Member
    DFW Area
    2020 Off Road
    rcbs204, Does this mean you reload the 204 Ruger cartridge?
  12. Apr 22, 2013 at 7:39 PM
    #1992
    Sandman614
    Tim
    '06 SR5 Off Road
    :notsure:
  13. Apr 22, 2013 at 8:20 PM
    #1993
    rcbs204
    Yes I do! I have a Kimber Long Master in .204, and it is one of the finest shooting guns I own!! They no longer make that gun in .204, so it is actually a collectors item now!!
  14. Apr 22, 2013 at 8:42 PM
    #1994
    45longcolt
    DFW Area
    2020 Off Road
    Very Cool. That "rcbs" just kept gnawing at me so I had to ask. I have had my Rock Chucker for 4 decades now, I started young. :)
  15. Apr 22, 2013 at 8:46 PM
    #1995
    rcbs204
    Thats great, I have a RockChuckerII and a Dillon 1050 to reload the AR and handguns!!:D
  16. Apr 22, 2013 at 8:53 PM
    #1996
    scotch
    scotch Well-Known Member
    Mark
    Centennial, CO
    2012 Tacoma, 2015 Tacoma, 2005 4runner 4.7L
    Lots of Stuff
    How will we know when we can order the new boards? will it be posted on your website?
  17. Apr 22, 2013 at 8:56 PM
    #1997
    rcbs204
    You can order now, I have stock Amber, and can make any color combinations of blue and white. I will edit the website and set all to in stock.
  18. Apr 22, 2013 at 9:04 PM
    #1998
    rcbs204
    All Items IN-STOCK!!!
  19. Apr 25, 2013 at 10:03 PM
    #1999
    oledragoon
    oledragoon Well-Known Member
    Don
    Oklahoma City
    06 Super White Tacoma TRD Off Road 4x4
    Super White Grille, and rear bumper on Off Road, TRD Intake System, TRD Cat Back Exhaust System, Custom bed bar for Emergency light bar, Overhead Console Temp/Compass Fix,rcbs Illuminated 4x4 Switch, ImMrYo Rear-View Mirror Lift Bracket, Jumpers LED's in cab, Jotto Computer desk, Cobra 29 CB & Uniden Scanner on custom dash pad, Autometer gauges(oil press, oil temp, trans temp, Batt/amp), Front bush guard, Rear bumper guard, BamaToy1997 4x4 Custom Front Hubs, OTW Mod One Touch Windows.
    Not sure you got my pm from 4-20, but I wanted to thank you publicly for your help with my kit. Well done Sir!!
    Not sure how to give you the credit thingys, thanks again!
    dc
  20. Apr 25, 2013 at 10:09 PM
    #2000
    Foihdzas
    Foihdzas VA7PTZ
    Danny
    B.C Canada
    2010 Dbl Cab 5' Box 6 Speed
    2010 Tacoma, sold...
    Look at the bottom left corner of a persons post. Look for the icon that looks like a scrunched up piece of paper, that's how you add rep:D
