rcbs204 4x4 Illuminated Switch!
Discussion in 'RCBS204' started by rcbs204, Jan 4, 2010.
  1. Nov 25, 2013 at 1:40 PM
    #2121
    rcbs204
    rcbs204 [OP] Well-Known Member Vendor
    Its the fact that you cannot shine light through solid plastic. The 4x4 writing is silk screened over plastic, in the 05-11's it is opaque plastic so the light can shine through.
  2. Nov 25, 2013 at 1:43 PM
    #2122
    wuzzy121
    wuzzy121 Well-Known Member
    Colorado Springs
    05 AC 3" lift
    ARB front bumper w/ Warn M8000 winch and lights, 3" lift, Tire gate tire carrier, All-Pro Expedition leaf springs, weather tech floor mats.
    Are the switches and housings the same or did they change them on the new ones?
  3. Nov 25, 2013 at 2:52 PM
    #2123
    anders99
    anders99 The Sailing Member
    Matthew
    Penscola, FL
    (07 Base 4cyl 4x4 - RIP) -> 2018 4Runner SR5 Premuim
    Taco SOS Offroad Concepts hybrid front bumper Iggy Corp. Switch panel Famous Fab ditch lights and cb antenna mount Pioneer Appradio 2 Halo Led Headlights Led Taillights 3'' toytech spacer lift on front end Toytec AAL on rear AFE cold air intake 4Runner Stock
    Got mine in the mail today. Haven't had a chance to look at it but packing was top notch.
  4. Nov 25, 2013 at 5:26 PM
    #2124
    "OldManTan"
    "OldManTan" Bye bloody Taco... Hello MGM Burrito!
    Buffalo, NY
    '16 Tundra DC
    Holy chit, I've done a lot already!!
    I'm pretty sure RCBS has tried to figure it out. The switch is solid in 2012 and later. Maybe a retrofit to a 2011 or older switch??
  5. Nov 25, 2013 at 5:35 PM
    #2125
    wuzzy121
    Colorado Springs
    05 AC 3" lift
    [QUOTE="OldManTan";7763913]I'm pretty sure RCBS has tried to figure it out. The switch is solid in 2012 and later. Maybe a retrofit to a 2011 or older switch??[/QUOTE]
    That's what I was thinking. Does the older switch and housing that is clear then silk screened fit the new ones? If so it might be better to go that route if they are still available.
  6. Nov 25, 2013 at 5:43 PM
    #2126
    rcbs204
    I personally have not seen a 2012+ switch in person,but I have had two people/ Beta testers try and install my light in there switches, and they were not successful. If it was a simple PCB change, it would have been done 2 years ago. There is one guy on here who used a 4runner switch, but it was around $100 or so to make it happen. That is not worth it to most people. Oldmantan is correct, if I could figure a path to light the switches, it would be done!
  7. Nov 25, 2013 at 7:15 PM
    #2127
    rcbs204
    Very nice, almost looks like it was suppose to be that way.
  8. Nov 26, 2013 at 6:13 AM
    #2128
    justchil
    justchil Well-Known Member
    Andy
    WV
    13 AC TRD OR
    Understood. Maybe a different route like glow in the dark writing/sticker similar to what they use on gun night sights... I don't think that stuff is cheap either lol. Dang you 05-11 guys :D
  9. Nov 26, 2013 at 8:29 AM
    #2129
    anders99
    Matthew
    Penscola, FL
    I got mine mostly installed today. Not wired yet though. It is raining cats and dogs in florida right now so instead of going to class I sat in the parking lot and got it in using just my leatherman. Still trying to decide wether to sider or just hook it up. I will post pics when completely done
    EDIT: Got it all wired up and it works great. When darkness comes pictures will also come.
  10. Nov 26, 2013 at 8:36 AM
    #2130
    CanadaToy
    CanadaToy Well-Known Member
    Greg
    Toronto
    17 DCSB TRD OR Alpine
    TRD Pro grille & skid, OEM tonneau and roof racks
  11. Nov 27, 2013 at 12:28 PM
    #2131
    rcbs204
    Shipped. :thumbsup:
  12. Nov 27, 2013 at 2:59 PM
    #2132
    whahahajr
    whahahajr Lone Star Club
    jimbob
    New Braunfels, Tx
    07 Tacoma TRD
    Camburg Uniball UCA, ARB Front Bumper, TAG rear bumper, OME rear shocks, All Pro 3" leaf springs
    Did mine ship? Ordered one on the 25th.
  13. Nov 27, 2013 at 3:43 PM
    #2133
    rcbs204
    Sure did, I ran out of boxes, so I shipped nine units today. For those that are waiting, they all went out the door this morning.
    Thanks,
    Shannon
  14. Nov 29, 2013 at 8:16 AM
    #2134
    rcbs204
    Hope everybody had enough to eat yesterday, I sure know I did, time to get out side and work some off.
  15. Nov 30, 2013 at 7:41 AM
    #2135
    Poolstick
    Poolstick Well-Known Member
    Ordered last night! One question - when you're splicing it into the factor harness behind the AC controls, do you use one of those quick splice things (I can never get them to work), or strip and solder?
    I've also ordered a Fly Eye Design light, so it's going to be getting a little busy down there. Any other locations you could recommend splicing it into?
  16. Nov 30, 2013 at 8:46 AM
    #2136
    rcbs204
    I strip and solder most al my connections for reliability. I have have never really sourced another location for hooking up the light. If still had had my truck, I would run out to the garage and figure a new location. Sorry I could not be of more help.
    Regards,
    S
  17. Nov 30, 2013 at 12:39 PM
    #2137
    Tmill
    Tmill Well-Known Member
    Tyler
    Florida Panhandle
    07 Sport Black DCLB
    Strip and solder is the best option but for those that don't have the tools crimp connector will work as well. I am a big fan do the j-hook connection. You could cut the wire to your AC panel and do a two v two j-hook weigh both the switch and you fly eyez. Make sure to slide your heat shrink over two of the wires before you solder or your stuck wrapping it with tape. Just my opinion, if you want a permanent install.
  18. Nov 30, 2013 at 1:12 PM
    #2138
    floodedkiwi
    floodedkiwi Well-Known Member
    Ken
    Naw'lins, Louisiana
    2019 GMC AT4
    Dog.
    I tried this in my 2013 Baja and it will not work. After completely pulling the switch apart the final issue was the outside bezel on the switch is made of black plastic, with the sliver screen printed over it, so even if I installed the lights they would never shine through. Toyota really cheaped out on the 2013 Taco on so many levels.
    I have just ordered an FJ lighted switch to see if that will work, it looks like the same switch dimensionally and will try to install between Christmas and New Year.
    Anyway props to the LED install, really good quality and well put together, just a shame it wont work in the 2013
    :cheers:
  19. Nov 30, 2013 at 3:06 PM
    #2139
    rcbs204
  20. Nov 30, 2013 at 9:22 PM
    #2140
    anders99
    Matthew
    Penscola, FL
    Finally took pictures when it was dark. Here it is installed @ 100% brightness
