rcbs204 4x4 Illuminated Switch!
Discussion in 'RCBS204' started by rcbs204, Jan 4, 2010.
  1. Feb 24, 2015 at 9:35 PM
    #2581
    06RadiantTacoma
    06RadiantTacoma Well-Known Member
    just sent payment for an amber! ive regretted not getting this back in the day so i wont let this opportunity pass me again
  2. Feb 26, 2015 at 7:44 AM
    #2582
    sseifrig
    sseifrig New Member
    2013 Toyota Tacoma Limited
    Will this work on a 2013 tacoma? The add says 05/11
    Only
  3. Feb 26, 2015 at 7:45 AM
    #2583
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    It says 05/11 only because it only works on 05/11
  4. Feb 26, 2015 at 7:57 AM
    #2584
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    I'll just say it again..
    2005 - 2011 only, does not fit 2012 - 2016 and beyond
  5. Feb 26, 2015 at 10:30 AM
    #2585
    bridaw
    bridaw The light was yellow, Sir.
    Brian
    SoCal, East San Diego County
    10 DC 6-speed TRD OR 4x4 tow debadged
    tailgate hose clamp/washer mod ,disable seatbelt warning ,dealer tinted windows ,running boards ,DiamondBack SE bed cover ,OEM rubber bed mat ,TRD Japan shift knob ,bed rail corner reinforcement with angle brackets+square nuts ,Armor Tech Offroad mount for 60" highlift jack ,Scangauge II ,OEM roof rack ,BajaRack basket ,WeatherTech dark tint window deflectors ,removed mud flaps ,debadged ,stubby antenna ,D-rings - 4 in bed floor + 8 on the side rails ,cut four D-ring slots in bedmat ,secured ActionPacker 48 gal cargo box to bed ,center console lock ,relocated 7 pin harness ,Redline Tuning QuickLIFT Elite hood supports ,Pop & Lock PL5300 tailgate lock ,RAM A-pillar mounts for GPS and Drift HD170 camera ,RAM mounts on bajarack for Drift HD170 exterior shots ,relocated rear differential breather ,headrest iPad mount ,ImMrYo rear view mirror lift ,Panavise Indash mount ,265/75/16 BFG All-Terrain T/A KO on TKO black rims ,installed front and rear WeatherTechTacoma DigitalFit FloorLiners ,replaced interior/external lights with Jumpers LEDs +switchback mod +under hood light ,installed rcbs204 Illuminated 4x4 Switch ,installed left and right Relentless Off-road Fabrication hood hinge light mounts ,installed KB Voodoo's Powder Coated Tailgate Cap System ,installed front and rear Wet Okole seat covers ,made and installed mount for Trail Toys NSA Switch Panel ,did ND4's Fog Light Anytime Mod
    Installed mine yesterday after my posi-taps were delivered. It is so wonderful having the switch illuminated. I should have got one years ago when I first saw this thread. Thanks for making this latest batch!
    Thanks for the tip about posi-taps! :thumbsup: I could not find them anywhere locally so I purchased a kit from Amazon with several sizes. Hopefully they lower the price some day but they are still worth using in places where the wires will be subjected to bumps and vibrations and/or places not easily accessible. I know I won't have to worry about the posi-taps behind my climate control failing. I have a few of the old style clamp wire taps under my hood and every so often a couple of them need to be jiggled a bit to restore contact. I'll probably end up replacing those with posi-taps now.
  6. Feb 26, 2015 at 2:58 PM
    #2586
    Toy4me
    Toy4me Well-Known Member
    Tom
    NNJ
    '10 DCLB TRD Sport MGM
    Mine came today:thumbsup:. Now it the weather would just warm up a little to motivate to go outside and install it.
  7. Feb 26, 2015 at 4:29 PM
    #2587
    "OldManTan"
    "OldManTan" Bye bloody Taco... Hello MGM Burrito!
    Buffalo, NY
    '16 Tundra DC
    Holy chit, I've done a lot already!!
    Don't be a wuss. :D Start the truck, and install it. Not like you have to wire anything from outside the cab.
  8. Feb 26, 2015 at 7:57 PM
    #2588
    Li0nel1234
    Li0nel1234 Well-Known Member
    Lionel
    Denver
    14 TRD OR DCSB SSM
    Will this work for a 2014 Tacoma?
  9. Feb 26, 2015 at 8:00 PM
    #2589
    OZ-T
    Peter North
    British Columbia
    Yes if you trade it in for an 05-11
  10. Feb 26, 2015 at 8:03 PM
    #2590
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Ha!
  11. Feb 26, 2015 at 8:12 PM
    #2591
    rcbs204
    rcbs204 [OP] Well-Known Member Vendor
    Could not have said it better myself!!
  12. Feb 26, 2015 at 8:26 PM
    #2592
    MARSHBUSTER
    MARSHBUSTER Well-Known Member
    Jim
    Alamogordo NM
    2005 SR5 4X4 Tacoma TRD
    Grill Gaurd/ Winch Bumper, Mile Marker 9000 LBS Winch, Custom Head Ache Rack, Custom Rear Bumper, Marathon Camo Max 4 Seat Covers
    Ok What Do I Need To Do To Order An Amber Switch For My 2005???
  13. Feb 26, 2015 at 8:32 PM
    #2593
    Wpg07TRD
    Wpg07TRD Canadian Member
    Neal
    Winnipeg
    '07 TRD Sport, DCLB
    5100s and 885x coils, Trail Gear Add-A-Leafs/5125s, interior light LED swap, rcbs204 illuminated 4x4 switch
    PayPal OP with order details. See page 1......
  14. Feb 26, 2015 at 8:33 PM
    #2594
    MARSHBUSTER
    Jim
    Alamogordo NM
    Ok Thanks Brother^^^^^^^^^^
  15. Feb 27, 2015 at 1:57 PM
    #2595
    RustyBlue
    RustyBlue Meh...
    Bryan
    Dayton, Ohio
    06 A-Cab TRD Off-Road 4x4
    just installed mine. did the solder method. whole project took just under an hour. results are amazing! highly recommend picking this up before they're all gone.
  16. Feb 27, 2015 at 4:24 PM
    #2596
    Toy4me
    Tom
    NNJ
    [QUOTE="OldManTan";9929121]Don't be a wuss. :D Start the truck, and install it. Not like you have to wire anything from outside the cab.[/QUOTE]
    Ok ok, it was up to 20* so it's done. I did the solder method and everything went smoothly. The only thing I'm unhappy with is the connections of the light wires to the factor grn, grn/w. Like the op, I stripped a small section out and soldered, then electrical taped. A posi-tap would be a much better choice here as when you solder, the coating on the factory wire melts back quite a bit, and it's difficult to get a good tape wrap up in there. Ultimately, I'd like to unclip the factory wire from the plug so shrink wrap tubing could be slid in place, shrunk and then reinserted in the plug. I tried, but couldn't get the pin unclipped from its' plug. Maybe I'll revisit this when it get warmer out as I have cup holder LEDs to install. Otherwise very happy with it. Thanks again OP, great product and clear, easy to follow instructions. :thumbsup:.
  17. Feb 27, 2015 at 6:02 PM
    #2597
    "OldManTan"
    Buffalo, NY
    '16 Tundra DC
    :rofl::rofl::rofl::rofl::rofl:
  18. Feb 28, 2015 at 3:22 PM
    #2598
    Pete0247
    Pete0247 Well-Known Member
    Kentucky
    2007 BSP DCSB TRD Off Road
    5000K headlights, 3000K fogs, fog mod, 2014 LED tail lights with LED reverse lights, interior LED dome/map, and license plate lights, Pioneer radio, WeatherTech window visors, 20% tint, bed door locks, Mobil 1 synthetic fluids throughout
    Received mine yesterday, installed today, was super easy, I'll post a pic a little later when it gets darker.
    Edit: sorry for the crappy phone pic, but there it is, thanks for the great product :D
    Now I'll have to get my gauge cluster and AC controls to match...
  19. Feb 28, 2015 at 7:35 PM
    #2599
    dakotasyota
    dakotasyota Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    Just installed. Looks awesome! Thank you so much, sir! My OCD is cured :)
  20. Feb 28, 2015 at 7:48 PM
    #2600
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    Pics or didn't happen. :p
