rcbs204 4x4 Illuminated Switch!
Discussion in 'RCBS204' started by rcbs204, Jan 4, 2010.
  1. Mar 2, 2010 at 4:16 PM
    #401
    emerson
    emerson Well-Known Member
    seattle
    offroad
    Is the diagram for soldering correct? No need to switch around? Going to get someone to solder it on tomorrow.
  2. Mar 2, 2010 at 8:18 PM
    #402
    rcbs204
    rcbs204 [OP] Well-Known Member Vendor
    The procedure is 100% correct if followed. If you wire directly then the polarity will change.
  3. Mar 3, 2010 at 3:49 AM
    #403
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    I'll be putting mine in this weekend! :woot:
  4. Mar 3, 2010 at 4:09 AM
    #404
    IrishPilot
    IrishPilot Well-Known Member
    MN
    09 TRD Off-Road 4x4 Double Cab
    So for those of us still considering TTaps, what size-color etc. is correct for the job?
  5. Mar 3, 2010 at 6:45 AM
    #405
    64Wildcat
    64Wildcat Black Jeep of the family
    Denis
    New Hampshire
    2015 Rubicon
    This is what i used they are made for 18 - 22 awg,got them from Radio Shack for $1.99
    Went on pretty easy.
    Quick Splice Connector with Male Disconnector (3-Pack)
    Model: 64878006D,MDFNY1-250 | Catalog #: 64-037
    Denis
  6. Mar 3, 2010 at 7:21 AM
    #406
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    The red ones are close to stock color I believe, as he's mentioned before.
  7. Mar 3, 2010 at 7:33 AM
    #407
    rcbs204
    I found that the Amber/orange ones cannot produce enough light in the T1 LED package so all the stock colors are red, and it is very hard to tell the difference.
    Cheers
    B
  8. Mar 3, 2010 at 7:58 AM
    #408
    NetMonkey
    NetMonkey Well-Known Member
    Geogetown, TX
    2010, 4x4, DC, off-road, shortbed, automatic
    Toytec Ultimate Lift @ 3", Mickey Thompson MTZ's 285/75/16, Moto Metal 955b, rear 2" ALL, Marlin Crawler sliders
    i can tell the difference between the stock dash lights and the red LED's on the 4x4 switch. it does look a little different, but i dont care. it still looks great and the whole color scheme goes together anyway. if anything, the red on the 4x4 switch stands out a bit more :)
  9. Mar 3, 2010 at 8:05 AM
    #409
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    I know ya'll keep saying switch the polarity. Can I get it spelled out, lol. Going off of rcbs204's original instructions: White to Green and Red to Green/White. So reverse is White to green/white and Red to Green. I am asking for incase the instructions have been updated or I am just that screwed up! Sorry lol.
  10. Mar 3, 2010 at 8:06 AM
    #410
    NetMonkey
    Geogetown, TX
    correct.
    i did not do the solder method and i hooked it up as follows:
    red->green
    white->green w/white stripe
  11. Mar 3, 2010 at 9:07 AM
    #411
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    Thanks for that clarification. I read through it all a few times and just ended up confusing myself. lol.
  12. Mar 3, 2010 at 9:13 AM
    #412
    automoto
    automoto Well-Known Member
    jersey shore
    07 SR5 4X4 AC
    i did it the same way, and this combo was the only way that worked. i tried reversing it and it didn't work.
  13. Mar 3, 2010 at 9:51 AM
    #413
    WATacoRider
    WATacoRider Well-Known Member
    TRD Sport 4x4
    Just installed mine. Thanks rcbs204.
    Only complaint I have about mine is, the "4" on my "H4" isnt lit up as well as the rest of the numbers and letters. I can easily fix this, but it looks good enough to me.
  14. Mar 3, 2010 at 1:36 PM
    #414
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Just got home from work. It's here ! Thanks rcbs204 !:D
  15. Mar 3, 2010 at 2:44 PM
    #415
    uood8
    uood8 If You Search...You Shall Find.
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    Its nowhere close...there is orange and red. In my pictures it looks close but in real life there is quite a difference. The red on the switch is the same color as the needles on your speedometer. It doesn't look out of place but don't be disappointed if you get yours thinking it'll be close to matching your hvac dials and when it arrives you realize its not.
  16. Mar 3, 2010 at 2:47 PM
    #416
    piercedtiger
    Jon
    Southern Tier, NY
    ah, ok. I read before it was close, and by the pics it does look close.
  17. Mar 3, 2010 at 2:56 PM
    #417
    Mark C.
    Mark C. If you want it bad, you usually get it bad!
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    LED Dome, Reed Switched LEDs in Glove Box and Center Console, Bumper Fogs, Tailgate anti-theft, LEDs over Cig lighter, Back-up camera anytime, Outside Temp add-on, Hidden GPS power, Sockmonkey 3rd Brakelight decal, 4X4 switch illumination, reed switch controlled engine compartment Flood LEDs, Elite Hitch Cover, Plasti-dipped cupholders and door switch control panels, Elite Hitch Cover.
    Arrived! Sheesh! Have been like the kid in the "Christmas Story" waiting for his Ovaltine Decoder Ring!!!! (Hopping up and down....from one foot to the other, waiting for the mailman to arrive!)
    Thanks rcbs204! Now to install!
  18. Mar 3, 2010 at 3:18 PM
    #418
    IrishPilot
    MN
    Be Sure To Drink Your Ovaltine.
  19. Mar 3, 2010 at 3:28 PM
    #419
    emerson
    seattle
    offroad
    I tried installing it with the molex one of the pins got stuck so i just yanked it out. I got someone to solder it, but it still wont light up.
  20. Mar 3, 2010 at 4:33 PM
    #420
    rcbs204
    Humm, Not sure what to tell ya there, I can't be responsible for yanking of any kind!! :D
