rcbs204 4x4 Illuminated Switch!
Discussion in 'RCBS204' started by rcbs204, Jan 4, 2010.
  1. Mar 4, 2010 at 3:37 PM
    #441
    emerson
    emerson Well-Known Member
    seattle
    offroad
    [quote="OldManTan";1498603]Okay where is the molex left? In the actual 4wd switch? You need that molex to supply power to the board IF it is soldered to the contacts on the switch. Or the other method is to cut the molex pins off and go right from the board to the green, green/white wires on the AC lights. Pics will help tremendously if you can get some up.[/quote]
    Damn i must be Fing retarded. Still not working.Well one of the molex got stuck into the plug, couldnt get it out so i yanked it out.(Reason? reversed the pins) Round 2 Got someone to solder it on to the factory switch like the diagram didnt work, they reverse the polarity didnt work. Im gonna wait and have a friend help with the AC light deal. thanks guys for all the help! And thank you bicemen for making this possible.
  2. Mar 4, 2010 at 4:58 PM
    #442
    07tacoswb
    07tacoswb Well-Known Member
    Alan
    North Carolina
    16 Tundra CrewMax XSP-X
    Got my light today. Installed it and man it's awesome :D. Thanks again rcbs204.
  3. Mar 4, 2010 at 5:27 PM
    #443
    "OldManTan"
    "OldManTan" Bye bloody Taco... Hello MGM Burrito!
    Buffalo, NY
    '16 Tundra DC
    Holy chit, I've done a lot already!!
    Maybe its me, but it sounds like you aren't actually supplying power to the board. You have to solder it to the factory switch, plug the molex into the factory plug AND run those wires and tap into the AC wires. Or you can pull the wires through the factory switch, cut the molex pins off and tap into the AC wires.
  4. Mar 4, 2010 at 5:42 PM
    #444
    rcbs204
    rcbs204 [OP] Well-Known Member Vendor
    Yep i think you nailed it.
    [quote="OldManTan";1502449]Maybe its me, but it sounds like you aren't actually supplying power to the board. You have to solder it to the factory switch, plug the molex into the factory plug AND run those wires and tap into the AC wires. Or you can pull the wires through the factory switch, cut the molex pins off and tap into the AC wires.[/quote]
  5. Mar 4, 2010 at 6:04 PM
    #445
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    could I just plug the molex into the AC plug and supply power directly to the board?
    No soldering for me, so is the above possible?
  6. Mar 4, 2010 at 6:44 PM
    #446
    AZBACKCOUNTRY
    AZBACKCOUNTRY Well-Known Member
    Doug
    AZ-between the hammer and the anvil
    11' AC TRD OFF-ROAD 4x4
    Pelfreybilt front aluminum bumper,AVID off road weld on sliders, RCI Offroad IFS & transmission Skid (steel), RCI LCA skids (aluminum),upper grillcraft, relentless hi clearance bumper,OEM color matched front grill color, ARE MX camper shell, wet Okole realtree seat covers,pelfreybuilt hi lift mounts,ICON 2.5 Coil-overs extended,, ICON tubular UCA's. Allpro expo leafs, SS extended brake lines.Bilstein 110 extended rear shocks.prinsu Cabrac.dwreck pod mounts OKLED 18w cubes.Baja Designs Squadron-R Sport, LED Wide Cornering, Ambers fog/driving 20" IGGY LED Single Row bar.tepui awning,rotopax 2 gallon, TREDs and mount , 100 watt renogy solar panel.victron 20 amp Bluetooth charge controller,Pro comp wheels - cooper st maxx 285/75/16 tires. Skygear bussman fuse relay smart box. ARB 12v plug hard wired for ARB fridge. Pelfreybilt gas tank skid. Smittybilt X2O 10K winch
    Great Mod- Really Enjoyed the Install- SOLDERED IT WITH THE WELLER JUNIOR - A RELIC FROM UNCLE TED'S GARAGE.
    From what I'm reading here- Take your time and it will be fine!
    I went with the White LED's and Red Arrow- Pleasing to the eyes and really illuminates the H2-H4-L4.
    It's a great combination of colors for the dial- I HIGHLY RECOMMEND IT!!
    rcbs204- Go enjoy your well deserved vacation and reap the fruits of your labor- Very nice work.:)
    Azbackcountry
  7. Mar 4, 2010 at 7:08 PM
    #447
    ESNTACO
    ESNTACO Active Member
    Will
    Md
    06 6 spd DC TRD O/R
    Locker Mod+Safety Switch, Fog Light Mod, ABS Kill Switch, Debadged, Lockable Bed Compartments, Weather Tech Floor Mats, Marathon Seat Covers (highly recommend), Limo Tint, Biceman 4x4 Light, Map Lights on w/Dome, Running Lights w/ Blinkers, Door Buzzer Mod, Cig Outlet Always Hot, Satoshi Grill, Urd Short Shifter, Diff Breather Soon
    looks good azbackcountry. for those off you that got custom colors post some pics. curious to see what they all look like
  8. Mar 4, 2010 at 7:31 PM
    #448
    "OldManTan"
    Buffalo, NY
    '16 Tundra DC
    No. But you don't have to solder anything. Take the wires, run them through the hole in the back of the switch where the stock bulb should be, the brown plug, and t-tap them into the AC lights. You have to cut the molex pins off and discard to do it this way. The molex pins are only for the soldering, "factory look" method. Be aware though that with the non-soldering method you will need to disconnect the factory plug and the PCB board wires to remove the switch.
  9. Mar 4, 2010 at 8:13 PM
    #449
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    I'm gone pick up the t-taps tomorrow morning but was just hoping that using the supplied molex pins could get me power through the AC plug. Let me get this straight for the stock look you get power from the AC plug and run it to the plug for the 4x4? Which in turn gives power to the PCB board which is soldered to the switch. Then why wouldn't plugging the pins directly to the AC switch give power to the PCB? Just curious.
    I do understand how to do it correctly just wondering about the route above mentioned. I am waiting on T-taps because none of the near by buisnesses carry them.
  10. Mar 4, 2010 at 8:32 PM
    #450
    Reepur
    Reepur Well-Known Member
    Brevard, NC
    '10 RC Black 4x4 2.7L
    265/75/16 BFG KM2 's on XD Hoss's 2.5" lift/4xBillies, OME 885's, Firestone Ride-Rites Desert Specialties UCA Volant CAI Grillcraft Grill Kobalt Slim Line Box Weathertech mats and Ventvisors. DTRL mod. 4 Lo -Trac Mod. Int. Wiper Mod. rcbs204 4x4 LEDS URD Short Shifter Plate Front bumper with Smittybilt XRC8000 winch Body Armor rear bumper with swing out tire carrier. ATO Front Skid Ultragauge BHLM
    Your confused. If you use the molex pins, they plug into the connector that is already there that plugs into the back of the 4x4 switch.
  11. Mar 4, 2010 at 8:43 PM
    #451
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    Thats the kinda shit I needed to hear. lol. Thanks. I have no clue how I had that mixed up like that must be the meds I have been taking for my surgery. I see now. No matter what you have to tap into the wires from the AC. I for some reason was thinking we were using the molex pins for the AC plug. Don't know why. Thanks for bearing with me.
  12. Mar 4, 2010 at 8:58 PM
    #452
    "OldManTan"
    Buffalo, NY
    '16 Tundra DC
    Thats just crazy!! That is a very common item up here. Napa, Radio Smack maybe even walmart has them. Crazy.
    That is what we are here for, glad you figured it out. Not you just have to hook it up. LOL
  13. Mar 4, 2010 at 9:07 PM
    #453
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    To be honest I have never seen T-taps before and really don't know if I will find them tomorrow. I have done plenty of wiring (entire chevelle from radio shack wire) just not on a new truck with all these fancy plugs, lol.
    If I can't find the T-taps i'll just splice them together and then add some spades to allow for me to seperate them later for incase I need to work on the switch. Again thanks.
  14. Mar 4, 2010 at 9:34 PM
    #454
    "OldManTan"
    Buffalo, NY
    '16 Tundra DC
    Well you don't NEED the t-taps. You can splice the wire whatever way you want. I don't want to admit it, but I used the old friction fit on mine. I just pushed the wires into the back of the AC plug. I don't recommend this way. It was one of those, "I'll fix it later". Well it has been 4 months and still haven't fixed it. Maybe in the spring. See if this shows up as being available by you http://www.radioshack.com/product/index.jsp?productId=2103500&clickid=prod_cs#
  15. Mar 5, 2010 at 4:04 AM
    #455
    64Wildcat
    64Wildcat Black Jeep of the family
    Denis
    New Hampshire
    2015 Rubicon
    Hey Lucas,
    See post #422 that's what i used the guy at Radio Shack had no clue what i was talking about and said thay had nothing like them so i looked for myself and found them.
    Denis
  16. Mar 5, 2010 at 4:46 AM
    #456
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    I'll keep my eye open for these today. From the picture I don't see where the female spade attatches to the other piece. Maybe in person I will see better. Thanks.
  17. Mar 5, 2010 at 5:17 AM
    #457
    Reepur
    Brevard, NC
    Actually, the spade that comes with it is a male spade. After you fold the T-tap over the wire and crimp it, the male spade plugs into it and helps lock it closed.
  18. Mar 5, 2010 at 7:31 AM
    #458
    JimmyZ
    JimmyZ Member
    Jim
    SouthEast MA
    07 SR5 4WD IMPULSE RED PEARL
    anytime on fogs, Dynolock electric tailgate lock, A/C off when in defrost mode, xtang soft tonneau, Bilstein TRD shocks, Sockmonkey bedside SR5 decal, OEM oval nerf bars, 2010 tail lights, DeeZee bed mat, 4WD switch illumination, Weathertech digital fit mats, HAWK LTS ferro-carbon brake pads
    Thanks rcbs204 for the great work. Installed and works great (also dims with the other dash lights). I followed the install instructions exactly (especially using the pictures provided). I did the soldering on the 4WD switch, installed the molex connectors in the 4WD switch plug but instead of soldering the red and white wires on the AC control wires I used these quick connectors. Use the RED quick connector because it is made for 18-22 gauge wire and the wires being used are 22 gauge).
    Jim
  19. Mar 5, 2010 at 7:43 AM
    #459
    emerson
    seattle
    offroad
    Yup hahahaha. Thank you for clearing that up for me! Im just gonna tap right into the AC wires then.
  20. Mar 5, 2010 at 7:48 AM
    #460
    Danosabre
    Danosabre Well-Known Member
    Dan
    Gardner,Ma
    09 TRD Off Road
    Extang Trifold bed cover,DDM 55W 6000k HID, maglight, Vent visors
    Waiting for mine..... :bored:
