rcbs204 4x4 Illuminated Switch!
Discussion in 'RCBS204' started by rcbs204, Jan 4, 2010.
  1. Oct 29, 2010 at 4:48 PM
    #861
    dvdrdclf
    dvdrdclf Well-Known Member
    Colorado
    2010 4x4 TRD Sport AC
    SNOW
    do you only have 60 of the stock color or all of the colors.... thanks
  2. Oct 29, 2010 at 4:52 PM
    #862
    rcbs204
    rcbs204 [OP] Well-Known Member Vendor
    I keep inventory in the Stock Colors because there is a higher volume.
    The other colors are built to order, so you can order what ever color you would like and i will build it and ship as soon as the order is received.
    Thanks
  3. Oct 30, 2010 at 11:20 AM
    #863
    rcbs204
    Boy i just got back from shooting my AR with the new Adams Arms piston system, what a dream. Finished cleaning the gun in like 15 minutes, no more carbon in the chamber area. Highly recommend this system if you have the means.
  4. Oct 30, 2010 at 4:12 PM
    #864
    ikillterrorists
    ikillterrorists Well-Known Member
    Andrew
    New Paltz, NY
    Sold my tacoma, got a Dodge Ram
    TRD Cold air intake Aries Grille Guard Flowmaster American Thunder Dual Exhaust Pro comp 3" suspension lift KMC XD Hoss, BFG KM2 285/75/16 Hypertech Speedometer Calibrator N-Fab Side Steps Access Roll-Up Cover TRD Quick Shifter SafeHitch
    Can you do blue numbers with blue arrow?
  5. Oct 30, 2010 at 4:28 PM
    #865
    rcbs204
    Yep, no problem, i actually think i have one built already.
  6. Oct 31, 2010 at 8:24 AM
    #866
    rcbs204
    Got tons of these built again, They will ship the day you order in most cases. :)
  7. Nov 2, 2010 at 7:17 PM
    #867
    rcbs204
    Really no buyers anymore, i guess i will have to sit down and make the youtube video of this project.
  8. Nov 2, 2010 at 9:22 PM
    #868
    "OldManTan"
    "OldManTan" Bye bloody Taco... Hello MGM Burrito!
    Buffalo, NY
    '16 Tundra DC
    Holy chit, I've done a lot already!!
    Looking at maybe buying a double cab. If I do, I am buying from you this time, instead of building my own!! LOL
  9. Nov 3, 2010 at 1:17 PM
    #869
    superwhite10
    superwhite10 Well-Known Member
    Garner, NC
    sooo....i followed the directions to a T, have double checked all the connections at least 5 times, but i think i might have screwed this up tremendously, is it possible by doing this, that if done incorrectly, NONE of the interior dash lights with auto dim when turning on the headlights? ....i cant really tell because its still light outside, but its appearing to me that NONE of my dash lights are changing (turning on) when i turn my lights on or off. :confused:
    i guess ill just wait until its dark enough to see the lights better...
  10. Nov 3, 2010 at 1:39 PM
    #870
    iSTIZO99
    iSTIZO99 Well-Known Member
    Jax, FL
    2010 TRD Sport 4x4 DC/SB
    Take a picture of your connections too!
  11. Nov 3, 2010 at 1:41 PM
    #871
    rcbs204
    I am not aware of any AUTO Dim function? Is this something new with the 2010's. Or are you just referring to the dial to turn the dash lights up and down? You would be the first that i am aware of that would have this issue. If it turns out that the lights no longer dim when turning the dial, then i would say have the wrong two wires on the harness connected, and you are pulling all the dash light to a Positive voltage and somehow bypassed the dimming switch. Need a little more information to properly diagnose the issue.
  12. Nov 3, 2010 at 1:43 PM
    #872
    iSTIZO99
    Jax, FL
    No auto dim on mine...you still turn the dial for dimming.
  13. Nov 3, 2010 at 1:44 PM
    #873
    rcbs204
    That's good, i was a little worried that Toyota changed something on me.
  14. Nov 3, 2010 at 1:58 PM
    #874
    superwhite10
    Garner, NC
    sorry i guess i should have clarified, after sitting in my truck pondering what i did wrong i realized i should have worded it better, i meant how the dash (radio, ac controls etc.) lights come on when you turn the headlights on.
    ill upload pictures of my connections, they are cell phone pics so they are a little blurry though
  15. Nov 3, 2010 at 2:00 PM
    #875
    iSTIZO99
    Jax, FL
    Your dash lights are not coming on now, but they were working fine before you started to splice into them?
  16. Nov 3, 2010 at 2:09 PM
    #876
    superwhite10
    Garner, NC
    correct, they were fully functional before i started, the only ones that apear to be lit are the ones that are lit without the headlights being on.(ie. speedo, odo, clock, and radio info screen) unless im completely forgetting, when you turn the headlights on all of those dim (or get brighter, which ever way it is to describe) while all the other lights turn on (ie. steering wheel controls, each button on the radio, ac controls)
    heres my connections
    http://www.tacomaworld.com/gallery/showphoto.php/photo/114714/cat/500/ppuser/43425
    http://www.tacomaworld.com/gallery/showphoto.php/photo/114713/cat/500/ppuser/43425
    http://www.tacomaworld.com/gallery/showphoto.php/photo/114712/cat/500/ppuser/43425
  17. Nov 3, 2010 at 2:16 PM
    #877
    PSUnick
    PSUnick Lets Go State!
    MA
    2007 AC 4x4 Sport
    Check the fuse.
  18. Nov 3, 2010 at 2:16 PM
    #878
    iSTIZO99
    Jax, FL
    I'm about to leave here in a sec, but have your power and ground connections been touching each other when you turned on the switch? Your connections seem fine. Not sure if the AC control lights are on the same circuit as the rest of the dash, but check your fuses just in case.
  19. Nov 3, 2010 at 2:38 PM
    #879
    superwhite10
    Garner, NC
    i checked the fuses that and couldnt find any blown ones, im about to head out though, i have my fingers crossed that maybe im wrong with all of this and they do work and i just cant tell due to the fact that its still light outside :pray: like i said in my above post, i followed the pdf directions to a T and double checked before each step, set it up and checked again before completeing the connections so its hard for me to understand what might have gone wrong.
  20. Nov 3, 2010 at 3:13 PM
    #880
    rcbs204
    No worries friend, I will help you with what ever you have to do. If it comes down to it, you can PM me and i will personally call you and help diagnose the issue.
    Thanks
