rcbs204 4x4 Illuminated Switch!
Discussion in 'RCBS204' started by rcbs204, Jan 4, 2010.
  1. Nov 3, 2010 at 3:41 PM
    #881
    superwhite10
    superwhite10 Well-Known Member
    Garner, NC
    thanks for all the support and help so far guys, its really just blowing my mind, as of right now the only lights that light up inside the truck are the guages, clock, radio info screen, and the overhead temp. doesnt matter if i turn the headlights on or off, these are the only lights that light up.
  2. Nov 3, 2010 at 3:52 PM
    #882
    rcbs204
    rcbs204 [OP] Well-Known Member Vendor
    Do your tail lights work?
  3. Nov 3, 2010 at 4:11 PM
    #883
    iSTIZO99
    iSTIZO99 Well-Known Member
    Jax, FL
    2010 TRD Sport 4x4 DC/SB
    Hook a voltmeter up to the green/white & green wires. You should get 12V when you flip on the headlight switch and 0 when off. But then again you did say that those lights don't turn on when you turn on your lights. Gotta troubleshoot everything...there's gotta be a logical explanation.
    How about the soldered end of the 4x4 switch, no shorts there? Kinda hard to tell from the pic.
  4. Nov 3, 2010 at 4:16 PM
    #884
    rcbs204
    Yeah this sounds like Jhodge's issue, although he ended up cutting the wires and re soldering them all together.
  5. Nov 3, 2010 at 5:31 PM
    #885
    BloodEagle
    BloodEagle Active Member
    Torrance, CA
    2011 TXPro
    Mine came in the mail today and I just hooked it up. Working great. Thanks!
  6. Nov 3, 2010 at 5:35 PM
    #886
    rcbs204
    Good Deal!
  7. Nov 3, 2010 at 7:36 PM
    #887
    superwhite10
    Garner, NC
    yes the tail lights do work, actually thats a lie, good thing i checked! :eek:and good thing i didnt get pulled over, surprised i didnt!!! so, what does that mean that the tail lights dont work? i was actually wondering if i could cut the wires and resolder everything, i having been soldering for very long, just picked it up recently so i was also wondering if maybe there was somthing i did wrong in that process. :confused: :facepalm:
  8. Nov 3, 2010 at 11:06 PM
    #888
    iSTIZO99
    Jax, FL
    Yea you may want to resolder those power supply wires and just leave out the 4x4 light for now until you first fix getting power back to your AC control module. Also verify the continuity of your 4x4 switch...make sure the red wire on power supply end is only connected to the red on the switch end and not white. Make sure it's disconnected from the power circuit though, otherwise if it's still connected and the headlight switch is in the off position, you'll get the impression that the red and white wires are shorted together.
    Can you turn the air on/off and toggle the vents? It really sounds like you blew a fuse though.
    Edit: just wanted to make sure I understood, did you say that you are new to soldering? A continuity check will tell if you've made good soldering joints or not. Do you have a multimeter to work with?
  9. Nov 3, 2010 at 11:23 PM
    #889
    superwhite10
    Garner, NC
    okay, can i just cut the red and white wires where i soldered to disconect them from the harness? i want to at least get my tail lights working, assuming a problem from the same source.
    then i would just pick a new spot on the green wires to solder the red and white to correct?
  10. Nov 4, 2010 at 3:19 AM
    #890
    iSTIZO99
    Jax, FL
    Yea you can just snip them or even just touch it with the soldering iron and pull them back off. Once you fix the other issue then you could reconnect to the same spot on the green because a wire's a wire and location doesn't matter.
    How did you strip your green wires originally...did you cut them or leave them in tact?
    Just out of curiosity...is your truck automatic and do the shifter lights turn on?
  11. Nov 4, 2010 at 6:21 AM
    #891
    superwhite10
    Garner, NC
    okay, im about to go do that! when i stripped them originally i just took a knife and made a small cut in the insulation and peeled away until i had enough room.
    i have an automatic and the shifter lights do not turn on either
  12. Nov 4, 2010 at 6:34 AM
    #892
    iSTIZO99
    Jax, FL
    Yea then I believe it could be your fuse. Replace the 10A Tail fuse anyway even if it doesn't look like it's burned out...sometimes fuses can look like they're still good, but really be bad instead.
    However, still disconnect your 4x4 light wires because you just might have a short that caused that fuse to blow.
  13. Nov 4, 2010 at 7:33 AM
    #893
    rcbs204
    Whoa whao whao, its a FUSE, i have done this exact same thing. You shorted out the two wires at some time, this blows the fuse under the steering column. If i remember right it is fuse 20. check again, it is the problem trust me.
  14. Nov 4, 2010 at 8:52 AM
    #894
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    Hey if you need a second set of eyes let me know. I live in Chantilly and work in Lorton so if you're in the area and haven't figured out the problem send me a PM. Mine went in good with no problems so if you wanted to check how I did mine for reference just let me know.
  15. Nov 4, 2010 at 5:00 PM
    #895
    superwhite10
    Garner, NC
    yep you guys were right! it was fuse number 3 i believe under the dash, a 10A fuse for taillights, instrument illumination etc. i first disconnected the 4x4 light and when nothing happened i put 2 and 2 together and remembered the question about my tail lights, looked up that fuse, replaced it, and my lights came back on. i will resolder everything tomorrow and update you guys as to what happens
    joneill03 - if i dont get it figured out tomorrow i might take you up on that offer. i live in stafford and work in prince william.
    thanks again guys, ill update tomorrow if i get it working or not.
  16. Nov 4, 2010 at 5:43 PM
    #896
    dvdrdclf
    dvdrdclf Well-Known Member
    Colorado
    2010 4x4 TRD Sport AC
    SNOW
    got mine today thanks!
  17. Nov 5, 2010 at 9:25 AM
    #897
    rcbs204
    Glad to hear it, is the snow in that pic from this year already?
  18. Nov 5, 2010 at 1:15 PM
    #898
    superwhite10
    Garner, NC
    alright! i got it all fixed and working! :D thanks for all the help guys i really appreciate it! will def tell any tacoma owners i come across in my area about this product!
  19. Nov 5, 2010 at 1:52 PM
    #899
    iSTIZO99
    Jax, FL
    Good to hear you got it fixed! :thumbsup:
  20. Nov 5, 2010 at 2:19 PM
    #900
    rcbs204
    May i ask what you found was the problem?
