rcbs204 4x4 Illuminated Switch!
Discussion in 'RCBS204' started by rcbs204, Jan 4, 2010.
  1. Jul 28, 2011 at 8:10 AM
    #1341
    rcbs204
    rcbs204 [OP] Well-Known Member Vendor
    Shipped!
  2. Jul 28, 2011 at 7:51 PM
    #1342
    rcbs204
    Still got some Blue and White LED,s for those that were waiting.
  3. Jul 29, 2011 at 4:22 PM
    #1343
    rcbs204
    Dear rcbs204,
    I installed my 4x4 switch light today and found it easier then described. There was a plug in the hole where the wires come out of the switch that had wire holes in it. I just stripped the housing from the red and white wires about 5/8" and threaded it through the plug. The plug just twists back in the hole and the wires in the plug touch the proper contacts. Easy. After splicing into the AC light wires, I had a little trouble with the Molex terminals not staying in place in the switch's factory connector. I just had to push them back in with a needle nose pliers and they now seem to be solidly in place.
    I've always wondered why this wasn't installed at the factory in the first place. Driving in the snow at night, I've reached around in the dark looking for the switch and thought it should be illuminated. Problem solved.
    Thanks
    - thebicycleguy
  4. Jul 29, 2011 at 9:30 PM
    #1344
    marksanctuary
    marksanctuary Member
    Orangevale, CA
    2011 4wd V6 Dbl Cab TRD Off Rd
    4x4 Illuminated Switch, Bed Mat, Maglite in the holder, Lots of Bungees
    I need one of those Staples buttons to push... "That was Easy" ...mine is installed!
    Thanks for a great mod!
  5. Jul 30, 2011 at 7:02 AM
    #1345
    rcbs204
    That Easy button would be nice in allot of circumstances!
  6. Aug 8, 2011 at 8:53 PM
    #1346
    Tommy
    Tommy Well-Known Member
    Tom
    Indiana
    2010 Access cab SR5 4x4
    so whats the difference between soldering the two leads or just using the harness? I'm curious as I'll prolly be getting one of these soon.
  7. Aug 8, 2011 at 9:04 PM
    #1347
    rcbs204
    One gives you an OEM look allows you to remove the switch without clipping the wires when you need to remove completely the other is fast and easier.
  8. Aug 8, 2011 at 9:33 PM
    #1348
    Tommy
    Tom
    Indiana
    So the lighting will look different if I don't solder? Or do you mean the wiring looks more OEM? I understand that it would be easier to remove the switch if it were done the soldering way, but I don't have a soldering iron and I doubt I will ever have to get in there again. Trying to decide if I should go ahead and buy an iron.
  9. Aug 9, 2011 at 7:26 AM
    #1349
    rcbs204
    Its the wiring that will be different, the lights will not change in appearance.
  10. Aug 9, 2011 at 7:43 AM
    #1350
    puckstopper55
    puckstopper55 Well-Known Member
    Long Island
    '11 Double Cab TRD Sport, Mag Grey
    tailgate anti-theft Map Light LED's Dome Light LED LP LED Halogen Bed Light Extra D-Rings in bed Anytime Fog Lights Tri-Fold tonnau cover Wet Ok's
    do you plan on doing a group buy soon?
  11. Aug 9, 2011 at 7:52 AM
    #1351
    rcbs204
    Never thought about it, did not think there was that type of interest.
    I could definitely figure something out though.
  12. Aug 9, 2011 at 8:25 AM
    #1352
    puckstopper55
    Long Island
    maybe put a feeler out there .. How many would you need to give a discount?
  13. Aug 9, 2011 at 9:13 AM
    #1353
    rcbs204
    It would take at the bare minimum of 25 people, due to the fact that i already have trimmed the cost of this item for the guys at TW. But could probably do a touch more to make it worth while. If i offer it exclusively though TW, then there is no ebay fees which i can round up and the will put the item roughly at ~ $28-$30 Shipped.
  14. Aug 9, 2011 at 9:17 AM
    #1354
    cverneau
    cverneau Well-Known Member
    Craig
    Cheshire, CT.
    11 Access Cab 4cyl 4x4 Auto
    AVS In-Channel Window Deflectors, AVS Rear Window Sun/Rain Deflector, EGR Front Hood Deflector, Weathertech Digital Fit Floor Liners With TRD Off Road Decals, TonnoPro Tri-Fold Cover, Coverking Black Neoprene Front Seat Covers & Front & Rear Center Console Covers, Black With Red Stitched TRD Head Rest Covers, Rear Grey Neoprene Wet Okole Seat Covers, Black Front Door Handle Pull Covers, Husky Custom Molded Mud Flaps, Devil Horns Of Fire On Satoshi, 7" Off Road Lights Mounted Behind Grill, Pop N Lock 5300, Seatbelt Chime Off, Interior & Exterior Led's, Cubby & Drink Holder Amber LED's, Infinity Reference #9633 6X9 Front Speakers, Solar-Gard HP Smoke 35% Tint, De-badged & Pinstripe Removal, Sun Visor Stickers Removed, Illuminated 4x4 Switch, ImMrYo Rear-View Mirror Lift Bracket, Ultragauge, TRD Aluminum Skid Plate, Bed Storage Cubby Locks Mod, Additional D-Rings In Bed, Rubber Bed Mat, Intermittent Wiper Stalk, Black Vinyl Arm Rest Mod, Secondary Air Filter Removal Mod, Spare Tire Rod Alignment Tube Mod, 14" Antenna Mod, Tailgate Theft Mod, DTRL Wire Jumper Mod, Parking Lights As Turn Signals Mod, Under Hood LED Strip Lighting Mod, 30 Watt Reverse Bulbs, PIAA 510's With LED's In Fog Locations, Cree LED Flood lights In Rear Bumper, Burner Bedlights In Bed Cubby's, Avid Light Bar, Horn Relocation Mod, Rear TSB Springs, Bilstein 5100's on all four corners - front set at 0.85", Cooper Discoverer ATP - 265-75R/16, Pioneer AVH-X3700BHS Head Unit With Microbypass, Added USB Charging Ports Under Dash.
    I'm in!! :thumbsup:
  15. Aug 9, 2011 at 11:39 AM
    #1355
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    If it's closer to the 25 side It could push me over the edge.
  16. Aug 9, 2011 at 11:47 AM
    #1356
    puckstopper55
    Long Island
    He got the GB going. Check it out and sign up!!
  17. Aug 9, 2011 at 11:51 AM
    #1357
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Just read through the last posts, thanks for pushing him into the GB Puckstopper!
  18. Aug 9, 2011 at 11:52 AM
    #1358
    Sandman614
    Tim
    '06 SR5 Off Road
    Where? I don't see it in the group buys section.
  19. Aug 9, 2011 at 12:11 PM
    #1359
    rcbs204
    It's under lighting.
  20. Aug 9, 2011 at 2:20 PM
    #1360
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Why not post the link so people can just click it. I just went to the group buy heading at the top of the page and didn't see it.
