rcbs204 4x4 Illuminated Switch!
Discussion in 'RCBS204' started by rcbs204, Jan 4, 2010.
  1. Aug 9, 2011 at 6:17 PM
    #1361
    rcbs204
    rcbs204 [OP] Well-Known Member Vendor
  2. Aug 9, 2011 at 7:20 PM
    #1362
    "OldManTan"
    "OldManTan" Bye bloody Taco... Hello MGM Burrito!
    Buffalo, NY
    '16 Tundra DC
    Holy chit, I've done a lot already!!
    Trust me guys and gals, it is an awesome AND easy mod. You won't be disappointed
  3. Aug 13, 2011 at 3:21 PM
    #1363
    rcbs204
    All order will ship on Monday the 15th.
    Thanks,
    S
  4. Aug 13, 2011 at 5:05 PM
    #1364
    canadaman
    canadaman Active Member
    Canada
    07 TRD Sport
    Illuminated my 4x4 switch today. I just used the stock orange and it looks fantastic. Excellent idea!
  5. Aug 15, 2011 at 11:10 AM
    #1365
    Mitch
    Mitch Somebody call for a Wambulance?
    Mitch
    Spokane, WA
    2007 Access Cab SR5 4x4
    Lights, Siren, Drugs, Needles, Electricity
    Stupid question, but do I need to srip the wire to solder it?
  6. Aug 15, 2011 at 11:30 AM
    #1366
    rcbs204
    Yes you do.
  7. Aug 15, 2011 at 11:56 AM
    #1367
    Mitch
    Mitch
    Spokane, WA
    Copy that. Just finished up. Looks great. And actually wasn't that bad.
    I first connected the white and red wires to opposite of you said (by accident) and my air direction light started working again. But the 4x4 light didn't work. So I figured out that I did them backwards. The 4x4 light now works but my air direction light isnt working again. Oh well.
    Thanks again Shannon
  8. Aug 15, 2011 at 12:54 PM
    #1368
    rcbs204
    Hey Mitch,
    Those are a really common fault.
    If you remove the bulb on the AC panel, you can kinda lift the lead on the buld and put it back in and it should start working again.
  9. Aug 15, 2011 at 1:36 PM
    #1369
    Mitch
    Mitch
    Spokane, WA
    Thanks for the heads up. Im gonna try that later today
  10. Aug 17, 2011 at 2:39 PM
    #1370
    grapevine220
    grapevine220 ...and here we...GO....
    Grapevine, Arkansas
    09 Toyota Tacoma Silver Double Cab TRD 4x4
    Matching Tonneau cover, Raptor series 4" nerf bars, tinted front windows, weather tech digital floor mats, Leather seat covers, K&N filter element, OBX throttle body spacer, Wade bugshield, Wade in-channel vent visors, Recon Line of Fire rear LEDs, Bull bar, Redline Tuning hood struts, Reid's leather armrest mod
    Need your help on my 4x4 switch....sent you a PM!
  11. Aug 17, 2011 at 2:47 PM
    #1371
    rcbs204
    Replied to PM, if you still need help after that, i can help after work tonight.
  12. Aug 17, 2011 at 6:22 PM
    #1372
    rcbs204
    I had to share this, it was really quite funny! All names have been removed to protect the innocent!!
    Customer:
    Hey, I bought one of your illuminated 4X4 switch kits and I am having some weird trouble. Please call me at xxx-xxx-xxxx if you can because I have hooked this thing up exactly as your instructions show but no illuminated switch. I reversed polarity and still no go. I checked the LEDs by hooking them up directly to a battery and they work. What is weird is that I checked voltage on the green and green w/white wires on the A/C wiring harness I didn't get voltage at all. I have an 09 Tacoma Double Cab and my A/C and fan are working properly so what gives? I have tried both the solder method and the T-tap method and I still get nothing. I even tried the green w/black wire because it showed voltage but that didn't work either. Help!!!
    My Reply:
    Did you turn on you head lights, and check for voltage? Head lights have to be on.
    Customer:
    :eek::eek::eek:That is ALL that it was!!!!!!!!I feel like a putz!!!!!!:eek::eek::eek:
    Thanks for the quick response and info. You da man!!!!!
    I had to share this one!!
    Hope the guy does not get too mad at me!
  13. Aug 18, 2011 at 12:16 AM
    #1373
    gottahot1
    gottahot1 Well-Known Member
    T.D.
    Arizona
    08 BLUE double cab 4x4 short bed Sport TRD
    'Caribe' fog light mod - Power port always on mod - Defrost A/C override mod - Illuminated 4x4 switch - Read diff breather relocation
    OK, I got my hardware in the mail today. I thought it would be a while before I was able to get to it but I found slices of time here and there to work on it.
    What I ended up with is a mish-mash of other install versions I've seen while lurking around this thread. For the switch part, I ended up running the wires through the "plug" and reinstalling the plug to hold the wires on place. It's sturdy - I'm not worried about the wires coming out.
    To connect to the A/C harness, I pulled the pins out and opened the crimped end a bit so I could add the wires from the kit and re-crimp. I am extremely particular and didn't want to expose any wire in the factory harness.
    So, no solder and no splice. I love it!
    Yes, I did check and everything works as it should. The lights come on (and look great) and dim with the rest of the dash lights and the A/C panel still functions correctly.
    Thank you for a quality product. It's refreshing to get something of this quality, but that's because it's MADE IN THE USA!!!
  14. Aug 18, 2011 at 2:44 AM
    #1374
    11TRD
    11TRD MERICA
    Jay
    Everett, WA
    2011 TRD SPORT 4X4 DC
    Cobra 29 WXNWBT, Devil Horns, ARB Bumper, Avid Stepbars, Homer Taco Satoshi thin lip grille, ICON UCA's, ICON EXT Travel up front with King 700# springs, Dakar heavy springs, sumo bump stops, with ICON VS 2.0 shocks in the rear, K&N Drop In, AVS Ventshades and Bugflector, Whelen SPS 660 emergency strobes, Redline Hood struts and tailgate EZdown, Illuminated 4X4 Switch, TRD Floor mats, Flyzeye LED lighting, Kragen 7" HID behind grille, Kragen 4" HID back up lights, Rigid SR Series 10" LEDx2 Elusive elements Lightbar, Firestik antenna, Rear Diff breather mod, Fogs anytime, Hitch Safe, OEM door sill strips, mryo mirror relocate bracket, Prinsu designs roof rack, Tepui Autana RTT, ARB Awning,Engo 10k winch synthetic, Blue seas fuse block and breaker, ARE Topper
    Damn its not on all the time???? I want a REFUND!!!:rofl::rofl::rofl::rofl:
  15. Aug 18, 2011 at 2:59 AM
    #1375
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    You could wire it up to be on all the time if you wanted to...:rolleyes:
  16. Aug 18, 2011 at 7:30 AM
    #1376
    rcbs204
    Yep 100% made in the USA!! Made in Montana!!
  17. Aug 18, 2011 at 6:33 PM
    #1377
    Tiedie
    Tiedie Well-Known Member
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    :DOk got my lites couple days ago,Got off early tonight and I quess since I putted around took about 45 min. including soldering,work great thanks again Shannon:yay:
  18. Aug 20, 2011 at 4:25 PM
    #1378
    rcbs204
    Your Welcome!
  19. Aug 21, 2011 at 11:13 AM
    #1379
    Tommy
    Tommy Well-Known Member
    Tom
    Indiana
    2010 Access cab SR5 4x4
    Got mine put in today, easy as can be, looks fantastic! Thanks for a great product!!
  20. Aug 21, 2011 at 2:34 PM
    #1380
    rcbs204
    Glad to hear it!
