rcbs204 4x4 Illuminated Switch!
Discussion in 'RCBS204' started by rcbs204, Jan 4, 2010.
  1. Feb 5, 2012 at 5:21 PM
    #1641
    Fractured
    Fractured FPS-a-holic
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    TRD wheels, TRD cat back exhaust, ScanGauge 2, Debadged, Avid sliders, UWS bed box w/automatic LED light, Led Interior/Reverse/Lic. Plate lights, Yellow Fogs, Flyzeye Light, Color matched grill, Rearview mirror relocate bracket, Power Sliding rear window, Plasti-dipped bumper/"T" emblem
    Weak. Oh well! Thanks for the info. I will wait to see what happens.
  2. Feb 10, 2012 at 5:18 AM
    #1642
    rcbs204
    rcbs204 [OP] Well-Known Member Vendor
    Sorry guys there will not be a 2012 option. I would have to design a new board, and it would only light the arrow. The return on investment is just not there, it would be a loosing proposition for me. Sorry for the long wait on this answer, but i have been trying to figure an easy way to make it happen.
    But no go.
    S
  3. Feb 13, 2012 at 4:43 AM
    #1643
    mhagie
    mhagie Well-Known Member
    Merle
    Washington Iowa
    2012 TRD sport DC LB
    none yet
    Meaning?
    Where do we go from here?
    Merle
  4. Feb 13, 2012 at 5:49 AM
    #1644
    nut
    nut she'll ride
    Patrick
    Arizona
    Totaled
    TRD SKEWP DCSB 4x4 Silver Mica | URD TCAI/MAF CAL | BHLM | GrillCraft | FF Sliders | LED's All Around | 12v Constant On | EGR In Channel | 15% Tint | Trimmed mud flaps | Fog Light Anytime Mod | Debadged | Tailgate Hoseclamp | DTRL Switch | Disabled Lock Beep/Seatbelt Chime | Husky Liners | HID's | BedRug | WO Seat Covers | ABS Kill Switch | Oil Catch Can | Viper 5704 | Custom Carbon Cabin Filter | Backup Camera Anytime | 400W Anytime | In Cab Outlet W/USB | Firestone Ride Rites | Ams Oil All Around | 32" LED In Lower Grill | BlackVue DR500GW-HD |
    i still think if you had a single LED bulb on the end of a 24" pigtail you could just feed it through the switch (as in dont remove the switch, just pull the knob off and run the wires "through" the holes in the switch) and like silicone it to the inside of the knob and have the arrow light up. I just need to get ahold of an LED thats wired and I'll do it. OP do you sell such a thing?
  5. Feb 13, 2012 at 7:17 AM
    #1645
    rcbs204
    That only works for one position, when you turn the switch, it won't be lit at the 4H and 4L. You need three leds, one for each position.
  6. Feb 13, 2012 at 11:43 PM
    #1646
    nut
    nut she'll ride
    Patrick
    Arizona
    Totaled
    I'll have to mock something up so you can see. The led would be glued directly under behind the arrow and the wires would have enough slack to allow it to rotate, so if you pulled the knob off it would dangle an inch or two with the slack. It's just an idea and haven't seen if there is enough room to clear the wires when you rotate it. I'll get something together this week if I can.
  7. Feb 14, 2012 at 5:45 AM
    #1647
    mhagie
    Merle
    Washington Iowa
    none yet
    The way I see it there is no way possible with the stock switch to light the dial as it is not translucent just painted on black plastic.
    The knob has potential for lighting but only the knob.
    I haven't had the chance to remove my switch yet as I work on it outside and I just heven't taken the time.
    I fully intend to bastardize something to try and have lighted dial and knob and realize that I might fail but I'm gonna try anyway.
    Damn luck, shoulda bought a 2011
    Merle
  8. Feb 14, 2012 at 11:04 AM
    #1648
    rcbs204
    Yeah I wish there was more i could do here, but there is no real $$ to make. I would have to charge like $500 for the thing, because it would be an all new front bezel, fabricating finished plastics is really spendy. And there is very limited interest maybe 25 people in all. Not worth my time and money, good luck with your en-devour Merle.
    Sorry 2012 guys.
  9. Feb 14, 2012 at 3:01 PM
    #1649
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    I have a 2008 and got your kit installed so my question is just out of curiosity. If someone wanted to spend the $$ could they buy a B 4 2012 switch and a kit and be good 2 go ?
  10. Feb 14, 2012 at 3:14 PM
    #1650
    rcbs204
    Nope, unfortunately, they changed the entire switch.
    Mounting and everything is different.
    The reason Toyota does not light the switch in the Tacoma, is because the switch is behind the steering wheel.
    They figured since it is obscured from the drivers view by the steering wheel, they would scrap the light and save then selves some money.
  11. Feb 14, 2012 at 3:20 PM
    #1651
    george3
    New Jersey
    Oh well, thanks for the answer. I like having it illuminated even if it it behind the steering wheel. I don't use it often but when I do - OOPS there it is. Don't have to turn on interior lights to find it.
  12. Feb 15, 2012 at 6:54 PM
    #1652
    TacoDawgs
    TacoDawgs Well-Known Member
    2008 Radiant Red DCSB TRD OR 4x4
    Front 5100s at 1.75. Rear TSB. LoRider tonneau cover. OEM bed mat. OEM bug deflector. Illuminated 4x4 switch. In cab AC outlets. 400W anytime. EGR in channel window visors. Black badges. Rear weathertech liners.
    That sucks for the 2012+ guys. It looks way better with the switch actually lit. And on a side note, Shannon makes a fantastic product for 2005-2011 guys. Thanks for the taking the time and effort to help us out Shannon.
  13. Feb 19, 2012 at 2:36 PM
    #1653
    george3
    New Jersey
  14. Feb 19, 2012 at 2:53 PM
    #1654
    rcbs204
    ^^ Hey that link looks like the same one in my sig!!! :D
  15. Feb 24, 2012 at 6:20 PM
    #1655
    rcbs204
    Im not complaining here, there has been huge rash of orders lately, and it ran me out of inventory. I will have all orders shipped as soon as i can!
  16. Feb 25, 2012 at 6:07 AM
    #1656
    mhagie
    Merle
    Washington Iowa
    none yet
    I see a light at the end of the tunnel for the 2012 guys, but not completly there yet.
    i will post my findings in a new thread as I have no intentions of hijacking this one.
    This ( Shannons) is a quality product for the 2005-11 guys at an excellent price.
    Merle
  17. Feb 25, 2012 at 7:44 AM
    #1657
    rcbs204
    Wow,
    Good job Merle!! They will most definitely be excited.
  18. Mar 5, 2012 at 10:44 AM
    #1658
    phat_ride_69
    phat_ride_69 Active Member
    Jack
    Calgary, AB
    2010 TRD Sport DCLB w/ JBL
    Westin Bull Bar with KC off road lamps, Nfab step bars, 5100's All Around, 1" Rear Spacer, 77 Series K&N Polished Intake,
    Just ordered a stock amber kit yesterday and paypal says "shipped" already!!!!
    Can't wait to install :D
    Thanks RCBS!!!
  19. Mar 5, 2012 at 11:50 AM
    #1659
    rcbs204
    Yeah i don't screw around when my items are in stock! :D
  20. Mar 9, 2012 at 7:17 AM
    #1660
    rcbs204
    Whats with all the Canada orders lately?
