rcbs204 4x4 Illuminated Switch!
Discussion in 'RCBS204' started by rcbs204, Jan 4, 2010.
  1. Mar 29, 2013 at 12:40 PM
    #1921
    rcbs204
    rcbs204 [OP] Well-Known Member Vendor
  2. Mar 29, 2013 at 12:52 PM
    #1922
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Have you decided if you are going to continue making these or not ?
  3. Mar 29, 2013 at 4:41 PM
    #1923
    rcbs204
    No not yet, i re-designed a new board (Rev3), but i have not ordered any boards. I may do enough to get through the year sales will tell. The last three months have been good enough to warrant the continuation of the product line.
    I have also invested in a 3D printer, so will more than likely be adding to the product line.
    Stay tuned, odds are good.
    S
  4. Mar 29, 2013 at 5:35 PM
    #1924
    DJ KRAZY K
    DJ KRAZY K Well-Known Member
    NM
    '15 TRD OFF ROAD 4X4 V6 Manual
    OME 886+Dakars, ARE Shell, ARB Front Bumper+Winch
    This may sound dumb but in your instructions when you say you get the power from the AC harness you mean the Air Conditioning, right? not alternating current harness or something I have know idea where it would be at? lol I dont want to screw it up...
  5. Mar 29, 2013 at 5:37 PM
    #1925
    rcbs204
    Yep Air Conditioning harness.
  6. Mar 29, 2013 at 7:26 PM
    #1926
    DJ KRAZY K
    NM
    Sweet thanks!
  7. Mar 30, 2013 at 5:18 PM
    #1927
    RickG
    RickG It seemed like a good idea at the time...
    Southern NH
    2010 SR5 4x4 Pyrite Mica
    Color matched grille, Access tonneau, OEM Temp/compass, De-badged, OEM hitch, Custom rear storage/dog deck, LED foot well lighting, Illuminated 4x4 switch
    Just put mine in today (...great service/quick shipping by the way, Thanks!)
    Anyway... my switch had an empty one of those little twist-in sockets that holds a bulb in the other switches. Looking at how the bulb leads were inserted into the ones on the AC module, I found that I could do the same with the wires from this light module. It worked great, and there was no need to solder. I didn't take a pic, but if you look on the back of the AC for the little brown bulb holders, it's pretty obvious how they work.
  8. Mar 30, 2013 at 5:29 PM
    #1928
    OZ-T
    Peter North
    British Columbia
    Interested but not following you ^^^
  9. Apr 1, 2013 at 1:48 PM
    #1929
    RickG
    Southern NH
    Yeah, sorry. Not too helpful without a pic. Anyway, here's the bulb socket that was in my switch (there was no bulb but otherwise this is the same part that's behind the AC and Recirc buttons. Copying those, I ran the wires up through hole A, over to the notch B, down under and up through notch C. Once reinserted and twisted, this allows the wire between section B-C to contact the pads that the installation instructions would have you solder to. (...only the red wire path is labeled here, but they're symmetrical).
    Not sure if these sockets are in all or most trucks, but it made things pretty easy.
  10. Apr 1, 2013 at 2:08 PM
    #1930
    rcbs204
    Very nicely done!
    Im surprised no one else has done that.
  11. Apr 1, 2013 at 2:52 PM
    #1931
    RickG
    Southern NH
    Thanks. I might just be the only one too lazy to solder it.
    The wire you supply is just the right gauge to fit through the holes as long as you twist the strands tightly and nip the end off clean.
  12. Apr 1, 2013 at 3:41 PM
    #1932
    45longcolt
    45longcolt Well-Known Member
    DFW Area
    2020 Off Road
    Has anyone just tried putting a bulb in the socket? Looks like that is all that would be needed to illuminate the switch.
  13. Apr 1, 2013 at 4:35 PM
    #1933
    RickG
    Southern NH
    Well, that and running the extra 2 wires. I was wondering that too, but I don't see how a single bulb would match the intensity of the rest of the panel lighting as well as these 6 LED boards do.
  14. Apr 1, 2013 at 5:45 PM
    #1934
    Chris24
    Chris24 Well-Known Member
    Greensboro, NC
    09 Black DCSB TRD Sport, V6, 6sp
    i think it'd be pretty dim...but it's weird that they have the switch wired for a light...but don't put a light in it from the factory...
  15. Apr 1, 2013 at 6:38 PM
    #1935
    rcbs204
    The single bulb is worthless, they would usually have what is called a light pipe in the switch. I spent the better part of 2010 perfecting what you see today!!
  16. Apr 1, 2013 at 7:17 PM
    #1936
    "OldManTan"
    "OldManTan" Bye bloody Taco... Hello MGM Burrito!
    Buffalo, NY
    '16 Tundra DC
    Holy chit, I've done a lot already!!
    If I remember correctly, we don't have the wires needed to do this from stock, the hot and ground for that light. I added mine so it looks like RickG's, but they weren't there when I started. I wonder if this was updated in 2010 to accept the 4-runner switch with out modification?? :notsure:
  17. Apr 2, 2013 at 5:38 AM
    #1937
    rcbs204
    [QUOTE="OldManTan";6679327]If I remember correctly, we don't have the wires needed to do this from stock, the hot and ground for that light. I added mine so it looks like RickG's, but they weren't there when I started. I wonder if this was updated in 2010 to accept the 4-runner switch with out modification?? :notsure:[/QUOTE]
    That would be nice if they did that.
  18. Apr 2, 2013 at 4:46 PM
    #1938
    RickG
    Southern NH
    [QUOTE="OldManTan";6679327]...I wonder if this was updated in 2010 to accept the 4-runner switch with out modification?? :notsure:[/QUOTE]
    No, not updated in my 2010. I had to add those 2 wires too. Mine are red/black though since I had trouble getting the supplied molex connectors to stay in there. I had some slightly different ones that stuck better.
  19. Apr 2, 2013 at 6:35 PM
    #1939
    "OldManTan"
    Buffalo, NY
    '16 Tundra DC
    Oh, then in that case I did the same as you. You can remove/replace the switch without anything other than unplugging it. I liked that because I could work on it without having to mess with splices. And looks better at dealer, although they better not toss my switch!! :mad:
  20. Apr 2, 2013 at 6:59 PM
    #1940
    rcbs204
    [QUOTE="OldManTan";6684878]Oh, then in that case I did the same as you. You can remove/replace the switch without anything other than unplugging it. I liked that because I could work on it without having to mess with splices. And looks better at dealer, although they better not toss my switch!! :mad:[/QUOTE]
    You sold your truck?
