RCBS204 Build Thread
Discussion in '2nd Gen. Builds (2005-2015)' started by rcbs204, May 8, 2011.
  1. May 18, 2011 at 3:23 PM
    #61
    rcbs204
    rcbs204 [OP] Well-Known Member Vendor
    OK, I asked Chris to change the title to my build thread.
  2. May 18, 2011 at 3:31 PM
    #62
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Done. :)
  3. May 18, 2011 at 3:32 PM
    #63
    rcbs204
    Thank you kind sir!!
  4. May 18, 2011 at 5:09 PM
    #64
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    NIce! can't wait to see the finished product :D
  5. May 19, 2011 at 3:13 PM
    #65
    rcbs204
    Going with the OME Dakar's Leafs in the back. Damn this stuff is adding up fast $$!!
  6. May 25, 2011 at 7:21 AM
    #66
    rcbs204
    Morning guys, I got the lift for the front and am now researching the back.
    I think i am going with the OME Dakar leaf packs, my question is, is that all it need?
    Do i need new shackles?
    Do need Longer U-Bolts?
    Do i need and shims or extra hardware?
    Thanks for the help.
    S
  7. May 25, 2011 at 7:46 AM
    #67
    rcbs204
    Thanks for the info,
    might you have a part # on the shims and the bushings?
    Thanks,
    EDIT: you are running exactly what i am buying right now. Might you have any tips on install and such.
    I see you did the carrier bearing shim, is that necessary? any rubbing with those 285's?
    Thanks
  8. May 25, 2011 at 8:03 AM
    #68
    rcbs204
    Oh cool, they got the bolts and everything, cheaper springs too!!
    Thanks, for the links!
  9. May 27, 2011 at 7:20 AM
    #69
    rcbs204
    All the Rear Suspension is on Order!! Woohoo!!
  10. May 31, 2011 at 7:43 PM
    #70
    rcbs204
    My Dakars shipped and will be here Thursday!! Whoohooo
    All i have left for the lift are the rear Icons!
  11. Jun 1, 2011 at 11:40 AM
    #71
    rcbs204
    So i just spoke with ICON, and it looks like the new rebuild-able rear aluminum shocks are gonna be available in 2-3 weeks. They are more in cost because they are rebuild-able. And a larger bodied shock as well. Can't wait to these.
  12. Jun 18, 2011 at 1:13 PM
    #72
    rcbs204
    Anybody know if i can do a complete 3" lift and not change the rear shocks?
    I have everything for my lift except the rear icons. Thanks guys
  13. Jun 29, 2011 at 8:38 PM
    #73
    rcbs204
    The lift is going on this weekend!!!
    Gonna have to run the stock wheels and tires for a little while yet, but should be good to go!
  14. Jul 1, 2011 at 6:20 PM
    #74
    rcbs204
    Holy shit that was allot of work. 9 hours in all, but was rather simple.
    The Lift is installed, and wow, more lift then i thought, the Truck looks absolutely stellar. What a difference.
    The only issue i have noticed so far is the tires squeal when going around some corners. I have the Stockers wheels and tires on still, and no alignment yet.
    I suspect the suspension should settle after awhile. Anybody else have the squealing tire issue, it not too bad, but it is new.
    The suspension in gravel washboard roads is unreal, it is super stable at high speeds on wash board roads and potholes/bumps.
    Anyway, wheels and tires to come next, as soon as the funds are saved!
    I will post pics as soon as the battery is charged on my sony camera.
  15. Jul 1, 2011 at 6:22 PM
    #75
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Shannon... Pics now!!! I know where you work, don't make me come there!
  16. Jul 1, 2011 at 7:13 PM
    #76
    rcbs204
  17. Jul 1, 2011 at 7:15 PM
    #77
    rcbs204
    More pics to come.
  18. Jul 1, 2011 at 7:29 PM
    #78
    memario1214
    Colton
    Missoula, MT
    Cool cool. Keep em comin.
  19. Jul 1, 2011 at 7:57 PM
    #79
    rcbs204
    You should just come check it out, I am home all day tomorrow for the most part.
  20. Jul 10, 2011 at 3:07 PM
    #80
    rcbs204
    OK gents,
    I went out on some trails today, nothing major, and we have a problem after lift.
    Got the truck all aligned, and went out.
    I have all stock wheels and tires still. When i go around rough corner, i here a popping, like something was loose, or i am hitting the end of travel on something. This is the front.
    I checked all the bolts and nuts from the lift and nothing is obviously loose. Any suggestions guys?
