RCD 4.5 Do it yourself
Discussion in 'Suspension' started by arrowthrower, Dec 25, 2010.
  1. Dec 25, 2010 at 7:29 PM
    arrowthrower
    arrowthrower [OP] Well-Known Member
    Logan
    Henderson, KY
    2011 DC Tacoma TRD
    Anybody tried to install theirselves? Wondering if it is really hard, or worth saving some money. Also having knowledge of working on your own stuff.
  2. Dec 26, 2010 at 8:50 AM
    arrowthrower
    Logan
    Henderson, KY
    2011 DC Tacoma TRD
    So i guess nobody has installed their own lift??
  3. Dec 26, 2010 at 8:55 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Many people may be busy with the holidays so a response to your specific inquiry may take longer than expected. Sorry for the inconvenience.
  4. Dec 26, 2010 at 9:03 AM
    Rucas
    Rucas 1st gen
    Lucas
    1st gen. 4x4
    Custom Aluminum Camper
    Ask solus694 and PreRunnerSeth.
    They did the RCD lift but if i remember it took some time, but they got it all in.
  5. Dec 26, 2010 at 9:10 AM
    jr114
    jr114 Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    No personal experience. But if you plan on doing this, make sure you have the capabilities to cut and weld the crossmember. I also think that alot of time may be spent on puuling stuff off of the old spindle and replacing them on the rcd spindle. Im sure someone on heres done this and will chime in.
  6. Dec 26, 2010 at 9:31 AM
    surfrat
    surfrat Well-Known Member
    LI, NY
    icon coilover, total chaos UCA, allpr expo, icon 2.0 rear,wet okole
    ive installed this type of lift before on my 91 pickup..its easy just a little time consuming..take your time, have the right tools and you will get it donw..I plan on installing mine FWIW. this time it should be easier since the truck is pretty new and not rusted like the 91 i had
  7. Dec 27, 2010 at 3:42 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    Prerunnerseth, Senor_Taco, Celtic and I installed mine... it took a long ass time. No need to weld, just need something to cut the cross member. The majority of the time was spent disassembling and reassembling the shocks, LCA, UCA, tie rods, and getting the damn axle nut off. In all it took about 16 hours w/ a few breaks and a couple of trips to the auto parts store.
    it was a pain but doable... probably should have tackled this over two days instead on just one
    I also learned a ton... btw, if you don't have air tools then I wouldn't do this...
    one more thing... wheelersoffroad.com has the RCD kit for the cheapest... $1799.00 plus shipping
  8. Dec 28, 2010 at 2:18 PM
    arrowthrower
    Logan
    Henderson, KY
    2011 DC Tacoma TRD
    Thanks. No i am considering Pro Comp since it is $800 cheaper. What does everyone think about Pro Comp?? I heard RCD is better.
  9. Dec 28, 2010 at 3:31 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    The Procomp basic 6" uses giant front spacers... while the RCD uses "custom" non-adjustable bilstein 5100s with stock springs thus RCD is better
  10. Dec 28, 2010 at 3:34 PM
    Rucas
    Rucas 1st gen
    Lucas
    1st gen. 4x4
    RCD. 4.5" is perfect height. plus the custom 5100's are way better than the huge spacers.
  11. Dec 28, 2010 at 6:16 PM
    HOSS454
    HOSS454 Well-Known Member
    Pukalani
    08 Sport
    Bolt ons here and there
    i have installed this lift by myself... took me the whole weekend but wasnʻt too bad... just a couple trips to the hardware store set me back some time, but all in all, it was easy to do, if you got the tools... and i got my rcd lift cheaper from dsms... they are awesome...
  12. Dec 28, 2010 at 7:52 PM
    arrowthrower
    Logan
    Henderson, KY
    2011 DC Tacoma TRD
    You got it cheaper than $1799? Even if Pro Comp is $800 cheaper, i have to go to an 18" wheels and tire. That is $800 difference there. I am sold on RCD. Does anyone know about warranty with RCD? Also i can't get anyone to say if they support 2011. All the local dealers will not backup because RCD just makes them for 05-10.
  13. Dec 28, 2010 at 10:51 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    ^don't know about the warranty, but theres not much different between 2010s and 2011s...
    RCD warrants their parts against failure though... you don't need 18s with RCD either... obviously since I have 17s
  14. Dec 29, 2010 at 9:41 AM
    arrowthrower
    Logan
    Henderson, KY
    2011 DC Tacoma TRD
    I am just waiting for Wheelers to open so I can call!
  15. Dec 29, 2010 at 11:30 AM
    arrowthrower
    Logan
    Henderson, KY
    2011 DC Tacoma TRD
  16. Dec 29, 2010 at 11:53 AM
    jrobson
    jrobson Well-Known Member
    Mobile, Alabama
    09 DC 4x4
    Ultimate lift kit, LR UCA's, Bi-xenon 8000K headlights, Xenon 8000K foglites, (4) KC slimlites on N-Fab light bar, Extang trifecta toneau cover
    Have it installed. Took my mechanics about 8 hours with proper equipment. You will thank yourself later for buying this kit after you see how well it performs. I love mine.
  17. Dec 29, 2010 at 12:44 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
  18. Jan 2, 2011 at 6:40 AM
    K1992f
    K1992f Well-Known Member
    Kanon
    Dirty Hanover pa ...
    2012 tacoma TRD sport fully loaded
    6" fabteck 20" fuel hostage 33" nitto MTs
    On this lift there's no aal to rear ?? Everything you need for this lift come with it ????
  19. Jan 2, 2011 at 6:57 AM
    arrowthrower
    Logan
    Henderson, KY
    2011 DC Tacoma TRD
    As far as I know.
  20. Jul 13, 2011 at 5:24 PM
    RugbyTaco
    RugbyTaco Rhum.
    Paul
    Sleepy Hollow
    '10 TRD Sport Magnetic Gray
    Wet Okoles, Weathertechs, AFE Pro Dry, Wicked Flow 13", URD MAF, MagLite Mount, 16x8 Procomp 8069, 265/75/16 GY Duratracs, Rear Leaf TSB,AAL, OME 9000s, 884s, S2000 stubby antenna, Leer XR100
    Thread revival! Are there any other options for the rear besides the blocks? Could you use a leaf pack and maybe a 1.2-2" block rather than the 4"? The 4" block just rubs me the wrong way
