RCD 4-5" lift kit - Wheel questions
Discussion in 'Suspension' started by Taco.Supreme, Sep 18, 2012.
  1. Sep 18, 2012 at 9:11 PM
    Taco.Supreme
    Taco.Supreme [OP] Member
    Dale
    Kelowna, BC
    07 V6 DBL cab
    Looking at getting this kit installed on my truck. I eventually want to put wheels and tires on after this winter. My questions is, can I run the stock Sport 17's on this lift to make it through the winter?
    RCD's website states "wheel size of 17” x 8” with a maximum of 4.5” backspacing"... I tried to search the backspacing for the stock 17's but I can't find an exact answer. The best answer I came up with was stock 16's are 4 5/8's backspacing. If that's the case for the 17's, will that difference in backspacing be enough for them to not fit?
    Sorry if this has been answered somewhere. First post!
  2. Sep 19, 2012 at 7:11 PM
    Taco.Supreme
    Dale
    Kelowna, BC
    07 V6 DBL cab
  3. Sep 21, 2012 at 8:05 PM
    Taco.Supreme
    Dale
    Kelowna, BC
    07 V6 DBL cab
  4. Sep 22, 2012 at 7:26 AM
    Chad7088
    Chad7088 Old Newbie
    Chad
    19th state
    '12 Tacoma DC Sport 4x4
    4.5 RCD lift, 295/70/17 hankook dynapro ATMs wrapped around 17x9 helo HE791 wheels, avs in-channel window visors, 20% tint, gibson cat-back, afe dry filter, painted engine cover, sock monkey decals, sickspeed shift knob, wet okole seat covers, weather-tech floor mats, G4 fold-a-cover tonneau, n-fab step bars
    stocks will not work with this lift....stocks have a +30 offset and 5.5 bs
    you will need at least a 4.5 bs and a negative offset
    The helos i have are 4.5 bs with a -12 offset....hope this helps..good luck
    On a side note...the lift is awesome
