RCD 4.5 vs 3" other lift
Discussion in 'Suspension' started by 2009tacomav6, Mar 11, 2009.
Is the 4.5 RCD worth the high cost ($2100) vs a 3" ($400)
  1. 3 inches is perfect for the look and upsizing
    173 vote(s)
    41.9%
  2. 3 inches is a better value than a 4.5
    72 vote(s)
    17.4%
  3. 4.5 kit is cool but not sure its worth the money
    127 vote(s)
    30.8%
  4. 4.5 + kits are not worth the cash if not off roading
    41 vote(s)
    9.9%
  1. Jul 1, 2009 at 10:27 PM
    #61
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    The RCD kit looks very nice.
  2. Aug 1, 2009 at 12:30 PM
    #62
    FoxRacR17
    FoxRacR17 Well-Known Member
    Kevin
    SoCal
    09 4x4 SR5 DoubleCab Short Bed
    Fox 2.5 C/O's, Fox 2.0 rear shocks, toytec 1.5" AAL, TC UCA's, blue/white dashboard lights, seatbelt chime removed, Synthetic leather armrests, WO seat covers front and back, Goodyear Wranger Duratrac 285/70/17, KMC XD Addict 17x9 rims
    so any work on if this RCD 4.5" lift is ever going to be compatable with the 09's with their VSC?
  3. Aug 2, 2009 at 12:51 AM
    #63
    05HUGHESTACOMA
    05HUGHESTACOMA Member
    NEW ORLEANS
    6" FABTECH STAGE II LIFT, BLACK BULLET GRILL, BLACKED OUT FRONT HEADLIGHTS, BLACKED OUT TAILS..
    i have one new 6" fabtech adj. Coilover.... If anyone needs a new one.. Let me know!
  4. Aug 11, 2009 at 10:35 AM
    #64
    imsikotic
    imsikotic If u cant stand behind our troops. Stand in front
    Randy
    Temecula, Ca
    06 TRD Sport DesertRunner
    4" Camburg Race Spindles and Icon 2.5" ext travel Coilovers in the front for about 5"of lift and for the rear All-Pro 3" leaf pack and Fox 2.0 Resi's converted to piggyback and custom valved by DownSouth Motorsports. 17x9" KMC XD Addicts w/ 4.5 inch Backspacing and -12 Offset. Wrangler Duratracs 285/70/17. K&N CAI, Exhaust, Carriage Works Billet Grill, Custom Bed bar with ProComp fog lights,DirtKing Fabrication front bumper w/ 3 HID converted Hellas, Demello rear PreRunner bumper, Tinted windows, Full System w/ 2 10s, Garmin 265WT, ClearHLM. Theres more I just cant think of it right now.
    I agree with the Camburg 4" spindle option if you are 2WD.
  5. Aug 18, 2009 at 12:34 PM
    #65
    silvertaco82
    silvertaco82 No way, get real
    Bozeman, MT
    2010 AC TRD Sport 4x4
    TRD Seat Covers, Weathertech floor mats, Sockmonkey Decals, Pro Comp 6", 35" Nitto Trail Grapplers, 18x9 XD addicts, 20% tint, Kenwood Dnx 5120, 2 10" Kicker Shallow mount subs
    little off topic, but can you fit a 16" rim with that 4.5" rcd lift?
  6. Aug 18, 2009 at 9:17 PM
    #66
    peejay
    peejay Yep im that Peejay..
    PJ
    San Diego
    Running a tricked out rzr xp 4
    Rollin a Hemi, and wheelin a sick xp4
    I believe so, you have to check on the backspacing.. call Matt at RCD to be sure though.. Im running 17's on mine...
  7. Aug 31, 2009 at 6:07 PM
    #67
    JRW1223
    JRW1223 Well-Known Member
    Jordan
    Tucson, AZ
    07 DCab 4x4 sport
    All Pro long travel, All Pro Front bumper, BFG 285/75/16, American Racing Ledge Wheels 16x8, Vision X 8.7" Tungsten Halogen Off Road Lights
    Those are some good ideas. Does anyone know if putting some adjustable coilovers in there for the RCD lift would work? Everytime I look at this lift on someones truck it seems to be sitting lower in the front.
  8. Sep 4, 2009 at 12:56 AM
    #68
    raydey boy
    raydey boy New Member
    Mililani, HI
    09 4x4 Sport Package
    Debadged and all stock
    isnt it the springs that hold the truck up and not the shocks? If so, seeing how you use the stock springs with the rcd kit go get 4", i would think any 3" adj c/o would work witht this lift. anything ajusted after 0" would be an additional raise ontop of the 4" you get from the RCD.
    Will this work?
  9. Sep 4, 2009 at 2:05 AM
    #69
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    no, that wouldnt work. The bilsteins that RCD supplies with their lift are a lengthened shock when compared to the overall length of a stock coil over assembly even though it uses the factory spring. Although, i dont see why a set of OME 885's or similar springs couldnt be used to gain a bit of height out of the front. The valving in bilsteins may or may not work well with the heavier rate springs though...
  10. Sep 7, 2009 at 1:15 AM
    #70
    raydey boy
    Mililani, HI
    i understand the bilsteins are a lengthened shock that uses the stock spring. But if you put this bilstein shock with the stock spring in a stock truck, wouldnt the height be the same as a stock? isnt the bilstein longer only to compensate for the additional travel needed for the 4" d/b and not for height purposes? if 885s would work, why wouldnt a 3" C/O work too?
  11. Sep 7, 2009 at 3:52 PM
    #71
    dmasters
    dmasters if it fly's it dies !
    dan
    LB,ca
    tundra & tacoma 4x4
    hey that rcd lift looks grate
    4.5 lift looks like the way to go..
    truck look cool man.
  12. Oct 5, 2009 at 8:01 PM
    #72
    tim920
    tim920 Never seen Forest Gump
    Tim
    Boston, MA
    2005 4Runner Limited V6
    What can I do besides the RCD and the All Pro options given in this thread if I want something in between a 3" and 6" lift? 3" doesn't seem much of a lift and 6" is too high. Someone mentioned a body lift. Is that a good idea? It's mainly for cosmetics. I have a 4x4 for so the spindles are out. Trying not to spend close to 2K for a lift.
  13. Nov 21, 2009 at 4:12 PM
    #73
    anti
    anti Well-Known Member
    Johnson
    08 DCLB 4WD
    the RCD lift is 4.5" drop bracket lift
    Procomp and Fabtech are 6" drop bracket lifts
    Allpro, Total Chaos, Engauge and Camburg make LT kits, combined with adjustable coilovers giving (i think) 2.5"-4" of lift.
    All other spacer and coilover kits are going to be up to 3.5" of lift, but not recommended to go over 3"
    edit: you said $2k limit, so cross out the drop bracket and LT kits
  14. Jul 1, 2010 at 3:44 PM
    #74
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    why is revived...did someone vote on this?
  15. Jul 1, 2010 at 4:29 PM
    #75
    tim920
    Tim
    Boston, MA
    I noticed this happening before, too. Either that or you're just showing off. :D
  16. Jul 1, 2010 at 5:00 PM
    #76
    hookedontronics
    hookedontronics Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    All your poll questions are against a 4.5" lift.
    Somebody is a little bias...
  17. Jul 1, 2010 at 10:10 PM
    #77
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    I like to whore out pics of my truck
  18. Jul 29, 2010 at 1:54 PM
    #78
    hookedontronics
    Jake
    Glenville, NY
    Stock UCAs? Hows the alignment? Do i need UCAs if i go with a RCD lift?
  19. Jul 29, 2010 at 2:28 PM
    #79
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    16 Super White Limited 4x4
    No you do not need UCAs, The taller Spindle keeps the ball joint angles correct.
  20. Jul 29, 2010 at 2:28 PM
    #80
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    he sold that truck a year ago
