Rcd 4.5"
Discussion in 'Suspension' started by Toyota_hic, Aug 4, 2009.
  1. Aug 4, 2009 at 3:42 PM
    Toyota_hic
    Toyota_hic [OP] Well-Known Member
    Grant
    07 offroad red tacoma SR5 ac./cab
    westin bull bar, tube steps, BFG MT, silver ceramic coated JBA shortys, tru dual flowmaster 40series with magnaflow tips, 77series K&N intake, allpine head unit, 10" type R sub, 500w/4 amp
    thinking about buying the RCD 4.5 lift, but never lifted or owned a lifted truck how dose RCD compare too other lifts i have done a little research online but id like some oppinions of people that are more expericed first hand....oh yea would the lift look bad with stock wheels and 275 BFG MT
    idk if i have the money right away to buy new tires and there are nothing wrong with the ones i have now but didnt kno if it would look goofy
  2. Aug 4, 2009 at 3:44 PM
    TexasIslandBoy
    TexasIslandBoy THE RED DRAGON!!
    Andrew
    South Texas. SPI
    07' trd offroad 4X4 (For Sale)
    pro comp 6inch lift 35'' tires moto 950's radfo coilovers magnaflow exhaust 5/16" front skidplate usa spec ipod interface tree pin strip mod dry drop in filter full size BFG KM2 spare
    i say go 6 inch if your going to do a drop bracket lift kit even if you only run 33s
  3. Aug 4, 2009 at 4:58 PM
    Toyota_hic
    Grant
    6" is just too high for my taste i really like the looks of the 4.5 i just wasnt sure if anyone has had any issues with it, or if it will look funny with that small of a tire
  4. Aug 4, 2009 at 5:03 PM
    06Bluez
    06Bluez Well-Known Member
    Phoenix, Arizona
    06 4x4
    Icon Coil-overs, TC UCA, with Bilstein 5150 and Icon 3 leaf pack. 17" Moto Metal 951 4.5" Backspacing wrapped in 285/70/17 BFG AT's. Demello front bumper and Avid offroad sliders.
    It looks dumb with a small tire. I dont like the lookds of the RCD lift.
  5. Aug 4, 2009 at 5:04 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    If your not 4x4 consider a spindle lift
  6. Aug 4, 2009 at 5:05 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    The RCD lift is one of the better drop bracket lifts out there.
  7. Aug 4, 2009 at 5:18 PM
    Toyota_hic
    Grant
    yes i have a 4x4
  8. Aug 4, 2009 at 5:26 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Its not on our site yet, but I can get you a good price on the RCD lift. They are a great company with good quality products. We can also get you some longer shocks or Coilovers for the front for improved offroad perfomance.
  9. Aug 4, 2009 at 6:27 PM
    KMN-BLU
    KMN-BLU less work/more play
    Destin, Fl
    2016 Limited DCSB 4x4 Blazing Blue
    I received notice today in the following email that the RCD 4.5 lift is now available for the 09 models with VSC option.
    Email---------------------------------------------------
    Our 4.5”-5” suspension system for the 05-09 Toyota Tacoma 4wd & 2wd PreRunner models is now available. The system is part #10-47405. The system comes complete with a two-piece lower sub-frame assembly with integrated differential skid plate and polished stainless steel anti-compression struts, CNC machined replacement cast iron steering knuckles, heavy-duty front differential brackets, front sway bar drops, front bump-stop extension brackets, front and rear brake line extension brackets, 4” rear lift blocks, rear u-bolts with hardware and two front and two rear Bilstein 5100 Series shock absorbers. Clears up to a 33”x12.50” tire on 8” wide wheels. Requires wheels with a maximum of 4.5” of backspacing. I have also attached a kit photo, vehicle photo and a copy of the installation instructions.
    Vehicles equipped with the factory Toyota VSC system will need to be recalibrated by a qualified technician after installation of the suspension system and realignment of the front end. The VSC system may be more sensitive compared to stock form with the system installed.
    If you have any questions or need any further information please feel free to e-mail me back, or you can also give us a call toll free at (866) 469-7257.
    Thank you for the inquiry.
    Matt Yoder
    RCD Suspension
    1900 Weld Blvd., Ste. #100
    El Cajon, CA 92020
    PH # (619) 588-4723
