RCD 4" or Fabtech/Procomp 6" lift???
Discussion in 'Suspension' started by Sapper, Feb 20, 2013.
  1. Feb 20, 2013 at 5:39 AM
    Sapper
    Sapper [OP] Active Member
    Ft leonard wood
    I am torn between getting a 6" or RCD's kit. I will not be going above a 33" tire. I tow with my truck, and do not want to do any trimming at all. Any suggestions.
  2. Feb 20, 2013 at 5:46 AM
    Monster Coma
    Monster Coma Well-Known Member
    Corey
    Pittsburgh, PA/Houston, TX
    Sponsored by Mom and Dad
    You are willing to cut up your truck to fit a 6" DB lift but not trim your fenders or do a CMC? Lol if you don't want to cut into your truck I recommend a 3" lift
  3. Feb 20, 2013 at 6:01 AM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    This.
  4. Feb 20, 2013 at 6:21 AM
    BORNWILDGUY
    BORNWILDGUY Well-Known Member
    Rich
    Florida
    2020 TACOMA TRD SPORT DCLB LIFTED W KDMAX-PRO XT TUNE
    FULLY LOADED WITH THE TECH PACKAGE, LEATHER, JBL SYSTEM W UPGRADED JBL SPEAKERS IN AL DOORS AND SUB, LED HEADLIGHTS, MOONROOF, EXTANG FULL TILT COVER, NFAB SIDE STEPS, OEM ROOF RACK, TRD PRO TAILS, COLOR MATCHED TRD PRO GRILL WITH WHITE RAPTOR LIGHTS, 15% TINT ALL THE WAY AROUND, TINTED WINDSHIELD 50%, BILSTEIN 6112'S W 650# SPRINGS AND 1/4 SPACER, ICON LEAF SPRINGS W 5125 REAR SHOCKS, WELD LEDGE 6 WHEELS 18 X 9 -12 W 275/65R18 TOYO AT III LOAD C TIRES
    If you want an 4.5 rcd or 6" just go for it. Alot of drop bracket haters on here. You can always go with the bds or zone 4" then if later on you want to upgrade to 6" you can. 33's will look good on either one and you won't have to do the cab mount chop
  5. Feb 20, 2013 at 6:25 AM
    jtav2002
    Josh
    Reading, PA
    In this instance its not hating if he doesn't want to trim simple plastic why is he going to want to make more permanent modifications for a drop bracket lift?
  6. Feb 20, 2013 at 6:29 AM
    BORNWILDGUY
    Rich
    Florida
    Because obviously he wants the look of a 4 or 6" that a 3" obviously isn't gonna give him w/o having to trim doing cab mount chop and deal with tires rubbing. Nothing wrong with cutting the crossmember to install a drop bracket kit since you are installing new stronger bracketry for your lower control arms to mount.
  7. Feb 20, 2013 at 6:33 AM
    Monster Coma
    Corey
    But that's what I'm saying it doesn't make any sense.
    You aren't hurting anything trimming fenders or doing a CMC.. so why would you want to cut your cross member but not cut plastic..
    Without cutting anything you can do a 3 inch lift and a 1" BL and BOOM 4 inches.. no cutting required
  8. Feb 20, 2013 at 6:58 AM
    BORNWILDGUY
    Rich
    Florida
    I would rather cut my crossmember to install stronger bracketry versus lifting your entire body off the frame whith some poly/plastic bushings. Body lifts aren't the greatest way to achieve lift.
  9. Feb 20, 2013 at 7:03 AM
    jtav2002
    Josh
    Reading, PA
    I'd neither cut my cross member nor install a body lift lol.
  10. Feb 20, 2013 at 7:04 AM
    Monster Coma
    Corey
    It was just an example.. he doesn't want to cut plastic but is fine cutting metal. Doesn't make sense to me but its his lift he can do what he wants
  11. Feb 20, 2013 at 8:20 AM
    Sapper
    Ft leonard wood
    I did not realize that it was very minor trimming of some plastic, i just dont want hack the hell out of them. My bad for not looking into that first off. I was just looking for advice to go up to 6" if im planning on running 33s.
  12. Feb 20, 2013 at 8:25 AM
    Monster Coma
    Corey
    You can run 33s on a 3" lift with some trimming and a CMC. You'd never know the CMC was done unless you looked
  13. Feb 20, 2013 at 5:20 PM
    Sapper
    Ft leonard wood
    Tracking, but the 3" lift is not the kit in question.
  14. Feb 20, 2013 at 5:23 PM
    Monster Coma
    Corey
    Then it's up to you do you want 4 inches or 6?
  15. Feb 20, 2013 at 5:43 PM
    Sapper
    Ft leonard wood
    That's the question I wanted advice on.
  16. Feb 20, 2013 at 5:46 PM
    Monster Coma
    Corey
    I mean that's really a personal preference. What are you looking for?
  17. Feb 20, 2013 at 5:49 PM
    Sapper
    Ft leonard wood
    Which would look better with 33s.
  18. Feb 20, 2013 at 5:50 PM
    Monster Coma
    Corey
    4" IMO. 6" looks better with 35s
  19. Feb 20, 2013 at 5:59 PM
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX
    2013 Trd Sport DC, 07 DC sr5, 03 Prerunner
    2003: Stock 2007: Avid Offroad sliders, 30% front tint, bed mat, Truxedo low-pro qt tonneu cover, aero turbine 2525 muffler w/ 8'' tip, AR25 Resonator, 16x8 Dick Cepek DC-1 w/ 265/75 Goodyear Wrangler Duratracs, 2010 headlights, ome 884 coils with .5'' top plate spacer, OME sport front shocks, bilsten 5100s rear, 2'' aal, locking gas cap, LR ucas, Viper 2-way remote start, afe drop in filter, Rocky locking bike mounts, gear chest, scangauge, pop n lock tailgate lock 2013: most things transferred over from my 07, 5100s @ .85 + eibachs and Toytec tps for 3'' front lift, wheelers progressive aal w/ overload; compustar 2-way remote start; Antennex shorty antenna, pop n lock tailgate lock with programmable key, seat covers, Toyota's crappy all-weather floor mats (should have got Husky's or Weathertechs), TRD skid plate, led light pods mounted in front bumper valence w/ Eyourlife wireless harness and remote, led bed lights, light pods mounted in bed, Devil Horns emblem from Diaz Fabrications, rear facing pod lights in bed, under seat lights,
    I'm not sure if you're 4wd or 2wd, but if you're 2wd you should look in to the maxxtrac spindles. Those will give you 4'' and then, if you feels so inclined, you can throw some 2'' lift coils or a hat spacer on later if you feel you really want the 6 full inches.
  20. Feb 20, 2013 at 6:02 PM
    Sapper
    Ft leonard wood
    It's 4wd
