RCD club, how many are in?
Discussion in 'Suspension' started by jrobson, Jun 15, 2010.
  1. May 28, 2014 at 2:26 PM
    #1121
    wobble
    wobble Well-Known Member
    Ridgefield, WA
    2014 TRD OR
    Modified RCD Lift, 315/70R17 STT Pros
    I just measured my clearance between steering knuckle and tires. I have 3/4". I'm running 17x9, 4.5" backspace, -12mm offset, 285/70R17 tires. The additional -12mm offset would put you about 1/2" closer than mine, which would leave you about 1/4". With the additional width of 305/70s over 285/70s, it might just put the tire into the steering knuckle. It's gonna be close.
  2. May 28, 2014 at 2:31 PM
    #1122
    rtgreene10
    rtgreene10 Well-Known Member
    Fl cracker
    4x4 turd
    Ahhhhh dammit. Well if they don't fit then Atleast it will be at a shop where they can order some new treads if needed.
  3. May 28, 2014 at 2:44 PM
    #1123
    rtgreene10
    Fl cracker
    4x4 turd
    The additional offset will push me farther from the knuckle. My backspace is about 4.1
  4. May 28, 2014 at 2:45 PM
    #1124
    wobble
    Ridgefield, WA
    2014 TRD OR
    Good catch. You are correct. It might just fit then!
  5. May 28, 2014 at 6:50 PM
    #1125
    NoRemorse
    NoRemorse Well-Known Member
    James
    Vermont
    2010 4wd 4 Door, Magnetic grey
    RCD 5" DB Lift Light Racing UCA Nitto Trail Grapplers 295/70/17 Red Stainless brake lines head lights and grill, JVC KW-Av6 DVD/6.1 Touch Screen wetokole seat covers, Husky Floor mats, Yellow fogs, toyota logo door projectors
    Hoping to maybe get my UCAs and spacers installed this weekend and get the alignment redone. I ended up just getting the 1/2" and 1/4" spacers from toytec. I only get a once every other Sat. For free labor and shop use from my buddy. Hoping he has time to deal with me this weekend. Fingers crossed lol.
  6. May 28, 2014 at 8:03 PM
    #1126
    rtgreene10
    Fl cracker
    4x4 turd
    Are you guys running the top spacer for the "taco lean"?
  7. May 28, 2014 at 8:50 PM
    #1127
    wobble
    Ridgefield, WA
    2014 TRD OR
    I'm running a 1/4" poly spacer for taco lean. Both sides are 26" hub to fender.
  8. May 29, 2014 at 9:52 AM
    #1128
    rtgreene10
    Fl cracker
    4x4 turd
    Anyone running the Carrier drop kit? I have one but don't know if I need to put it on.
  9. May 29, 2014 at 10:01 AM
    #1129
    wobble
    Ridgefield, WA
    2014 TRD OR
    The RCD kit comes with one.
  10. May 29, 2014 at 10:02 AM
    #1130
    RND2
    RND2 Well-Known Member
    In my head swimming around
    12 DCSB
    RCD 4"
    Im running mine and getting a little vibration at different speeds but mostly around 20/25.
    May need to lower it some more just haven't had any time.
  11. May 29, 2014 at 10:03 AM
    #1131
    wobble
    Ridgefield, WA
    2014 TRD OR
    I have a slight vibration as well from 5-15mph, but it's not bad.
  12. May 29, 2014 at 1:15 PM
    #1132
    rtgreene10
    Fl cracker
    4x4 turd
    Well it looks like I have to wait another week for my install. The shop is super backed up on some custom trucks.
    @wobble. Let me know how those dakars ride!
  13. May 29, 2014 at 1:16 PM
    #1133
    wobble
    Ridgefield, WA
    2014 TRD OR
    That sucks!
    Will do. I will probably install them Saturday.
  14. May 31, 2014 at 5:30 PM
    #1134
    wobble
    Ridgefield, WA
    2014 TRD OR
    I installed the Dakars and 1.5" blocks. It's definitely stiffer, but I like the ride.
    Measurements with 4" blocks:
    LR 25 3/4"
    RR 26"
    Measurements with Dakars and 1.5" blocks:
    LR 26 1/4"
    RR 26 3/4"
    I gained 1/2" on driver's side and 3/4" on passender side. I'm sure they will settle a little though.
    rtgreene10, not sure if you planned on using the u-bolts that came with the RCD kit or not. I did and there are 1.5" of thread showing after tightening them. I'm going to order some a little shorter since they stick down a bit.
  15. Jun 1, 2014 at 7:36 AM
    #1135
    Mandy3206
    Mandy3206 Well-Known Member
    San Juan PR
    Sand Pearl Black 06 6spd DC SB TRD OR Moded
    Cutting them would be faster and cheaper, just grind them down...............
  16. Jun 1, 2014 at 11:08 AM
    #1136
    rtgreene10
    Fl cracker
    4x4 turd
    :worthless:
    Good to know buddy. Can't wait
  17. Jun 1, 2014 at 9:33 PM
    #1137
    wobble
    Ridgefield, WA
    2014 TRD OR
    Spent the day cutting down a maple tree and pulling the stump. Best I can do right now. lol
  18. Jun 1, 2014 at 9:35 PM
    #1138
    wobble
    Ridgefield, WA
    2014 TRD OR
    Thanks Mandy! Will do that.
  19. Jun 1, 2014 at 10:08 PM
    #1139
    Mandy3206
    San Juan PR
    Cool, anytime bro.........
  20. Jun 2, 2014 at 4:24 AM
    #1140
    RND2
    12 DCSB
    RCD 4"
    Wobble how's the ride with the new springs compared to the stock?
