RCD club, how many are in?
Discussion in 'Suspension' started by jrobson, Jun 15, 2010.
  1. Oct 31, 2010 at 7:08 PM
    #121
    surfrat
    surfrat Well-Known Member
    LI, NY
    icon coilover, total chaos UCA, allpr expo, icon 2.0 rear,wet okole
    will Fj trd gunmetals fit with this RCD kit?
  2. Oct 31, 2010 at 10:45 PM
    #122
    cantac09
    cantac09 Official TW Igloo Builder
    Hugh Jass
    Saskatchewan
    tundra
    stock
    if they are 17 inch and 4.5 inch backspacing they will
  3. Nov 6, 2010 at 10:29 PM
    #123
    sandjunkie
    sandjunkie Well-Known Member
    Aaron
    OC
    I'm in.
    ChadsPride likes this.
  4. Nov 6, 2010 at 10:43 PM
    #124
    Eman5pt0
    Eman5pt0 Well-Known Member
    E
    NY
    so i think im convinced to get an rcd lift!
  5. Nov 6, 2010 at 11:08 PM
    #125
    cantac09
    Hugh Jass
    Saskatchewan
    tundra
    stock
    its a great lift man
  6. Nov 6, 2010 at 11:57 PM
    #126
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    ^because you have nothing to lower... honestly since you have a prerunner just get spindles
  7. Nov 7, 2010 at 12:01 AM
    #127
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
  8. Nov 7, 2010 at 9:52 AM
    #128
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    I think his is at 4.5" and he is running a 305/65/17 IIRC.
  9. Nov 7, 2010 at 10:31 AM
    #129
    cantac09
    Hugh Jass
    Saskatchewan
    tundra
    stock
    ^^^ yes they are
  10. Nov 7, 2010 at 10:44 AM
    #130
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    thanks
    Yes 4.5" RCD with BFG 305/65/17 AT
    btw,
    the reason why you don't have to chop anything is because us 4wd have a front differential that needs to be dropped when going over 3" of lift. In order to do so, you have to cut the front cross member for the diff to drop down since the front cross member is directly under the front diff.
    You can get spindles that can give you either 4" or 3.5" depending on the brand. Add a nice leafpack or and AAL and you'd be good to go. No need for UCA or new shocks... however, since the stock shocks are pathetic a set a bilstein 5100s (set at "0") will shore up the ride if you want. Or you can get any set of coilovers to really ride right... look up iamrayzian he's running 3.5" spindles with king coilovers and its awesome for sure
  11. Nov 7, 2010 at 10:48 AM
    #131
    cantac09
    Hugh Jass
    Saskatchewan
    tundra
    stock
    ya man since you're a prerunner just get some 4 inch lift spindle. it will give you more ground clearance than the rcd. and iirc you can buy different shocks and crank them up to give you about 5 inches of lift.
  12. Nov 8, 2010 at 9:58 AM
    #132
    jrobson
    jrobson [OP] Well-Known Member
    Mobile, Alabama
    09 DC 4x4
    Ultimate lift kit, LR UCA's, Bi-xenon 8000K headlights, Xenon 8000K foglites, (4) KC slimlites on N-Fab light bar, Extang trifecta toneau cover
    I guess it's time for me to get some newer pics up here of my truck now too.
  13. Nov 8, 2010 at 11:00 AM
    #133
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    ^yeah wish I would have had my better lens though... those pics are way muted
  14. Nov 8, 2010 at 11:22 AM
    #134
    MY50cal
    MY50cal ---- Tread Lightly ---- Leave No Trace
    Mojo
    Camden County, NC
    09 PM RC / 05 SWB AC (RIP)
    Yep.
    some day...
  15. Nov 9, 2010 at 4:14 PM
    #135
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Hey guys, I know the RCD kit uses blocks to lift the rear. What I'm wondering is that since people sometimes get vibrations using add a leaf, wouldn't the blocks cause the vibration issue also since the driveshaft would be angled more with taller blocks?
  16. Nov 9, 2010 at 4:45 PM
    #136
    757southpaw
    757southpaw Well-Known Member
    Jay
    757
    07' DC LB TRD Sport 4x4
    BAK BakFlip Tonneau cover, 30% front tinted windows, AVS vent shades, Black Billet Grill,Pop& Lock, secondary air filter removed, Goodyear Duratrac's, Billies @ 2.5" on front, Billies on back w/ 1.5" AAL, Toytec Diff drop, NOKYA Hyper Yellow fog light bulbs, LaminX Weathertechs, Rear diff breather mod, BHLM
    I think you've got the nicest DC LB on this site!
  17. Nov 9, 2010 at 5:19 PM
    #137
    cantac09
    Hugh Jass
    Saskatchewan
    tundra
    stock
    i get a little bit of driveline shudder at take off but thats it. i probably wouldnt get the shudder if i didnt have an aal plus the blocks. the kit also some with the carrier bearing spacers so the drive shaft is fairly straight.
  18. Nov 9, 2010 at 5:23 PM
    #138
    ross123
    ross123 Well-Known Member
    fort bragg
    is there any other option for the rear? i don't really like using blocks. other then that i think the kit looks great. and i am really considering it
  19. Nov 9, 2010 at 5:24 PM
    #139
    cantac09
    Hugh Jass
    Saskatchewan
    tundra
    stock
    not from rcd but you could buy a 4 inch leaf pack
  20. Nov 9, 2010 at 5:28 PM
    #140
    ross123
    fort bragg
    i think i would deff get a leaf pack. you know who makes a good one that would work with this lift?
