RCD club, how many are in?
Discussion in 'Suspension' started by jrobson, Jun 15, 2010.
  1. Jan 10, 2015 at 10:22 AM
    #1461
    guitarplayer360
    guitarplayer360 Well-Known Member
    Northern California
    2013 Toyota Tacoma, TRD Off-Road, 4x4
    4" RCD Lift, BFG A/T 285/70r17s, 17X9 KMC HD Addicts
    Just checking in...have had the lift on for about 15 months now with no issues at all. Glad to see others are enjoying it!
  2. Jan 10, 2015 at 5:09 PM
    #1462
    Rustyshackelforde
    Rustyshackelforde Well-Known Member
    Gillette, Wyoming
    05 tacoma sport lifted
    Rcd 4.5 lift, bhlm, blacked out hood scoop, afe cold air, alternating blinker mod, 33inch tires, stealth custom series wheels, bushwacker flares, tjm front bumper
    Has anyone removed their swaybar? Would it be a good idea? Or should I just leave it on? Anyone run aftermarket ome coils with this truck for a heavier plate bumper?
  3. Jan 18, 2015 at 7:56 PM
    #1463
    2011supercoma
    2011supercoma Well-Known Member
    nola
    sr5 4x4, trd supercharged
    trd supercharger, afe cai, doug thorley lt hearders, magnaflow exhaust, rcd 4.5" lift with ome 883 springs, cbi ditch light mounts with rigid industry D2 spot lights,
    Yes remove it, you get used to it but everyone shits themselves except for baby girl in the back seat for some reason. Lol. I'm running one 883 coils and gained ~.75 inch of lift. I did this so I can run on 35x12.5's. When I replace my 35's I may go to 33's and add my plate bumper and winch. I rally want 35's and my bumper but we'll se.
  4. Jan 22, 2015 at 3:54 AM
    #1464
    Tcollins83
    Tcollins83 Well-Known Member
    Trevor
    Ocala,fl
    '13 TRD Off-road dbl cab
    Window tint, k&n filter, painted grill.
    Is your taco still sitting level? Do you mind posting a side profile with this truck and 883?
    Also, how's these lifts coming for everyone? Are there still some major vibe issues or has a solution been found? Thanks for the info. I'm close to pulling the trigger on this lift I just have some hesitation because of the vibe issues. I'm still trying to figure out the wheel setup... Thinking of pro comp 7032 17x8's with 33x12.50 Goodyear fierce. What do y'all think of that setup? Are the rims wide enough for 12.50's?
  5. Jan 22, 2015 at 7:29 AM
    #1465
    wobble
    wobble Well-Known Member
    Ridgefield, WA
    2014 TRD OR
    Modified RCD Lift, 315/70R17 STT Pros
    No major vibes here. Both my girlfriend and I are running RCD lifts with Dakars and 1.5" blocks. Both trucks have very slight shudder around 15mpg. About the same shudder I had on my previous truck running OME 3" lift with AAL. Not enough for me to worry about.
    Some of my jeep buddies run 33x12.50 tires on 8" wheels. It will work fine as long as your backspace is correct. I don't care for the look though. Personal preference...
    I didn't think Fierce Attitude comes in 33x12.50R17. Got a link?
  6. Jan 22, 2015 at 9:49 AM
    #1466
    Tcollins83
    Trevor
    Ocala,fl
    Yea I posted that before I checked. Apparently there's not a lot of options in that size...theres no way to run 16" rims with proper backspacing?
  7. Jan 22, 2015 at 11:47 AM
    #1467
    wobble
    Ridgefield, WA
    2014 TRD OR
    Sorry, I don't know. I haven't tried to fit 16" wheels.
  8. Feb 2, 2015 at 4:02 PM
    #1468
    Tcollins83
    Trevor
    Ocala,fl
    Question about Rcd lift.
    Will 17x9 with 4.75 bs and 33x12.5 cooper stt's Work on the Rcd lift? I know 4.5 is suggested but I am really struggling finding a nice flat black rim in those specs. I'm wanting the 17" pro-comp 7032's on 33x12.5 or 295/70/17 stt's. Does anyone have any experience with running 33x12.5's on this lift? I'm more worried about rubbing on the knuckle then anything..
  9. Feb 2, 2015 at 4:29 PM
    #1469
    wobble
    Ridgefield, WA
    2014 TRD OR
    I'm running 33x12.5's with 17x9, 4.5" BS wheels. I have about 5/8" clearance between the tire and the steering knuckle.
  10. Feb 2, 2015 at 7:55 PM
    #1470
    Tcollins83
    Trevor
    Ocala,fl
    Thanks wobble. So I think I'll be good then.?.. I guess I can always add a same wheel spacer if needed.
  11. Feb 2, 2015 at 7:57 PM
    #1471
    Tcollins83
    Trevor
    Ocala,fl
    You think stock uca's would tighten that gap too much?
  12. Feb 4, 2015 at 3:08 PM
    #1472
    wobble
    Ridgefield, WA
    2014 TRD OR
    I'm not sure. I wasn't running stock UCAs when I put these tires on.
  13. Feb 4, 2015 at 4:12 PM
    #1473
    Negative1
    Negative1 Well-Known Member
    I'm on the same setup and there is no issues whatsoever.
  14. Feb 4, 2015 at 4:54 PM
    #1474
    Tcollins83
    Trevor
    Ocala,fl
    Ok thank you. I'm still debating going with the procomp 7032's (4.75" bs) or finding a rim with a 4.5" bs.
  15. Feb 8, 2015 at 1:39 PM
    #1475
    Tcollins83
    Trevor
    Ocala,fl
    Anyone have problems running 295/70/17's on this Rcd setup?
  16. Feb 17, 2015 at 6:53 PM
    #1476
    Chad7088
    Chad7088 Old Newbie
    Chad
    19th state
    ‘20 Tacoma Off Road DCSB 4x4 MT
    Lots to come
    Not at all....as long as your bs is at least 4.5 in
  17. Feb 19, 2015 at 6:10 PM
    #1477
    Tcollins83
    Trevor
    Ocala,fl
    Thanks Chad. I can not find a rim I really like in 17" w/4.5 bs that's all flat black. I like the procomp 7032 (4.75 bs) and the mc enduro (4.75bs). Will those rims absolutely not work in a 16"?
  18. Feb 20, 2015 at 4:44 PM
    #1478
    Rustyshackelforde
    Gillette, Wyoming
  19. Feb 24, 2015 at 1:58 PM
    #1479
    MKW
    MKW Well-Known Member
    Murrells Inlet, SC
    2014 RC 4x4
    OME 3" lift MK6 wheels 285 Fierce MTs & 4.88s!!
    So, after reading thru a LOT of this thread, I think I've got what I want to do figured out. The truck is a 2015 DCSB Sport 4x4. My plan is a RCD lift with OME 883s to give another 1.5" of lift in the front and custom Alcans out back. I plan to run 17x8.5" wheels with 4.5" of back spacing and 315/70-17 tires.
    Does all this sound OK?? I know there might be slight rubbing, but I'm OK with trimming a little plastic.
  20. Feb 25, 2015 at 8:56 AM
    #1480
    MKW
    Murrells Inlet, SC
    2014 RC 4x4
    Did I post in a dead thread?? LOL
