RCD club, how many are in?
Discussion in 'Suspension' started by jrobson, Jun 15, 2010.
  1. Sep 18, 2015 at 3:20 PM
    #1561
    freedomriding
    freedomriding FREEDOMEDIA
    Nate
    Oahu, Hawaii
    '20 TRDOR w/KDSS
    Eibach 2.0, STT PROs, Summit Dakars, JBA
    Couple from today's drive on the beach with the new KO2's. They do way better in the sand than the KM2's I had on there.
  2. Sep 18, 2015 at 7:13 PM
    #1562
    freedomriding
    Nate
    Oahu, Hawaii
    '20 TRDOR w/KDSS
    The Eibachs some how make it ride even better. It's unreal how solid yet cushy it is.
    2011supercoma and Neutral like this.
  3. Sep 22, 2015 at 9:24 AM
    #1563
    2011supercoma
    2011supercoma Well-Known Member
    nola
    sr5 4x4, trd supercharged
    trd supercharger, afe cai, doug thorley lt hearders, magnaflow exhaust, rcd 4.5" lift with ome 883 springs, cbi ditch light mounts with rigid industry D2 spot lights,
    same with the ome 883s. plus I took the sway bar off which can make it a lil more fun. lol.
    Neutral likes this.
  4. Sep 22, 2015 at 2:15 PM
    #1564
    Neutral
    Neutral Well-Known Member
    Fella
    Alabama
    14 SR5, 25 SR5
    14 4.5" RCD, Pelfreybilt armour, Fox coilovers/shocks, Alcan leaf springs, 4.56 gears, 35's 25 Stock
    I'm looking at getting the Eibachs since it has a little heavier spring rate but I can't seem to find a good deal on them shipping wise. Everywhere I see its like $30-35 for shipping. I don't mind paying the $170Ish but that shipping just seems outrageous, maybe it's just me. If I could find somwhere with cheaper shipping then I'd buy them, any suggestions?
  5. Sep 22, 2015 at 2:47 PM
    #1565
    freedomriding
    Nate
    Oahu, Hawaii
    '20 TRDOR w/KDSS
    Yep the shipping is pricey because they're heavy. Even directly from Toytec was around $60 here to Hawaii.
  6. Sep 22, 2015 at 2:48 PM
    #1566
    freedomriding
    Nate
    Oahu, Hawaii
    '20 TRDOR w/KDSS
    Call Wheelers Offroad and see what they quote
  7. Sep 22, 2015 at 3:07 PM
    #1567
    Neutral
    Fella
    Alabama
    14 SR5, 25 SR5
    Already have, he told me about $35. I may have to get it from Toytec. Theirs was the cheapest IIRC. I'll have to double check though.
  8. Oct 7, 2015 at 6:28 PM
    #1568
    smokeeeyyy
    smokeeeyyy Well-Known Member
    Andrew
    New Roads, LA
    08 4x4 DCSB silver
    4.5" RCD lift 33"Toyo Open Country MT's 18" Fuel Lethal N Fab 3" bars 7" pioneer in-dash radio
    Does any know know if 35" Toyo MT's will fit this lift? I have 33's currently and think they look small. I'm sure there will be trimming, just wondering if anyone has done it before
  9. Oct 7, 2015 at 6:48 PM
    #1569
    Neutral
    Fella
    Alabama
    14 SR5, 25 SR5
    Idk about others running Toyo MT's in 35s but I know one running 35s in a Trail Grappler and another running Dick Cepek's. They both had longer coil springs installed.
  10. Oct 8, 2015 at 1:17 AM
    #1570
    freedomriding
    Nate
    Oahu, Hawaii
    '20 TRDOR w/KDSS
    Really depends on the rim more than anything. I just put the new BFG KO2 34x12.5r18 on 18x10 Moto Metal 970 with 4.5 backspacing and -24 offset and they rubbed like hell. I had to do the body mount chop and cut my Bushwackers big time in the bottom corners. Plus, I have the 1.5" additional lift Eibach coils and 1/4" top plate spacer (driver side only). My previous 17x8.5 Method Wheels with 4.75 back spacing and zero offset with 34x12 KM2's didn't rub at all so you have a comparison.
  11. Oct 8, 2015 at 5:17 AM
    #1571
    smokeeeyyy
    Andrew
    New Roads, LA
    08 4x4 DCSB silver
    I'm running 33x12.5xR18 currently and they rub when I'm backing up to the left without any trimming. If I would have to do that much cutting out the fender, I'd rather not lol
  12. Oct 8, 2015 at 3:21 PM
    #1572
    freedomriding
    Nate
    Oahu, Hawaii
    '20 TRDOR w/KDSS
    Some recents
    TacomaOhio likes this.
  13. Oct 14, 2015 at 10:47 AM
    #1573
    Fincher1
    Fincher1 Well-Known Member
    Oklahoma
    2012 TRD 4x4
    Lifted with big MFing wheels
    are your wheel spacers hub centric or wheel centric. and if so where can i get the 2" wheel spacers that r hub centric.
  14. Oct 14, 2015 at 2:12 PM
    #1574
    rtgreene10
    rtgreene10 Well-Known Member
    Fl cracker
    4x4 turd
    I'm running the eibachs with my steel bumper. I want to say it's an inch lift with the added weight. I had the bumper on with the stock springs too and it's a world of difference with the eibachs. No more nose dive and crazy body roll
    Neutral[QUOTED] likes this.
  15. Oct 14, 2015 at 5:13 PM
    #1575
    Neutral
    Fella
    Alabama
    14 SR5, 25 SR5
    What do you think the total weight of your bumper is?
  16. Oct 15, 2015 at 1:59 PM
    #1576
    rtgreene10
    Fl cracker
    4x4 turd
    They list mine online at 100lbs I think it shipped at like 115 or something though. Either way I'm sure when I add a winch it won't make a difference at all. These springs are stiff enough but still ride well. And cv angles are still fine.
  17. Oct 15, 2015 at 4:41 PM
    #1577
    Neutral
    Fella
    Alabama
    14 SR5, 25 SR5
    Hmm, alright. Mine weighs close to 185lbs so I may end up going with the Eibachs over the OME coils. The OME 883 coils are only like 20lbs "heavier" than stock but the Eibachs are about 50lbs. I appreciate you getting back with me.
  18. Oct 15, 2015 at 4:55 PM
    #1578
    rtgreene10
    Fl cracker
    4x4 turd
    Yeah I talked to Dan at wheelers and he recommended the eibachs over the OMEs in regardes to bumper weight and handling
  19. Oct 17, 2015 at 7:01 AM
    #1579
    Negative1
    Negative1 Well-Known Member
    Does anyone else have an annoying squeak in their passenger side rear whenever the suspension flexes ever so slightly?
    For example, backing into a driveway over a small 1" bump ?
    I'm running Alcan springs in the rear and greased up the plastic pucks between the leafs with no success.
    I also lubricated the RCD shock bushings with no success...
  20. Oct 18, 2015 at 7:52 AM
    #1580
    Fincher1
    Oklahoma
    2012 TRD 4x4
    Mine squeaks from leafs it is very annoying
