RCD club, how many are in?
Discussion in 'Suspension' started by jrobson, Jun 15, 2010.
  1. Mar 2, 2017 at 7:06 AM
    #1681
    Fincher1
    Fincher1 Well-Known Member
    Oklahoma
    2012 TRD 4x4
    Lifted with big MFing wheels
    only thing i have heard is eibach is better all the way around in regards to the 883 or eibach 112-620
  2. Mar 4, 2017 at 10:14 PM
    #1682
    noneck180
    noneck180 Active Member
    Might just have to get them shipped up then ..Thanks .
  3. Mar 8, 2017 at 8:44 PM
    #1683
    SPIN Offroad
    SPIN Offroad Well-Known Member
    SPIN
    Asheville NC
    Black 2014 DCSB TRD Off-Road "TAKEESHA"
    3" toytec suspension lift/1" Toytec body lift, In-channel AVS vent shades, tinted front windows, OEM color matched grill surround, plastidipped front badge & rear bumper, Debadged emblems + All LED interior+vanity& tag lights. Third tail light TRD black matte overlay, Aftermarket 6K HID projector headlights, Smittybilt D-shackle in receiver hitch slot, 17" FUEL Vapor wheels 285/70/17 Nitto Trail Grapplers, Weathertech floorliners w/TRD OFFROAD decals, 3" NFAB textured nerf bars, DEPO black tail lights. black on black perforated leather Clazzio seat covers with custom TRD headrests. TO BE CONTINUED...
    I see a lot of you out there get the RCD lift then try to get more height out of it...Question-Do you wish you had just gotten a 6" lift (6" BDS lift with fox coilovers for example) in first place or nahhh?? I'm asking because I'm not sure If I'd want to go 6 either. I guess i figured if i got RCD lift and wanted, its easier to add a little then be stuck at 6 to begin with-right?
  4. Mar 9, 2017 at 2:27 PM
    #1684
    MKW
    MKW Well-Known Member
    Murrells Inlet, SC
    2014 RC 4x4
    OME 3" lift MK6 wheels 285 Fierce MTs & 4.88s!!
    That's a good question. I'll tell you my thoughts...
    I chose the RCD lift knowing that I wanted more than 4-5". IMO, the best way to get 6-7" of lift is go with a 4-5" DB lift and then get additional lift from spring or coilovers. That way, there are no worries about lack of ground clearance because you will end up with just as much clearance under the DB as a truck with only a spring or coilover 3" lift. My son's truck with RCD and OME 884s has 7.25" of lift and 15" of clearance under the crossmember. Best of both worlds, IMO.
    SPIN Offroad[QUOTED] likes this.
  5. Mar 20, 2017 at 9:51 AM
    #1685
    Fincher1
    Oklahoma
    2012 TRD 4x4
    my truck came with the lift for the price of stock truck so i grabbed it quick....with that being said i wish i had a 6" lift solely due to ground clearance. first lifted truck usually i go the other way lol "low" i dont like the drop bracket as much.
    on another note i just installed my eibach 112-620 springs, new tires, and did alignment. it is a totally different truck in regards to on pavement havent taken offroad. just put on km2 305/17/70 tires. springs should of been beefed up when rcd made lift. no rubbing at full lock left or right and i have stock bumper for the ones that are wondering about springs.
  6. Mar 24, 2017 at 9:57 PM
    #1686
    noneck180
    Do you mean the ride is much better than using the stock coils on the front?
  7. Mar 25, 2017 at 12:22 AM
    #1687
    wobble
    wobble Well-Known Member
    Ridgefield, WA
    2014 TRD OR
    Modified RCD Lift, 315/70R17 STT Pros
    The ride is softer with stock coils than it is with Eibach coils. The Eibach have a higher spring rate.
  8. Mar 25, 2017 at 10:36 AM
    #1688
    noneck180
    Yeah I know the theory, I was just asking what he thought. Lol what I find with the stock springs is when on turning and hitting a bump/ hole. I get some rubbing. So a higher spring weight is what I need I am thinking. I am not sure how you get a 6" lift without a drop bracket and have your cv angles not at 30 degrees. The only thing that gives you ground clearance is bigger tires? No
  9. Mar 25, 2017 at 10:39 AM
    #1689
    wobble
    Ridgefield, WA
    2014 TRD OR
    I'm running eibachs.
    The RCD lift is a drop bracket lift.
    If you are rubbing, trim, CMC, or lift it higher.
  10. Mar 25, 2017 at 9:12 PM
    #1690
    noneck180
    I have had a lot of lifts, Thanks.
  11. Mar 30, 2017 at 10:37 AM
    #1691
    wobble
    Ridgefield, WA
    2014 TRD OR
    If I were to do it again, I'd get a 6" lift to start with, but that's only because I'm running 35s. If I were running 33s, I'd stick with the RCD.
    BTW, Fox no longer makes options for BDS or RCD lifts.
  12. Mar 30, 2017 at 10:45 AM
    #1692
    SPIN Offroad
    SPIN
    Asheville NC
    No MORE FOX OPTIONS! -I'm out!-lol
  13. May 1, 2017 at 12:46 PM
    #1693
    noneck180
    What do you think of 886 coils? Would the ride be way to stiff...
  14. Jul 14, 2017 at 4:18 AM
    #1694
    charlievinyl
    charlievinyl Member
    charlie
    long island
    2015 tacoma dclb trd sport
    Finally got it all installed loving it
    noneck180 and ChadsPride like this.
  15. Jul 21, 2017 at 11:37 PM
    #1695
    noneck180
    Anyone added spacers to their RCD lift to give enough clearance to run 35's?
  16. Jul 22, 2017 at 8:20 AM
    #1696
    MKW
    Murrells Inlet, SC
    2014 RC 4x4
    Tons of folks on this thread run 35s on the RCD lift. There are several different ways to achieve the lift needed. I did it by adding OME 884 coils to the RCD package.
    noneck180 likes this.
  17. Aug 25, 2017 at 10:32 AM
    #1697
    noneck180
    When ever I talk to anyone around here they say you can't stack lifts.
    I am getting really frustrated.. lol
    I just want a couple or 3 more inches..
  18. Aug 25, 2017 at 10:42 AM
    #1698
    wobble
    Ridgefield, WA
    2014 TRD OR
    Use different springs (OME or Eibach)
  19. Aug 25, 2017 at 10:43 AM
    #1699
    noneck180
    That's what I had read.. but 4wd parts here must have the stupidest people working there.
    They told me I have to buy a whole drop bracket lift ..
  20. Aug 25, 2017 at 10:46 AM
    #1700
    wobble
    Ridgefield, WA
    2014 TRD OR
    They just want to sell you a Pro Comp kit.
