Rcd lift kits
Discussion in 'Suspension' started by K1992f, Dec 21, 2010.
  1. Dec 21, 2010 at 1:52 PM
    #41
    Canadianboy
    Canadianboy Taco love in East Van
    James
    Vancouver, BC
    09 TRD Sport S/B 4x4 Auto in Mag Grey
    Icon Stage 3, Goodyear Duratracs and KMC Addicts!
    OP check out an Icon stage 3 lift. This will get you up to 3" of lift and will ride great. Icon has quality components and a lot of the guys with Tacoma run them.
    http://www.outlawoffroad.com/23784/72/223/3772/2009_TOYOTA_TACOMA_4.0_V6_GAS.html
    Or you could get a stage 2, and get some cheaper UCAs to use with the lift. This would be a quality, solid lift.
    Either that, or the Toytec lift you are looking at would also be good.
    Good luck.
  2. Dec 21, 2010 at 1:54 PM
    #42
    Canadianboy
    James
    Vancouver, BC
    I wonder how the RCD would ride and perform, compared to the Icon stage 3 that I have. Can anybody compare?
    I was thinking about going a bit higher, so RCD is an option.
  3. Dec 21, 2010 at 1:56 PM
    #43
    K1992f
    K1992f [OP] Well-Known Member
    Kanon
    Dirty Hanover pa ...
    2012 tacoma TRD sport fully loaded
    6" fabteck 20" fuel hostage 33" nitto MTs
    Ok well I have to make a choice by tomorrow .. The ultimate kit 3" or the icon 3" that toytec haves the ultimate is about 1,114 and the icon kit is 1,400 so witch one guys ......
  4. Dec 21, 2010 at 1:57 PM
    #44
    jr114
    jr114 Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    Ill second that. I ran the procomp 3" strut and coil spring lift prior to my Icons. Wouldnt wish that on anyone.
  5. Dec 21, 2010 at 1:58 PM
    #45
    jr114
    Jon
    SoCal
    Truck
    look at this instead as an alternative to the the ULK
  6. Dec 21, 2010 at 2:02 PM
    #46
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    Get this
    Also do you have a AC or a double cab? Get the 885s for the DC and the top spacers in the kit to make it a 3"
  7. Dec 21, 2010 at 2:13 PM
    #47
    K1992f
    Kanon
    Ok I don't see a stage 2 or 3 on the icons only see stage 1 on toytec website .. That ome suspension by toytec for $699 will that full kit get me my 3" with hole kit or am I missing something it says something about plates
  8. Dec 21, 2010 at 2:18 PM
    #48
    K1992f
    Kanon
    I have a double cab 09 trd sport
  9. Dec 21, 2010 at 2:30 PM
    #49
    Sprink669
    Sprink669 Well-Known Member
    I have the OME kit with 886's and the Dakar rear leafs. It rides stiff but not too stiff. The roads here in Ohio are horrible and the truck takes them and doesn't miss a beat. I got the 886 springs because I have a ARB bumper and M8000 winch. I would imagine that the 885 springs are softer.
  10. Dec 21, 2010 at 4:14 PM
    #50
    jrobson
    jrobson Well-Known Member
    Mobile, Alabama
    09 DC 4x4
    Ultimate lift kit, LR UCA's, Bi-xenon 8000K headlights, Xenon 8000K foglites, (4) KC slimlites on N-Fab light bar, Extang trifecta toneau cover
    I had the Ultimate kit and once I adjusted the CO's it threw off my CV angles and started blowing CV boots. Not to mention the stiff ride and the fact that I can't stand even the slightest ammount of wheel rub. Thats why I went the RCD route.
  11. Dec 21, 2010 at 5:04 PM
    #51
    K1992f
    Kanon
    Ok I never thought this would be so hard. All I want is 3" lift kit Complete kit I have about a price range around 1,000 to 1,200 to spend I'm not going to be doing any off roading just a norm everyday drive to work and to the mall etc just lookn for a aggsive look ... Ok with being said the OME toytec start price at 699 it don't tell me that really gives me a 3" lift ??? But it dose say something about plates for the maximum 3" lift if I bought that lift kit is there something else I need to buy to get the 3" lift ... Sorry I'm dumb when it come to this stuff that's why I'm askn for help ... So just make it simple for me or tell what lift to buy at that price range .... Or is the toytec ultimate the beat rout for me .. Thanks
  12. Dec 21, 2010 at 5:38 PM
    #52
    GreatBasinTaco
    GreatBasinTaco Well-Known Member
    Reno, NV
    2020 Tundra DC
    Lots of stuff
    the ome kit with 885 springs will give you about 2 1/2 to 2 3/4 if you have no extra front end weight. you can add the top plate spacer for a full 3 inches, but you can avoid aftermarket uca and get proper alignment at 2 1/2. you will still be able to fit the tire package with minor trimming.
  13. Dec 21, 2010 at 5:47 PM
    #53
    K1992f
    Kanon
    What do u mean by UCA ??
  14. Dec 21, 2010 at 6:03 PM
    #54
    GreatBasinTaco
    Reno, NV
    2020 Tundra DC
    Lots of stuff
    upper control arms
  15. Dec 21, 2010 at 9:30 PM
    #55
    jr114
    Jon
    SoCal
    Truck
    OP your best bet is most likely the OME kit. Has everything your looking for all in one package. I posted a link a few posts up. Check it out.
  16. Dec 22, 2010 at 8:40 AM
    #56
    sandjunkie
    sandjunkie Well-Known Member
    Aaron
    OC
    RCD FTW
    Closest ride to stock. No CV issues. Plenty strong for the occasional off roader. Same Price as a 3 inch coilover and UCA lift (maybe cheaper than some).
  17. Dec 22, 2010 at 10:17 PM
    #57
    cantac09
    cantac09 Official TW Igloo Builder
    Hugh Jass
    Saskatchewan
    tundra
    stock
    ^^^^ what he said
  18. Dec 22, 2010 at 10:28 PM
    #58
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    4.5" RCD is what I recommend... jrobson knows what he's talking about... he had the ULK and had some problems then went with the RCD.
    I had a mix 3" lift and the ride was rough... plus my 28/70/17 tires rubbed like crazy...
    now with the RCD I have 305/65/17 tires and have no problems
  19. Dec 22, 2010 at 11:01 PM
    #59
    surfrat
    surfrat Well-Known Member
    LI, NY
    icon coilover, total chaos UCA, allpr expo, icon 2.0 rear,wet okole
    any of you guys take this lift on the beach? wondering how it rides on it..and im not talking about the beaches that you take 2wd trucks on either [​IMG]
    My truck is on the beach everyday..nearly 100 miles a week sometimes on it. Just wondering if i should go with this RCD kit or the OME. I had remote resi Icons on my FJ prior to the taco..but i felt they where overkill
  20. Dec 23, 2010 at 6:44 AM
    #60
    allrsdup
    allrsdup Well-Known Member
    Sahuarita AZ.
    2018 dcsb trd offroad 4x4 Inferno
    honestly. go with a drop bracket kit. the rcd 4.5" or procomp or fabtech 6". it will save u cv axles and ball joints down the road. i have had a few trucks all with drop bracket lifts and the ride is awesome on them.
