RCD Lift Pics an Review
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kdawwwg, Oct 17, 2010.
  1. Oct 17, 2010 at 11:53 AM
    Kdawwwg
    Kdawwwg [OP] Well-Known Member
    Ken
    Draper,Utah
    2010 Magnetic Grey DC Long Bed TRD Sport 4x4
    RCD 4.5" Lift ,Moded to 5.5",1.5 inch Toytec AAL Light Raceing UCA's, 285/70/17 Duratracks, Procomp 7028 Wheels 17X8.5x4.75, Leer XQ Shell,Keyless Entry,Bedrug, Kartec Front End Limiting Straps.
    Very stout kit,Heavy duty spindles, 1/4 inch thick drop brackets,nice polished stainless steel lateral struts
    i was able to easily remount front skid plate
    the ride is wayyyy better then the 3 inch spacer lift i had, an i would have to say it rides better then stock,RCD did a great job on these shocks
    now the 4 in block in back works, no Axel wrap,or vibes,but not the best way to go,I'm looking into a 6 in spring for the back
    this kit can easily be made into a 6+ kit , i add 5/8 spacer [little over 1 inch of lift ]on driver, an a 3/8 spacer on passenger [about 5/8 lift][taco lean]
    i went from siting at 38 1/2 inches with 3inch kit, to 42 1/2 inches with the modded rcd kit, now i don't under stand how i gained 4inches when i only lifted around 2 inches more over, my 3inch kit:?[ same tires] ,but all take it :D
    pic 1 shows the add spacer
    pic 2 ground clearance under drop bracket
    pic 3 drop bracket cut, chrome lateral struts
  2. Oct 17, 2010 at 11:55 AM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    Looks awesome! :thumbsup:
  3. Oct 17, 2010 at 12:00 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Badass! Definitely the route I will go when I finally get the money to fix my broken ass suspension.
  4. Oct 17, 2010 at 12:01 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    looks good man!
  5. Oct 17, 2010 at 1:01 PM
    toku58
    toku58 Well-Known Member
    On a Rock in the middle of the Pacific
    Mall Crawler!
    21' TRD OffRoad 2" 887 OME on Bilstein 5100's. 285/70R17 General Grabbers G3 17x8.5" Icon TRD wheels (Gun metal gray) 4.75" BS
    The reason is that you need to get your alignment done again. Your tires went from: |---| to \---/ so the tilt of the tire riding on it's outer edge is what is giving you the added lift.;)
    Been there done that!LOL!
    Good Luck!
  6. Oct 17, 2010 at 1:02 PM
    RelentlessFab
    Eric
    Sparks, NV
    bet you're right.
    If the truck drives forward the front lifts, so drive straight back for 20 feet and re-measure....:cool:
  7. Oct 17, 2010 at 1:19 PM
    sandjunkie
    sandjunkie Well-Known Member
    Aaron
    OC
    Awesome!! Mine goes under the knife a week from Monday for the same kit. What size tire are you running?
  8. Oct 17, 2010 at 2:25 PM
    Kdawwwg
    Ken
    Draper,Utah
    must be the pic view,cause it was realigned in front of me an it is at 0 toe ,0 camber, 2.6 caster on driver,2.8 caster on passenger.
    new pics in gallery you will see there is no \---/ only |---| :)
    added new pic just for toku :D dead level
  9. Oct 17, 2010 at 2:31 PM
    Kdawwwg
    Ken
    Draper,Utah
    285/70/17 duratracks ,best tire out there[imho]
  10. Oct 17, 2010 at 2:39 PM
    surfrat
    surfrat Well-Known Member
    LI, NY
    icon coilover, total chaos UCA, allpr expo, icon 2.0 rear,wet okole
    that looks awesome man!
  11. Oct 17, 2010 at 2:53 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    Welcome to the club!
    on a side note: double check you steering knuckle and tie rod end rubber boot ensure they are not rubbing
  12. Oct 17, 2010 at 3:21 PM
    Kdawwwg
    Ken
    Draper,Utah
    even with the bigger rim 17/8.5 wit 4.75 backspacing, Ive got a 1/2 inch clear, not rubbing anywhere, an did some hard 4x4ing last night,with 7 people an about 200lbs of paragliding gear, ran that suspension through the gauntlet
  13. Oct 17, 2010 at 3:25 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    ^the steering knuckle has a sharp little lip on it (on the spindle) the tie rod end has a rubber boot, if you spindle was like mine and sharp then it will cut thru the rubber boot on you tie rod end....
    look where you tie rods connect to the spindle
    nothing to do with wheels.
    My spindle might have been a defect from RCD or the tie rod was a defect from toyota who knows, but the little rubber boot rubs on the steering knuckle which just so happened to be sharp and cut that boot right open
    I have since fixed this but I had to get new tie rod ends and had to grind down the sharp part on the knuckle
  14. Oct 17, 2010 at 3:31 PM
    Kdawwwg
    Ken
    Draper,Utah
    i will reinspect, i do see that lip, i will call rcd an let them know, an pop my tie rod an grind that spot before i cut a boot,thanks
  15. Oct 17, 2010 at 5:52 PM
    allrsdup
    allrsdup Well-Known Member
    Sahuarita AZ.
    2018 dcsb trd offroad 4x4 Inferno
    looks awesome u have a pic of front cv angles?
  16. Oct 17, 2010 at 6:19 PM
    Kdawwwg
    Ken
    Draper,Utah
    Yes, in my gallery,very minimal angle :)
  17. Oct 17, 2010 at 6:41 PM
    allrsdup
    Sahuarita AZ.
    yea i just saw them. looks awesome i like it a lot nice job.
  18. Oct 18, 2010 at 10:26 AM
    cantac09
    cantac09 Official TW Igloo Builder
    Hugh Jass
    Saskatchewan
    tundra
    stock
    you have a great lift and tire combo. probably the best you can buy.
  19. Oct 18, 2010 at 10:28 AM
    cantac09
    Hugh Jass
    Saskatchewan
    tundra
    stock
    great choice man. you'll love it!
  20. Oct 18, 2010 at 10:34 AM
    rob1
    rob1 Well-Known Member
    Robert
    South Texas
    Indigo Blue DblCab 4X4 Long Bed TRD Sport SR5
    Tail gate mod, locking gas cap, locking spare tire, rear spring tsb,Weathertech Digital fit's
    Very Nice!! If you don't mind how much and from where did you order/install??
