RCD Lift - Rear Bilstein Shock Leaking
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wobble, Apr 21, 2015.
  1. Apr 21, 2015 at 1:05 PM
    wobble
    wobble [OP] Well-Known Member
    Ridgefield, WA
    2014 TRD OR
    Modified RCD Lift, 315/70R17 STT Pros
    I installed an RCD 5" lift a year ago. It came with Bilstein shocks. Now one of my rear shocks is leaking fluid. The same thing happened to the 5100s I had on my previous truck. I ended up replacing those with OME 60091 and liked the ride quality and had no problems with them. Unfortunately I don't think those would be long enough for my current rear lift, which is around 4.25" over stock. Does anyone have suggestions for replacement shocks without spending a fortune?
  2. Apr 25, 2015 at 5:02 PM
    freedomriding
    freedomriding FREEDOMEDIA
    Nate
    Oahu, Hawaii
    '20 TRDOR w/KDSS
    Eibach 2.0, STT PROs, Summit Dakars, JBA
    From that Bilstein link, 5100 series only has a 90 day warranty!? I was under the impression that they're lifetime? Call RCD and see if they'll swap it.
  3. Apr 25, 2015 at 5:55 PM
    Brjw
    Brjw Well-Known Member
    Brian
    Forest Grove, Oregon
    That's what bilsteins do. My jeep sat for two weeks and I came home to a puddle of shock oil from the front driver's side. It had literally just sat still in the driveway. Lol
    It was part of an AEV lift and they did send a warranty replacement.
  4. Apr 26, 2015 at 11:48 AM
    wobble
    Ridgefield, WA
    2014 TRD OR
    Since this is the third Bilstein shock that has done this to me in the past few years, I'd rather replace them with another brand. The lack of quality is apparent.
    I didn't want to spend a bunch of money, but I may have to get ICON or Fox. I think they both have options for the RCD lift. I don't know of any others. I've only owned Bilstein and OME, so I don't know much about other brands.
  5. Apr 26, 2015 at 11:46 PM
    freedomriding
    Nate
    Oahu, Hawaii
    '20 TRDOR w/KDSS
    3! I've been under the impression Bilstein was the best shock available!? I installed my lift back in Dec, guess I'll see how mine hold up over time:mudding:
  6. Apr 26, 2015 at 11:50 PM
    phillstill
    phillstill Long hair don't care
    Phill
    Tulsa
    LT35TANK
    Everything
    Wheelers off-road sells an Icon extended version rear shock for 4-5 inches of lift.
  7. Apr 27, 2015 at 7:18 AM
    wobble
    Ridgefield, WA
    2014 TRD OR
    The two rear shocks (5100s) lasted about two years on my previous Tacoma. This one lasted a year. I probably flex my truck more than most though.
    I was happier with the ride quality OME gave over Bilstein on my previous Tacoma. I think these Bilstein shocks are overrated.
    I didn't see any on their website, but will give them a call. Thanks!
