Rcd lift ??
Discussion in 'North East' started by K1992f, Jan 2, 2011.
  1. Jan 2, 2011 at 7:13 AM
    K1992f
    K1992f [OP] Well-Known Member
    Kanon
    Dirty Hanover pa ...
    2012 tacoma TRD sport fully loaded
    6" fabteck 20" fuel hostage 33" nitto MTs
    I'm new to all this stuff ... I have a 09 Tacoma trd sport double cab .. Will the rcd lift fit my truck ... If so is there any other parts I have to buy for this lift or dose this kit come with everything I need ??? I live in the gettyburge pa area if any close people around with experience one lifting trucks thanks
  2. Jan 2, 2011 at 7:26 AM
    98tacoma27
    Ben
    Not Beech Creek
  3. Jan 2, 2011 at 7:32 AM
    K1992f
    Kanon
    Ok what lift should I go with ... I don't no anything about this stuff I get this forum and I get no help at all . I'm not looking to be out off rd or anything like that just want a nice lookn truck ... What lift kit should I buy that will come with everything I need to lift my truck . 3" is what I'm lookn or that rcd lift size .. I don't want 6" so any help would be good ..
  4. Jan 2, 2011 at 8:00 AM
    98tacoma27
    Ben
    Not Beech Creek
    This is a good buy and will do what you ask. It retains the stock struts.
  5. Jan 2, 2011 at 8:23 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    If you are a 4wd and want more than 3" of lift, RCD is the way to go no doubt. I know plenty of people who run offroad with drop bracket lifts and do great. If you are a prerunner, go for a set of camburg spindles instead
  6. Jan 2, 2011 at 8:33 AM
    98tacoma27
    Ben
    Not Beech Creek
    DB's suck for off road. You don't gain ground clearance unless you put 35" on and you still run the risk off smacking the DB on a rock.
  7. Jan 2, 2011 at 8:42 AM
    memario1214
    Colton
    Missoula, MT
    And you don't gain ground clearance with a suspension lift either unless you get bigger tires. Don't tell members (aka Krookz) with db lifts that they can't wheel... every single time you wheel ever anywhere, you run the risk of hooking up on Something out there...
  8. Jan 2, 2011 at 8:48 AM
    98tacoma27
    Ben
    Not Beech Creek
    Of course the whole point of lifting is to gain room for larger tires. And I never said that they can't wheel DB. I said they suck for wheeling. I never mention anything about Stan. And I guess you were there when he almost ran a member over because his DB was stuck against a rock. I wasn't but I saw the footage. I did watch three Tacoma's , two with suspension lifts and one with a db. The two suspension lifts made it, but the DB hung up on.....guess what......the DB.
  9. Jan 2, 2011 at 8:50 AM
    98tacoma27
    Ben
    Not Beech Creek
    Speak of the devil. Meet the guy that hit his DB. Sup Kohler.
  10. Jan 2, 2011 at 9:55 AM
    memario1214
    Colton
    Missoula, MT
    Okay, there is no denying the fact that suspension lifts are superior as far as offroad applications go. And for the record I really don't want to get into a pissing match with you because that isn't what this is about... for many people, I would say the majority drive their trucks like a truck about once a month when they wheel. For these people a db lift is more than suitable because they can stuff larger tires and reach a little more places than they could before. Day to day they are still able to drive their truck like normal and get the near stock ride as well.
  11. Jan 2, 2011 at 9:56 AM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    If you don't offroad much the RCD would probably be a better ride. If you offroad a few times a month I would stay away from a DB lift. RCD makes quality stuff from what I've seen though. :thumbsup:
  12. Jan 2, 2011 at 9:57 AM
    98tacoma27
    Ben
    Not Beech Creek
    And for day to day, a DB is overkill and not cost affective. Bottom line, it's his truck and money.
  13. Jan 2, 2011 at 10:06 AM
    TRDKenE
    TRDKenE DAMN GOOD DEAL!!
    Kenny
    Richmond, Virginia
    '10 D-CAB OFF-ROAD 4X4
    TRD CAI, GrillCraft.
    Either one is good. It just depends on your budget and your needs, Look through the suspension forums a lot of discussion on a lot of different setups.
  14. Jan 2, 2011 at 11:17 AM
    jrobson
    jrobson Well-Known Member
    Mobile, Alabama
    09 DC 4x4
    Ultimate lift kit, LR UCA's, Bi-xenon 8000K headlights, Xenon 8000K foglites, (4) KC slimlites on N-Fab light bar, Extang trifecta toneau cover
    Very happy after I switched my Toytec kit out for the RCD. Money well spent.
  15. Jan 2, 2011 at 11:35 AM
    JoeTacoma02
    JoeTacoma02 Well-Known Member
    Obviously he doesn't want a 6" guys and he doesn't offroad. So in another word, he is a mall crawler. That being said go with toytec and save yourself the $$. Get their 3" spacer up front and their 3" block for the rear springs :)
  16. Jan 2, 2011 at 11:42 AM
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    If I could start over I would get an RCD lift instead of my 885 coils and 1/2" spacer to save wear and tear on my front differential and safely get a little more lift
  17. Jan 2, 2011 at 11:44 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    3" spacers will ride like shit on and off road. 3" block will lead to axle wrap. Poor choice.
    If you are on budget, I would recommend either Bilstein 5100 shocks or OME shocks and springs up front, and an add-a-leaf for the rear.
  18. Jan 2, 2011 at 11:47 AM
    JoeTacoma02
    Yeah but he clearly states he does not offroad and just wants something to look "nice" and i agree with the 3" blocks..bad choice but cheaper than AAL
  19. Jan 2, 2011 at 11:48 AM
    TexasTacoma37
    You can get an add a leaf for under $100 from wheelers, toytec, etc. The axle wrap is an on-road issue, not an off-road one.
  20. Jan 2, 2011 at 12:21 PM
    K1992f
    Kanon
    Yes I really don't off rd .. And won't I'm not to kill my truck I'm just lookn for looks :) .. I was thing the rcd lift with the xd monster wheels tire size 33/12.5/20 would that work nice on this lift .. That's the look I'm lookn for ... I no the lift is high on price ... I was lookn at the toytec ultamate kit 3" but I guess that tire won't fit that lift ??? Like said I'm just lookn for you guys to help ... Is there anybody around here from gettyburg pa area ??? That I could talk to ???
