RCI 16-23 Tacoma Pike Series Front Bumper
Discussion in 'Armor' started by RCI-Offroad, Feb 2, 2024.
  1. Apr 14, 2024 at 9:14 PM
    #41
    SconnieTaco60
    SconnieTaco60 Well-Known Member
    2021 Tacoma TRD Off Road
    Stock
    Is anyone that installed the front center Pike Bumper planning on adding wings???
    jmferg likes this.
  2. May 11, 2024 at 7:17 PM
    #42
    jmferg
    jmferg Well-Known Member
    I'd love to see more pictures of the wings aside from RCI's stock photo
  3. May 12, 2024 at 11:01 AM
    #43
    kbarakeh
    kbarakeh Active Member
    Khalid
    2017 Tacoma TRD Pro
    Fitment of the bumper is spot on, however there is one major design flaw that I noticed. The face of the light bar cut out angled pretty low to the ground and doesn’t give you enough room to adjust your light bar much higher without cutting off the top portion of the light beam. Also the center “RCI” cut out does block the whole center section of my DD stage series light bar. A fix for this would be to slot out the light bar mounting brackets to allow the light bar to sit lower in the cut out when angling it higher.
    jmferg, Fullsendcf and pp2small like this.
  4. May 12, 2024 at 7:53 PM
    #44
    pp2small
    pp2small Well-Known Member
    Brian
    Socal
    2022 TRD Offroad
    Looks great! I have the exact same light bar on my bumper and have the exact same issue as you. To get the light beam to point at a reasonable angle (not too high, not too low), I had to position the light bar pointed up which makes the lightbar look uncentered in the cutout. Also the bottom of the lightbar is hitting the RCI logo, preventing me from angling the light bar any higher.
  5. May 12, 2024 at 10:06 PM
    #45
    kbarakeh
    Khalid
    2017 Tacoma TRD Pro
    Yep my exact same issues. Not sure if it was designed on one that was lifted 3” in the front or what lol. You literally can’t even see the beam if you have the light bar centered and flush with the cut out.
  6. Jul 15, 2024 at 7:14 AM
    #46
    INTERRUPTOR22
    INTERRUPTOR22 Well-Known Member
    Port Hueneme, CA
    2017 tacoma TRD off road 4x4 Magnetic Grey
    BakFlip tonneau cover. Rexing front and rear dash camera. Leather seat covers Dessert Does it seat jackers TRD Pro Front grille OTT ECU 285/70/R17 Falken Wildpeaks AT3W. Methods 703 Bronze 0 offset Fox 2.5 with Remote Resi with DSC adjusters front and rear ICON Tubular UCA Cab mount chopped Superbump bumpstops with Ubolt Flip kit Meso customs interior black out kit with LED white/red map light and dome light and TRD shift knob with hidden buttons Kustom 45 headlights with rgb halo ring.
    Wondering about the short loop diameter. Looking to use the loop as a way to mount some twin KC Hilites slimlite 8" spot lights.
  7. Nov 7, 2024 at 12:55 PM
    #47
    SconnieTaco60
    Stock
    Can someone post a link to a good install video(s) for both the Pike Front Bumper and the Wings that go with it???
  8. Nov 13, 2024 at 8:24 AM
    #48
    SconnieTaco60
    Stock
    Did RCI (or has anyone else) come up with a fix the front lightbar slot alignment issue?
  9. Nov 13, 2024 at 8:34 AM
    #49
    SconnieTaco60
    Stock
    I've seen a few posts with guys encountering alignment issues (saying that the slot angle is too low) with their front lightbar in this Pike Bumper. Did you run into any issues with the lightbar cutout slot and not being able to properly align your lightbar? I have a 30" Morimoto lightbar that I'd really like to use in this bumper, provided that I can align it correctly to see down the road.
  10. Nov 13, 2024 at 8:42 AM
    #50
    SconnieTaco60
    Stock
    Correction my lightbar is a Diode Dynamics 30" SS30 with driving LED lights.
  11. Feb 27, 2025 at 6:53 PM
    #51
    jmferg
    Saw this posted on facebook.
    481276311_10232765208891508_685145543947_1777aab8ba725629394000c63bafcff75ce3ac55.jpg
    hoodwinked likes this.
  12. Feb 27, 2025 at 7:08 PM
    #52
    hoodwinked
    hoodwinked Well-Known Member
    Looks sweet. I like the metal ears, making into a "full front bumper" kind of look. I wonder if those would fit my C4 LoPro bumper.
  13. Feb 27, 2025 at 7:37 PM
    #53
    SconnieTaco60
    Stock
    I ended up not getting the wings and instead went with a modest Viper Cut to compliment my Pike center bumper
    Snuffleupagus and jmferg like this.
  14. Feb 27, 2025 at 7:52 PM
    #54
    hoodwinked
    that viper cut looks good, you got any side profile pics? I am aiming to do mine kind of like yours.
    jmferg likes this.
