RCI A-arm skid Plus Marlin LCA Frame Brace?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by GawainXR, May 14, 2025.
  1. May 14, 2025 at 11:51 AM
    GawainXR
    GawainXR [OP] Well-Known Member
    William
    2020 TRD Off-Road
    DashCam
    Does anyone currently have this combo, what sort of cutting and modification did you have to do?
    I ordered Marlin's LCA Frame brace primarily because I had an issue with alignment techs rotating the cam bolt upside down, leaving it vulnerable or even flattening the ridges of the LCA's mounting bracket.
    I currently have the RCI A-Arm skids that I would like to keep but but can visually see where they might collide with the LCA Brace's skid.
    I'm guessing at the very least I'll need to grind the cam guard tab off, which is fine and am guessing I'll need to cut off 1/2 or so of material so that it doesn't collide with the LCA brace at full droop.
    Once they arrive, prior to having a shop install them, I'm planning to dry fit the LCA frame brackets with the truck at full droop to see how much material I'll likely need to remove from the RCI skid.
  2. May 15, 2025 at 6:59 AM
    Dorf510
    Dorf510 Well-Known Member
    Tyler
    Vista, CA
    18 TRD 4x4
    Dayton wires, flux-capacitor, port-a-potty
    I had to trim my skids(full belly RCI) to fit the Marlin kit, idk about LCA skids as i do not run them(what’s the point of them?)
    TacoTrigger16 likes this.
