RCI Group Buy Spring 2018 ***CLOSED***
Discussion in 'Automotive Group Buys' started by mstudt, Mar 29, 2018.
  1. May 1, 2018 at 8:22 PM
    #221
    Lord Humongous
    Lord Humongous The Ayatolah Of RockNRolla
    AZ
    Inferno 3rd gen trd offroad 4x4
    https://www.tacomaworld.com/threads/lord-humongous-gigahorse-build.436524/
    It's the Southern Style Offroad hybrid bumper. No trouble st all with the install. These plates are so beefy they actually replace the 2 front bumper supports.
    COSD[QUOTED] likes this.
  2. May 2, 2018 at 7:46 AM
    #222
    JAL
    JAL Well-Known Member
    Mississippi
    96 Tacoma Access Cab (sold) now 2018 Tacoma DCSB 4X4 OR (traded). Current 2022 TRD DCSB OR Celestial Silver
    RCI Sliders and mostly stock.
    Thanks for the pic’s Solo! I ordered the 5* without the top plate though. My thinking is I’m the one using the truck 90% of the time and the outer bar is enough for me.
    You see any issues with a short female using just the bar to step up?
    Plan is to put anti-skid tape in the step area.
  3. May 2, 2018 at 8:20 AM
    #223
    Daria
    Daria Can I pet your dog? Moderator
    Dodging tumbleweeds
    I’d advise against anti skid tape. As a female, I did this with my Tacoma. Ended up scraping the hell out of my legs(used to wear skirts to work daily). Literally walked into work bleeding one day. Depends on how your woman gets out of the truck. My legs rub/slides against the sliders when I jump out.
    m603holden likes this.
  4. May 2, 2018 at 1:27 PM
    #224
    mstudt
    mstudt [OP] Well-Known Member
    Eugene, Oregon
    Today is the last day to use the codes in the first. Use them while you can.
  5. May 2, 2018 at 2:29 PM
    #225
    COSD
    COSD Well-Known Member
    Denver Metro
    2017 MGM DCSB OR
    Thanks for the response! And the truck looks good!
  6. May 2, 2018 at 2:29 PM
    #226
    Lord Humongous
    AZ
    Thanks man!
  7. May 3, 2018 at 8:18 AM
    #227
    JAL
    Mississippi
    Thanks Darla! I assume you’re are the 5* ones also?
    A since I’m not getting a top plate would it really matter the lower 5* over the standard 20*?
  8. May 3, 2018 at 4:09 PM
    #228
    GeneralGadsen
    GeneralGadsen Well-Known Member
    Grant
    High Point, NC
    2017 LEASED AND MODDED!
    BodyArmor Front Bump Engo Winch Rigid Lights RCI Skids/Sliders
    Damn ya'll got shipment notifications already?
  9. May 3, 2018 at 4:14 PM
    #229
    16Tacos
    16Tacos Well-Known Member
    Zach
    Boston
    08 Access Cab 4x4 V6 SR5
    OME Nitrochargers w/886s & Dakars, ARB Deluxe Bull Bar w/Warn winch, RCI sliders with kick out, IFS & Mid skids, BFF Hi-clearance rear bumper, Brushed Copper 17" SCS Ray10s w/285-70 KO2s, Black OEM 16" steelies w/255-85 KM2s, Leer contractor cap w/Smittybilt overlander xl RTT, Off-Grid Engineering dual battery kit and bed power panel, Blue sea aux fuse block, Wyntner 60L fridge freezer, ARB dual compressor, Pioneer 720BT head unit, CB radio, @Matt_Gecko bed and engine bay lights, @TacomaTruckParts Dirt bike tie down bar, color matched OEM grill, A-Pillar phone mount mod, @Docloco rear seat molle panel
    Just gives you a great opportunity to open the door, help her up, and look like a gentleman :thumbsup:
  10. May 3, 2018 at 4:27 PM
    #230
    MurderedTacoV2
    MurderedTacoV2 Booty Admirer
    Adam
    Hudson, New Hampshire
    06 Taco TRD OR
    3 inch lift, B110’s, Dakars, Dirty5’s, Dual Locked
    Mine will be here on the 8th. Depends what you bought.
  11. May 3, 2018 at 4:36 PM
    #231
    Marbleyard
    Marbleyard Thread killer
    Virginia
    2019 4Runner Pro
    SOLD 2016 taco: premium technology and tow package. OV Tune 1.05; A.R.E. V Camper Shell; BRO grille & Tails; OEM bed mat; Xenon Depot HID headlight conversion; reflective gray tailgate letter inserts; GoPro session; Hondo radio knobs; K&N cold air intake, quicksand painted dash bezels, Subaru dash speakers, Kicker CS 6x9 fronts and 6.5 rear speakers; All LED interior lights and LED high-beam headlights. Redline elite hood shock props. prinsu cab and camper rack with rough country 30" light bar; (2) 8" rear facing “F.U.”rough country black LED lights; prinsu cargo basket kit, (2) prinsu load racks; roadshower 4; ARB 2500 awning and room kit; weather tech floor mats; carhart seat covers; ckma12 ARB air compressor under the hood; blue ridge overland gear air tools bag, tool bag, driver's seat molle. Rack mounted TRED 800 recovery treds and plano case. Rotopax water and fuelpax fuel canisters; Pelican cased first aid kit in bed. rockblokz mud flaps. ARB rear dif. breather. Stand alone fuse block. SSO bumper with 10k smittybilt synthetic line winch and factor55 ultrahook. Pro Eagle 2-Ton “The Beast” jack. OME lift kit: 90000 front shocks and 886 OME coils, Camburg 310078 UCA, 60091 rear shocks with light duty Dakar leafs. Good Year duratracs 285/75R16. Black vinyl inlays on factory OR wheels; RCI Steel Front/Trans/Trans Case/Rear Diff Skids, Alum A-Arm; Mobtown bolt-on sliders with scorpion bed coating; pelfreybilt aluminum fuel tank skid; Cali-Raised full length Molle storage LH & RH bed sides; Caliraised bedside reinforcements; HELLA sharptone horns; Optima blue-top battery with AJT machined red tiedown bracket. AJT quicksand key fob. Overland Bound member #6996
    Completed my armor today thanks to the group buy, al I needed was the a-arms to finish it all off. All RCI except the alum. fuel skid. Super pleased with RCI! Worked with no problems with my SSO front bumper, Mobtown bolt-on sliders and pelfreybilt fuel skid.
  12. May 3, 2018 at 6:12 PM
    #232
    Daria
    Dodging tumbleweeds
    I had a different brand of sliders. Mine were 15 degrees.
  13. May 3, 2018 at 7:32 PM
    #233
    JAL
    Mississippi
    Thanks
  14. May 4, 2018 at 2:18 PM
    #234
    GeneralGadsen
    Grant
    High Point, NC
    I order two skids for my 3rd Gen. A Transfer and a Transmission.
  15. May 4, 2018 at 7:22 PM
    #235
    17tacostormtrooper
    17tacostormtrooper They call me bacon!!
    Zach
    Pike county Ga
    2017 TRD DCLB/2000 ext cab trd
    Stage 2 icon lift 285/55r20 toyo rt tires Fuel maverick 20x9 wheels Window tint Vent shades LED interior lights Led reverse light Night light rear led standalone reverse lights Smitty built drivers side mole gear seat cover Husky floor mats Truxedo bed cover Factory roof rack Custom grill
    Got my a arm skids!!!! Thanks guys for the group buy!!!:spending::fingerscrossed: Maybe another once I get my money built back up! Time to start in my 3rd gen!!!!!
  16. May 5, 2018 at 2:33 PM
    #236
    The_Black_Pearl
    The_Black_Pearl IG: the_black_pearl_tacoma
    Colorado Springs, CO
    2013 All Black Tacoma Double Cab Long Bed
    I may have missed this but I’m #10 on the list and haven’t placed my order yet. Am I still able to purchase?
  17. May 5, 2018 at 3:20 PM
    #237
    MurderedTacoV2
    Adam
    06 Taco TRD OR
    Negative, missed out buddy.
  18. May 6, 2018 at 11:45 AM
    #238
    mstudt
    Eugene, Oregon
    No. Everybody on the list was notified that codes were active.
  19. May 9, 2018 at 8:40 AM
    #239
    GreenNoob
    GreenNoob Active Member
    2018 Tacoma TRD Off Road Access Cab
    Ceramic Pro
    I still haven't gotten any shipping notice. Ordered full set of skids
  20. May 9, 2018 at 8:58 AM
    #240
    RPS1030
    RPS1030 Well-Known Member
    Leadtime on the T4R skid set was listed at 1-3 weeks, so I've got most of another week to wait maybe.
