RCI Metalworks Tacoma rear bumper / no-cut version. Bravo to RCI!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Stocklocker, Jan 1, 2019.
  1. Sep 13, 2019 at 10:08 PM
    #161
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Not the greatest lighting, but those chain hoops are horizontal there just under the license plate. Very strong and up out of the way. It's a great bumper (although I've considered selling mine to go for a lightweight tube look) :anonymous:
  2. Sep 13, 2019 at 10:43 PM
    #162
    Stocklocker
    Stocklocker [OP] Well-Known Member
    17TRDORDCSBAT
    Thanks for posting that up. It’s raining where I live and I was procrastinating about crawling under the truck to snap a photo.
  3. Sep 13, 2019 at 10:51 PM
    #163
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Wish it would rain here. The clouds keep teasing, and then it gets hot again.
    Note: I've towed 6000lbs on this RCI bumper just fine. If anyone was wondering about that aspect of it
  4. Sep 13, 2019 at 11:15 PM
    #164
    Stocklocker
    17TRDORDCSBAT
    Yeah....I’m not a big fan of hot and dry. I keep wondering when the weathermen and weatherwomen will stop referring to sunny days as “good weather”, and rainy days as “a turn for the worse”. The planet could use more rainy cool days. That’s the actual good weather.
    CygnusX191[QUOTED] likes this.
  5. Sep 13, 2019 at 11:17 PM
    #165
    wessyder
    wessyder Enlightened OR Bro who don't need no skewp
    2019 Tacoma TRD OR, basically an off road race truck
    Tied several boat anchors to my truck to destroy MPG.
    Thanks guys!
    CygnusX191 and Stocklocker[OP] like this.
  6. Sep 17, 2019 at 11:53 PM
    #166
    HighCountryTacoma
    HighCountryTacoma Well-Known Member
    Colorado
    2017 DCSB TRD Off Road Quicksand
    Any word as to weather or not this is compatible with a 255/85 r16 tire in stock spare location, or what modifications are necessary to make it fit?
    Also how hard is it to wire the Rigid lights? I'm not real electrically inclined.
    CygnusX191 likes this.
  7. Sep 18, 2019 at 1:13 AM
    #167
    Gregw138
    Gregw138 Well-Known Member
    Greg
    NY
    2019 TRD Off Road DCSB 2016 Lexus ES350 2009 Lexus ES350
    WAY TOO MANY
    You may need to take a 1/2” off the hitch receiver. It’s only 5 minutes work with an angle grinder and a little touch up paint. As for the lights it depends on how you want to hook them up. You can tie in to reverse lights or have it on its own designated circuit with a separate switch ?
  8. Nov 6, 2019 at 2:27 PM
    #168
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Props to RCI. Their sliders saved my bacon today
  9. Nov 6, 2019 at 2:52 PM
    #169
    basshole
    basshole Well-Known Member
    chicagoland
    2018 OR MT
    What happened? Is that a nice dent in the kick out?
  10. Nov 6, 2019 at 3:34 PM
    #170
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Weird reflection due to rain.
    Hard to see, rear passenger tire is flat (screw embedded in the tread)
  11. Nov 6, 2019 at 3:55 PM
    #171
    basshole
    chicagoland
    2018 OR MT
    Ha! Well super easy way to plug a tire that's for sure. I haven't lifted my truck by my RCI sliders yet.
    Maybe over the winter I'll cave in and buy this rci rear bumper. Still drooling over it.. Getting tired of busted up rear plastic chrome crap that I've taken off multiple times to paint and install reverse pods in. Every time I take it apart another clip breaks
  12. Nov 6, 2019 at 4:02 PM
    #172
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Dude the RCI bumper is 110% worth it. There's a post/pic a few pages back of me using it to tow a 3rd gen Ford Explorer. Beast of a bumper, and HUGE bang for buck. Easy install too.
    Edit: Dear @RCI, the screws for the cover plates for the reverse lights could be higher quality, ie something that wont rust. Doesn't affect the bumper negatively in anyway, just saying.
    basshole[QUOTED] likes this.
  13. Nov 6, 2019 at 4:06 PM
    #173
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Wiring up the lights is super easy. The most difficult aspect is routing the wiring into the cab. There is an existing firewall plug near the brake booster that you can use to get from the engine bay to the cab. All you'll need to do is remove the plug (route the wire through the rubber grommet) and poke a hole in the carpet pad (behind the dash) with an awl. The other entrance is under the drivers seat. While under the truck, locate the floor plug and pull that out to route the wiring from under the truck, up through the hole (under the carpet), continue the wire to the door sill and then take it up through the drivers kick panel.
    Buy this kit for the wiring. Has everything you need, accept wire taps.
    https://www.amazon.com/gp/product/B00PACD2D0/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
    I placed the switch inside my cubby pocket. See post #123...
    https://www.tacomaworld.com/threads...ot-high-clearance.590385/page-7#post-21339869
    Good luck!
  14. Nov 6, 2019 at 4:09 PM
    #174
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    FYI to all owners or potential owners. I hated the flip up plate, so I switched it out with two of these...
    https://www.ebay.com/itm/FLEX-O-MAG...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
    I hated the flip up plate, because if it's in the up position and you lower the tailgate, you'll potentially fuck up your tailgate. Also, if you're towing and the plate is in the up position, it's almost impossible to read. With these magnetic brackets, you can stick the plate to anything that is metal. Lastly, you don't need to drill holes for the plate.
    trlfrk likes this.
  15. Nov 6, 2019 at 4:56 PM
    #175
    basshole
    chicagoland
    2018 OR MT
    Bummer to hear you don't like the flip up plate. I figured it would lay on a decent angle with a drop hitch, I guess I didn't look at pics closely.
  16. Nov 6, 2019 at 9:40 PM
    #176
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    It's actually pretty easy to read, even in the "up" position. No need to drill it super low on the bumper. Also it's nowhere near the tailgate, so not really sure what @Bertw192 is on about :notsure:
  17. Nov 6, 2019 at 10:15 PM
    #177
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    I actually had my plate contact my tailgate when I lowered it. Fuck up on my part, but it happened none the less.
    Not only that, but I hated having to hold the plate up when connecting my trailer. See the photo below, I'm not towing with a ball.
    mtip and Stocklocker[OP] like this.
  18. Nov 7, 2019 at 4:05 AM
    #178
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Fancy off road hitch there. Looks cool.
    Almost thought you had a Pyrite Mica 3rd gen there for a second
  19. Nov 8, 2019 at 6:59 PM
    #179
    Stocklocker
    17TRDORDCSBAT
    Your matchy-matchy trailer wheels made my night brother. All hail!
    :bowdown:
    Once I finish my 6X6 mod I’ll be right there with you.
  20. Nov 27, 2019 at 2:41 PM
    #180
    funkeedingus
    funkeedingus Well-Known Member
    Has anyone asked RCI if they sell a version without the light cutouts? I don't want the lights and I think the plate looks.. off.
    savethewheels and CygnusX191 like this.
