RCI mid-height bed rack + awning mount + 270 awning
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JakeDoubleU, Aug 26, 2021.
  1. Aug 26, 2021 at 4:44 PM
    JakeDoubleU
    JakeDoubleU [OP] New Member
    Jacob
    2014 silver Tacoma TRD Off-Road
    Front Runner roof rack Toytec 2.5 lift Falken WildPeak AT3 SwitchPros Cali Raised Ditch lights KC HiLites Cyclone rock lights OEM Audio WeBoost OTR
    Has anyone tried the above combination ? I’ve already got the mid-height rack and am wondering if I use the RCI awning mounts with a 270 awning, will it be tall enough to clear the rear door and also just be tall enough to stand under in general ?
  2. Aug 26, 2021 at 5:00 PM
    Dank Donkeh Luvver
    Dank Donkeh Luvver Well-Known Member
    Eric
    Maryland
    2020 TRD OR White 6MT
    OVTune/Coyoza, Eibach Pro Lift, Mobtown Sliders/Skid, Softopper, Martin Offroad Rack
    I am not sure, but for reference, the Peregrine 270 awning is 88" (7'4") when stowed, which means you'll have a lot of overhang.
    JakeDoubleU[OP] likes this.
  3. Aug 26, 2021 at 5:34 PM
    shaggy135
    shaggy135 Well-Known Member
    Valley of the Sun, AZ
    2019 Barcelona Red TRD 4x4 OR DCSB MT
    I've got the KB Voodoo mid height rack on tonneau brackets. Had to make my own awning brackets though. These are repurposed countertop brackets, ha. Originally went with 12" brackets (which I need to sell now) but my awning is too thick and my rear door kept rubbing on it. So I swapped them out for 14" ones. All good now but I haven't taken any good pics yet. Overland Vehicle Systems 270 awning.
    Here's the 12" ones:
  4. Apr 3, 2022 at 7:50 PM
    EdsNotHere
    EdsNotHere Well-Known Member
    2011 Pre-Runner Double Cab
    is that the max modular awning mount and then you just modified with some additional steel and welded?
  5. Apr 4, 2022 at 7:59 AM
    shaggy135
    You are correct. Awning mount on the outside and then some countertop support brackets on the inside. Nothing is welded though, it's all bolted together.
    These countertop brackets: https://www.amazon.com/gp/product/B00S5HP49C?ie=UTF8&th=1
    Here's the video where I learned about the setup. Basically used this guy's awning mount as a template. Around the 5:30 mark.
    AJ4mPR and Milkman6V7 like this.
  6. Apr 4, 2022 at 8:17 AM
    Jpmurph
    Jpmurph Well-Known Member
    17 DCLB TRDOR
    The RCI awning brackets folded under the weight of the OVS 270 so I built my own. I was surprised there was not more off the shelf options.
    20211009_093229.jpg 20211009_100535.jpg 20211009_105926.jpg Screenshot_20220404-080818_Gallery.jpg
    codyjphoto likes this.
  7. May 5, 2022 at 6:13 PM
    Milkman6V7
    Milkman6V7 Member
    22 TRD Offroad 6V7
    6 inch RC lift 35s RC intake Stubby front bumper 10k winch Some lights Hooke roof rack Pending.... 5.29s Supercharger Full satin clear wrap
    Thanks Shaggy! Welding up some for my rig tomorrow.
  8. May 5, 2022 at 6:21 PM
    EdsNotHere
    D65C1264-3D82-4AA1-B0E4-97015C88C9D0.jpgMy solution.
  9. Jul 30, 2022 at 5:44 PM
    Malirris
    Malirris New Member
    Love the solutions here, hoping to figure out something easy and cheap for myself. Would adding a 3" spacer be an option under the OVS supplied bracket? Or would this cause load issues? Trying to keep cost to low, but I really need to raise this at least 3-4 inches in order to clear the rear door.
  10. May 30, 2023 at 8:43 PM
    Vega89xi
    Vega89xi Active Member
    Joe
    Nashville Area
    2021 Lunar Rock TRD Pro
    A little here... A little there...
    Bringing this back from the dead. Trying to solve the same issue with KBV mid height rack and an OVS 270LT. Have KBV extended mounts but you can't bolt the 270 to it because of the design of the mounts. Ordered some 15" counter brackets to mod the mounts with and clear the door. Any other cool things out there? Seems pretty difficult to find out of the box solutions to this.
  11. Jun 25, 2023 at 11:03 PM
    51Beets
    51Beets Well-Known Member
    2020 TRD Offroad
    Too much to list
    Did this work for you? I'm running a high Cali Raised rack (17.5in) but need to raise it probably 2-3 inches for it to clear as well.
  12. Oct 24, 2023 at 3:23 PM
    pinnacle.auto
    pinnacle.auto New Member
    Here’s what I did after looking at this thread. 30ish dollar piece of metal from Home Depot, a cut off wheel and a drill and some paint. Holds pretty firm. It’s worth mentioning the factory brackets did not mount easy to cali raised bed rack. Had to do a lot of drilling and some wonky mounting but it works. Must be a proprietary design.
