RCI skid install help please
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hinmo24t, Mar 14, 2025.
  1. Mar 14, 2025 at 7:44 AM
    hinmo24t
    hinmo24t [OP] MAhole
    tom
    dartmouth, ma
    2015 TRD OR , blue ribbon metallic
    pia, prob my fault
    but got 1/4 alum full skids RCI
    tried getting engine and tran done last night, only got engine skid
    because transmission forward i was able to sandwich nicely, with rubber spacer correctly,
    but then the rearward transmission skid wouldnt line up with crossmember for thru bolts
    and the half moon plate above. i dont have the brackets to remove on the crossmember
    QUESTION: do these skid like being adjusted forward or rearward?
    i tightened fronts per install video, and wondering if i need to loosen and play with front orientation, + maybe push forward sandwich section together more
    any advice appreciated
    thanks
