Re: 2009 brake issue?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Geode, Oct 28, 2010.
  1. Oct 28, 2010 at 12:15 PM
    Geode
    Geode [OP] Well-Known Member
    Illinois
    09 4WD TRD
    Just recently I started hearing a buzzing sound when I apply my brakes. There's a canister under the hood that moves visibly when the brakes are applied, not sure if this is the source of the noise?
    I'm hoping someone can help me out here, I'm not sure what the part is and if anyone has experienced this issue?
    I've posted a video on you tube to show what is happening
    http://www.youtube.com/watch?v=U1yfwMX0RhM
    Brakes seem to work fine, for what that's worth.
    Thanks
  2. Oct 28, 2010 at 12:19 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    You brake booster is probably shot. Relatively cheap and easy to replace as long as you can access the nuts under the dash where it's bolted through the firewall. :)
  3. Oct 28, 2010 at 12:21 PM
    mjp2
    NJ
    I just realized that you've got a 2009. If you're still under warranty have the dealership handle it on their dime. Definitely not something that should fail that quickly.
  4. Oct 28, 2010 at 12:26 PM
    Geode
    Illinois
    09 4WD TRD
    Thanks for the reply, I'm still under warranty so I'll take it in :)
  5. Oct 28, 2010 at 12:34 PM
    mjp2
    NJ
    No problem, and please let us know how it turns out. :)
  6. Oct 28, 2010 at 12:56 PM
    Geode
    Illinois
    09 4WD TRD
    Will do, was quietly hoping my truck would never see the dealer........I bought new in September of 09', have about 8,700 easy miles on it. I've done a few oil changes, including the differentials etc, rotated the tires etc. Like to do stuff myself when possible. The tutorials and member knowledge here are great, I hope to be able to contribute in the future.
    peace
  7. Nov 1, 2010 at 8:48 AM
    Geode
    Illinois
    09 4WD TRD
    Just got a call from the dealer, they said the noise is from the electric motor assisting the brake booster and that it's normal. Not sure why it all of a sudden got so loud. Not sure I agree, but they are the experts.
  8. Nov 1, 2010 at 8:53 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I would check with another dealer, or call Toyotya CS.
  9. Nov 1, 2010 at 9:01 AM
    Geode
    Illinois
    09 4WD TRD
    Thanks Chris. Sounds like I should take this issue pretty seriously?
    I was hoping my local dealer would take care of things :(
  10. Nov 1, 2010 at 9:02 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Well......I would. Brakes are a safety device. Tell you r dealer, that if its so "normal", have them fire up a new truck, and let you hear its brakes.
  11. Nov 1, 2010 at 9:05 AM
    Geode
    Illinois
    09 4WD TRD
    Good advice, thanks. I was hoping for a frustration free experience.
  12. Nov 1, 2010 at 9:13 AM
    excalis
    excalis Well-Known Member
    TRD Off Road 4x4
    Good luck with the dealer trying other trucks, I had mine try two Tacomas similar to mine and none made the noise mine did but they still called it normal.
    I just contacted Toyota's main customer support line and they provided me with a reference number and let me know that if my A/C compressor (which was causing the noise) failed after warranty that they would fix it.
    We will see what happens. I hope you get this matter resolved in your favor. :)
  13. Nov 1, 2010 at 9:39 AM
    Geode
    Illinois
    09 4WD TRD
    I'll try another dealer, seems to me that if they think it is all good, that complaining won't help. I don't want to make an issue of it, if it is "normal".
    I've got 2 years left on my warranty, and can't help wondering if I should find a good local shop and pay for any work I might need in the future. May end up costing less in the long run.
    I'm not particularly good with confrontations (really bad). If the service adviser says it is all good, and I say I don't think so well then things could/would go downhill fast......
  14. Nov 1, 2010 at 9:54 AM
    Geode
    Illinois
    09 4WD TRD
  15. Nov 1, 2010 at 12:49 PM
    excalis
    TRD Off Road 4x4
    Keep us posted, I have an '09 also, so if I experience the same thing I will know what to do. :)
  16. Nov 1, 2010 at 12:56 PM
    mnudo200827
    mnudo200827 Well-Known Member
    Michael
    Corona, CA
    2005 Tacoma Double Cab Prerunner
    Icon Coilovers, All-Pro UCA's, All Pro 3" Leaf Springs, Rear Fox Adjustable Shocks, Stainless Steel Brake lines, 17" KMC Addicts wrapped in 305/65/17 KM2's, Kenwood DDX 512 stereo, 2 12" Polk Audio MM1240 subs in custom enclosure, 4 component speakers, Wet Okole Seat Covers
    i dont think its normal, mine doesnt make that noise but mine is an 05, but i am sure all the brake components are the same. You should definetly get to the bottom of what ever it is and get it fixed. You dont want your rakes to fail at any time.
  17. Nov 1, 2010 at 1:54 PM
    Geode
    Illinois
    09 4WD TRD
    Yeah I'll keep after it and keep you posted.
    Picking it up this afternoon, will discuss it more with the service department. I have a distant friend who worked as a professional mechanic at Toyota for twenty years, I'll be picking him up a case of his favorite brew for his opinion. He still has some pull at my dealership.
    No doubt there is something wrong, to bad the dealer thinks I have nothing better to do with my time than bother them with some weird noise........
    I appreciate all the comments.....
  18. Nov 2, 2010 at 6:48 PM
    Geode
    Illinois
    09 4WD TRD
    So Monday evening I picked up my truck from the dealer. The service writer said the sound was normal, and it was weird because he didn't respond to any of my questions, just looked blankly at me about my concerns....
    So I said fuck it, I'm good for a fight but will pick a spot another time.
    Today I left work at lunch to drive around, get some gas. As I drove around, I began to realize that this noise was really not normal, and that the dealer was full of shit (surprise).
    Decided to check my oil while I was filling up, and took a real close look at the master cylinder/brake booster. Something looked out of place, and I ended up pulling out a walnut which was jammed between the hydraulic motor and the inside fender well. It was stuck good, but I got it out.......It was all I could do not to get in my truck and try it out. Had to pay for the gas first. And yeah this totally fixed the issue.......Unreal, I'm so relieved, and can't stop chuckling........A fucking walnut, r u kidding me? Squirrel I'm guessing.
    The dealer receipt said the noise was normal, and had a sticker which said Toyota would contact me to see how satisfied I was with the service they did. They cut the pedal (fine by me), re-flashed the trans for the brake over ride and spent ten minutes explaining that terrible noise I was hearing was normal...........
    Anyway, thanks, it is all good :) I whish I took a picture, but didn't think to and phone camera doesn't work. I may take it back to the dealer and re install walnut, then tell them to make sure the walnuts don't fall out of any of the other Taco's.......
  19. Nov 2, 2010 at 6:55 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You should call the Manager, and tell them what the issue was. If the techs cant even diagnose a safety issue correctly, find another dealer to work with.
  20. Nov 2, 2010 at 8:48 PM
    Geode
    Illinois
    09 4WD TRD
    Thanks Chris,
    I just got back from meeting with my friend who had been a toyota mechanic for 20 years. He told me the same thing, I'll be talking with the service manager tomorrow. And looking for another dealer as well.
    You're spot on, Thanks.
