Re: 2010 tsb
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tyboxr, Sep 16, 2009.
  1. Sep 16, 2009 at 1:15 PM
    tyboxr
    tyboxr [OP] Member
    2010 Sport, V6, 6sp, Mag Gry
    So all this talk about the rear springs has made me paranoid about the real springs on my 2010 DC Sport. I have three leaves with the lowest being about twice as thick as the upper two. I also have the sticker on the door but it states that the modifications have changed the capacity from "0" to "0"? So I am guessing that the thickened third leaf was the fix? Or was it always that way? Any TSB survivors out there?
  2. Sep 16, 2009 at 1:29 PM
    BSP4x4
    BSP4x4 Guest
    Sounds like you have the regular crappy 3 leaf pack that they for some reason conitnue to use...check the part numbers against the TSB!
  3. Sep 16, 2009 at 1:49 PM
    brandob9
    brandob9 Well-Known Member
    Brandon
    Portland, OR
    09 DC Long Bed
    Soundproofed cab, beeps purged, bed lights, extra bed tie-downs and TSB springs.
    Those springs are fine as long as you use your truck like an SUV or sedan. There is nothing to be paranoid about. It just happens that when you load in more than 500 lbs in the back with the 3-pack, things get squishy.
    Meanwhile, the 4-leaf pack will make it ride like a truck when empty, and comfortable with at least 200 lbs in back.
  4. Sep 16, 2009 at 1:54 PM
    tyboxr
    tyboxr [OP] Member
    previous current
    48210-04550 48210-04570 Spring Assembly Rear , RH Leaf Spring 1
    48220-04190 48220-04210 Spring Assembly Rear, LH Leaf Spring
    are these the correct parts numbers in question?
