Re-gear manual 1st gen?
Discussion in '1st Gen. Tacomas (1995-2004)' started by TRDtaco99, Oct 10, 2020.
  1. Oct 10, 2020 at 8:21 AM
    TRDtaco99
    TRDtaco99 [OP] Active Member
    1999 TRD tacoma 4WD 5spd
    I know there are tons of these threads but I'm having trouble finding them for 1st gens...
    Should you re-gear for 285/75r16s or 33s? I have 4.10s stock w/e-locker and manual transmission with 3.4 5vz-fe, currently running 32s. I was thinking of 4.56 but I've heard that's overkill for the highway. Any input would help
  2. Oct 10, 2020 at 8:54 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Hard to say but you can mess around with this:
    http://www.grimmjeeper.com/gears.html
    Ultimately it’s down to your preferences - do you want low end pull or lower highway rpms. Some people that don’t drive on long interstate trips don’t mind going overgeared since they only hit 60-70 mph briefly. Others doing almost all of their driving on highway or that have to drive 200 miles to get to their off roading destinations will opt for longer (smaller ratio) gearing.
    Wyoming09 and TRDtaco99[OP] like this.
  3. Oct 10, 2020 at 12:28 PM
    QMEDJoe
    QMEDJoe Proverbs 3:5-6
    Joe
    Columbus Grove, Ohio
    2003 Tacoma, V6, 5 speed, 4x4.
    Fox 2.0 Coilovers in the front and Fox 2.0’s in the rear, Total Chaos UCA’s, Al-lpro expo leafs, K&N cold air intake, TRD headers,Magnaflow catback exhaust,URD short throw shifter, switched out my 60/40 bench seat for some Tacoma Limited seats, Replaced the vinyl shift boot for a leather one, completely soundproofed the cab w/ Frost King. Replaced stock radio with a Pioneer AVH series head unit. Focal component system w/a 10" sub powered by 2 Alpine amps. Weathertech floor mats. Line-X'd the bed. SCS Ray 10’s, Installed an A.R.E. MX series camper shell. All-Pro Apex front bumper w/ All-Pro skid plates all the way back to the Trans. Low Range fuel skid plate.
    I’m in the same boat. I have the same setup (minus the e-locker) I have read a few threads that say 4.56’s are the way to go on 33’s but have also heard guys say that 4.88’s is a sweet spot with 33’s. I travel to much and from what I’ve read the RPM’s will be too high with 4.88’s so 4.56’s is what I’m going with.
    TRDtaco99[OP] likes this.
  4. Oct 10, 2020 at 12:32 PM
    silas144144
    silas144144 Active Member
    sd
    03 taco 4x4
    I have 4.56 gears in my 2003 manual trans. I'm very happy with the performance.
    TRDtaco99[OP], QMEDJoe and Dalandser like this.
  5. Oct 12, 2020 at 7:11 AM
    TRDtaco99
    What would you say your rpms are at around 60mph?
  6. Oct 12, 2020 at 7:19 AM
    2004Taco
    2004Taco Financially Irresponsible
    Lou
    California
    04 Double Cab PreRunner SR5 TRD
    I regeared with 4.88's on 35's. For the longest time, I was driving around with my stock 4.10's on 32.8 and it was fine. I wouldn't regear until you decide to go up to 35+.
    with that said, if you're on the fence I would call the guys at Nitro Gear. They're very helpful.
    TRDtaco99[QUOTED][OP] likes this.
  7. Oct 12, 2020 at 11:41 AM
    silas144144
    sd
    03 taco 4x4
    Not sure about the RPMs at 60 mph. On the freeway, I hit 3000 RPMs at about 78 mph. I don't know if that speedometer reading is correct with the larger tires.
  8. Feb 14, 2021 at 12:45 PM
    TaCody96
    TaCody96 Member
    1996 Tacoma extended cab 3.4l 4wd
    What size tire?
  9. Feb 14, 2021 at 12:59 PM
    silas144144
    sd
    03 taco 4x4
    285/75 R16
  10. Feb 14, 2021 at 1:28 PM
    Chugiak76
    Chugiak76 Well-Known Member
    Colorado Springs, Colorado
    2020 Tacoma SR 2.7 4x2, AXC
    It'll be a tad sluggish, but you'll be just fine. With 285/75/16 (32.8") tires, and 4.10 gears, you'd be at 2111 rpm at 60 mph in 5th. Divide your mph by 0.028422 to get your rpm for your desired cruise speed in 5th, and 0.023819 for 4th gear.
    I wouldn't bother regearing until you went to 35+
    Before that it wouldn't be worth the cost or trouble in my opinion, but if you did switch to 4.56, you'd be looking at 2345rpm at 60mph (divide mph by 0.025584 for 5th, 0.02144 for 4th)
  11. Feb 14, 2021 at 1:56 PM
    Poncate
    Poncate Well-Known Member
    PNW
    04 DCSB 4x4
    I’ve got the same question but for an auto. I’ve read 4.56 for manual and 4.88 for auto. Thinking the jump from 4.10 to 4.88 is fairly substantial and should bring back some pep. Manual should be similar with 4.56
  12. Feb 14, 2021 at 2:16 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    Running at 3k to 3500rpm on the Freeway is not going to harm an engine . Sure you're going to a drop In mpg but it's going to be minimal
    For a regear you've got (3) options
    Option #1 Regear for better fuel economy , calculate rpm 200-300rpm lower than stock gearing
    Option #2 Regear to bring the RPM's back to stock ( with larger tires this regear option makes the truck feel like it did with oem size tires )
    Option#3 Performance regear ..... bring the rpm up to 3k at cruise rpm . This will allow off the line throttle response and better gearing in low range . Calculate rpm about 300 to 500rpm above option #2
  13. Feb 14, 2021 at 2:26 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
  14. Feb 14, 2021 at 2:47 PM
    willie64
    willie64 Willie64
    willie64
    BEND OR
    (slowly becoming less than) Stock '03 3.4L 4x4 TRD SR5
    144 watt led lights on front 36 watts x2 led on the back, cb, Kenwood ham, icon 3" lift, 285/75/16 Fierce Attitude tires, JoeZilla sliders, 4x innovation rear bumper, ARB front bumper. Snorkel. On the workbench: more stuff I can't afford.
    I'd been on 33's for several years (automatic) with the stock 4.10's and it was ok but sluggish. I regeared to 4.88 about 4yrs ago. For the driving I do, mostly around town and excursions, this appears to be a good combo. I rarely do any highway miles and there is nothing close to an interstate hwy system near me. MPG: actually it's about the same as when I was at 4.10 with 33's. Not overly great. I think i wore out the engine and tranny a little after all the hard use before going to 4.88. I've heard about people going straight to 5.29 aaaaaand loving it. I doubt they do ANY hwy miles. Absolutely no gear searching at all. If I were to tow anything on a regular basis I would go with 5.29.
    Digiratus and Poncate[QUOTED] like this.
  15. Feb 14, 2021 at 6:41 PM
    TaCody96
    TaCody96 Member
    Having a hard time deciding between 4.56 and 4.88.. leaning toward 4.56...
    96 Taco 4x4 3.4L 5sp manual
    Just moved up to 285/70/17 (~32.8x11.25) that I got from a deal on Craigslist. It added a bunch of weight, not only with the bigger tires, but also with the 1.5” spidertrax spacers at 6lbs each needed to make the 2nd gen wheels fit. Eventually I plan to get new alloy wheels with the proper backspacing to drop some weight, but right now it feel like I traded my 3.4 for a 2.7.
    Currently running 4.10s. I don’t plan on going any bigger than 33s as this truck is my DD. I have a Jeep that I’m working on making my wheeler... I know, I know.. Jeeps
    I log a lot of highway miles.. spend a fair amount of time at 80mph.
    Any help/advice is greatly appreciated
  16. Feb 14, 2021 at 10:02 PM
    silas144144
    sd
    03 taco 4x4
    4.56
  17. Feb 15, 2021 at 9:10 AM
    Poncate
    PNW
    04 DCSB 4x4
    Thanks! Do think with the 4.88 you’d be over geared if you were on the interstate a lot? I rarely go over 65 and cary a bit of weight when heading out. Kind of sounds like there’s some benefit to going the 5.29 route.
  18. Feb 16, 2021 at 9:37 AM
    willie64
    willie64 Willie64
    willie64
    BEND OR
    I guess it comes down to personal preference on your daily driver. I too carry a lot of weight when I go out. Id love to get a larger gastank. Since I've relocated my spare I've been thinking about doing a 30 gal GM swap to that area. I've read some interesting posts about that.
    I've been pretty happy at 4.88 on my automatic.
    Poncate[QUOTED] and Dalandser like this.
  19. Feb 16, 2021 at 11:31 AM
    TaCody96
    TaCody96 Member
    After looking into regearing it sounds like it’s going to run ~$3k. Has anyone taken other routes to gain back power after increasing tire size?
  20. Feb 16, 2021 at 11:41 AM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    If you get a used set of gears out of another tacoma you'll save a poop ton of money
