Re gear maybe?
Discussion in '4 Cylinder' started by AlexA, May 24, 2010.
  1. May 24, 2010 at 7:00 PM
    AlexA
    AlexA [OP] Well-Known Member
    Alex
    Newport News, VA
    2012 DCSB Prerunner SR5
    Put new 30'' tires on my stock '10 2wd tacoma. Was looking into a regear to regain the stock performance. What gear comes stock in the automatic 2wd 4 cyl trucks and what would be the best gear to regear to? thanks for any help! love this forum!:cool:
  2. May 24, 2010 at 7:06 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    If you have a five lug then you should have 3.58 gears with the automatic. Unless you want to go up to 4.56, which would probably be way too low, the other options are to find a used set of 3.73 (from a 6cyl) or 4.10 (from a 4 cyl) from a 6 lug taco. I'm not sure if there are other options for correcting the speedo, but there is the Dakota Digital (corrects the speedo) or something like a Scangauge (external gauge). I have no experience with the Dakota Digital, but I have a ScanguageII which works well, but your odometer and speedo will still show the wrong values.
  3. May 24, 2010 at 7:10 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
  4. May 24, 2010 at 7:21 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    A regear is not called for here. I went from a 29" tire to a 33"
  5. May 25, 2010 at 12:46 AM
    Kelson
    Kelson My Truck is Cuter than Yours
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    you are talking about 6 lug trucks. It would be impossible for him to have a 6 lug truck because the 2TR-FE is not available with the automatic transmission on a 6 lug truck, the 5 speed is the only option on the PreRunners and 4X4s with the 2TR-FE (the four cyl)
    5 lugs come with stock 215/70/15R which is a 26.9" tire. i have 29" tires right now and i do notice a loss in performance, but I do have the 5 speed transmission that has 3.31 gears. I know i need to regear, but with the auto's higher final drive ratio, the need to re-gear is less, but depending on your use may or may not be applicable.
  6. May 25, 2010 at 12:46 AM
    Kelson
    Kelson
    Honolulu, Hawaii
    oh yah and the autos are much easier to re-gear than the 5 speeds, so if you do decide to re-gear, your in luck!
  7. May 25, 2010 at 2:03 AM
    AlexA
    Alex
    Newport News, VA
    thanks for all of the help everybody! so if i do regear is 4.10 the best option for me to regear to?
  8. May 25, 2010 at 6:31 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    Of course he will notice a difference, I do also but I promise my tire change is much more invasive than his, my tires are very heavy. His stock gear of 3.58 with his new 30" tall tires feels like he has some 3.21 gears. Basically your stock manual truck. If he regears to the 4.10 with is 30" tall tires his gearing will drive like some 3.67 gears. A bit more than stock. If he has the money than go for it but in my opinion it isn't necessary. If you do regear I think 4.10 will be fine, in the end its your call.
    Your truck with your new 29" tires feels so different because of your original high gear set. It feels like you are driving around with a 3.07 gear set. I have a question though why is it easier to regear an auto than a standard? What changes in the rear? I've never heard of this before and have swaped many rear ends with no reguard to the trans.
  9. May 25, 2010 at 6:37 AM
    BigBawlzTaco
    BigBawlzTaco Wanna know how I got these scars?
    Forsyth,Georgia
    Chevy Avalanche
    Straight piped.
    You should be fine.
  10. May 25, 2010 at 7:38 AM
    afd23a
    The Dynamo of Dixie
    You might also give it a couple of tankfuls of gas and see how it drives then. The computer seems to take about that long to adjust to changes.
  11. May 25, 2010 at 8:18 AM
    NakedTacoma
    NakedTacoma Well-Known Member
    West Covina
    Mid travel front Long travel rear
    You do NOT need to regear
    CLOSE THIS THREAD BEFOR IT GETS TO 20 PAGES OF CONFUSION lol
    also i drive a base 5 speed with 33 and i have 4.10s.....you def dont need 4.10s
  12. May 25, 2010 at 11:07 AM
    Cappy Cap
    Cappy Cap Well-Known Member
    Boston
    08 Reg. Cab
    K & N Intake, Alpine S-10 Shallow Mount Sub, Alpine CDA-9884 H/U, Alpine Type-R Components, Alpine Amp, 3.73 rear end, Welded on Muffler, Bug Deflector, Rain Guards, LCE Short Shifter,
    its ur truck man do what you want. It all depends on your driving habits too, i have the base 5 lug with 3.31's and when i went to the 235/75/15 i DID notice a difference especially on the highway, so instead of killing my engine i regeared to a 3.73 i got from a prerunner rear end. you may be ok with your 3.58's but like i said its totally up to you, if YOU feel a difference than do what you think is right. With a topic like this it can get out of hand very fast lol, so play with calculators and allow your engine to readjust then go from there. Unfortunatley your spedo is F*ed for life lol, mines off when im at 85 on the speedo im really around 75, just need to remeber that its screwed up.
  13. May 25, 2010 at 12:07 PM
    AlexA
    Alex
    Newport News, VA
    thanks for all of the help. I will take this knowledge and do further research and make a decision. I appreciate all of the help! i can feel a difference but im still on my first tank since the tire swap so i will wait and see if it adjusts enough or if i need a regear.
  14. May 25, 2010 at 5:52 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    Sounds like a plan man. Don't forget to come back and give us details on your experience.
  15. May 25, 2010 at 5:52 PM
    Jason'sLawnCare
    I misread the Toyota specs. Now that I look back there is a dash for that size meaning it's not available. Thanks for letting me know.
  16. May 25, 2010 at 8:03 PM
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    Yes! I have some if you are interested.
    PM sent.
  17. May 26, 2010 at 1:32 AM
    Kelson
    Kelson
    Honolulu, Hawaii
    if you want, you can read this. lol it explains why the manuals are a pita to regear. read Post #63
    http://www.customtacos.com/forum/showthread.php?t=116684
    haha np us 5 luggers are tacomas too! lol
  18. May 26, 2010 at 6:19 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    Thanks for the post but that doesn't make the job harder. Its like anything else you just have to have the correct parts. You have the same issues with certain chevy rears. Especially when you are jumping from a higher gearing to a much lower gearing (3.08 to a 4.10.) The Thickness changes as does the spacing. If you buy the wrong gear then it will certainly be a PITA same as your rear.
  19. Aug 29, 2010 at 5:31 PM
    Goatus
    Goatus Well-Known Member
    Dillon
    Asheville, NC
    2011 TRD Off-Road TX MGM
    Floor Liners, AFe Filter, Leer Cap, Bed Mat, Roof rack, Cap Rack, Rack Rack, Burt Bacharach
    Sorry to bring a dead thread to life but does anyone have information on how a 5-lugger with 235/75r15 tires performs in terms of power and MPG after re-gearing to 3.73?
  20. Aug 30, 2010 at 6:05 AM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    From what I've heard, when you put 235/75/15's on it corrects the speedo since the speedo normally reads 2-3 MPH low at 60 MPH. I've heard many people say that they did not need to regear at all. Most people said that after they put the new tires on, their speedo read about 1 MPH higher than their GPS was reading...and there shouldn't be any noticeable loss of power (except maybe on the highway).
