Re-gear, new problems
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tacobill20, Apr 27, 2022.
  1. Apr 27, 2022 at 4:07 PM
    Tacobill20
    Tacobill20 [OP] New Member
    Bill
    2020 tacoma 4x4 offroad
    285 tires, 3.5" lift, Lear bed cover, prinsu rack.
    Hey, I've got a 2020 Tacoma 4x4 Offroad. I've put a 3" lift with 285's. Last year I had the dealer download a upgrade software to help with sluggish response. I'm sure most have experienced this. It help a little and seamed to improve shifting. but not enough. I decided to get it re-geared and went with 4:88 upgrade. Thought this would help with millage as well as torque. It actually does stay in the upper gears on the hwy. BUT here's my problem... 1) gas mileage went down considerably. 2) when I'm going down steep hills it will down shift on its on. To the extent it will push my rpm's up above 4K. I have to go into manual and up shift to get to the right gear for the speed I'm doing. Is there a way to fix this?
    cryptolime likes this.
  2. Apr 27, 2022 at 5:38 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    It’s hard to propose any theories about your gas mileage without more information. Changing your diff gears could cause your fuel economy to go up, down, or stay the same.
    Your description of the transmission behavior doesn’t add up. I’ve never had an automatic transmission downshift while going downhill and maintaining my speed. I’ve also never observed s-mode forcing an up shift. S-mode simply limits the top gear the transmission will use and is designed for engine braking.
  3. Apr 27, 2022 at 5:41 PM
    roboturner
    roboturner Dead Eyed
    Colorado
    00 IJM AT XC 4x4 3.4L TRD | 18 CB MT DCSB 4x4 V6 Pro | 98 NW MT 4x4 3.4L SR5 4Runner
    KDMax time
    https://www.tacomaworld.com/threads/kdmax-pro-tune-by-paparee-and-twtaco.713699/
  4. Apr 27, 2022 at 5:49 PM
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    What were your expectations going into it?
  5. Apr 27, 2022 at 6:17 PM
    manwithtools
    manwithtools Well-Known Member
    Dan
    So Cal - San Diego
    2021 Cement Gray Off Road
    Fox 2.5's Deaver Stage 2. 5.29's, 285/70/R17 Front E-Locker
    Tacobill20[OP] likes this.
  6. Apr 27, 2022 at 7:12 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    The truck is designed and programmed for engine braking, which downshifting transmission happens. As for poor gas mileage, you went to 285's and 488's it going to take a big hit in gas mileage.
  7. Apr 27, 2022 at 9:08 PM
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    Go back to stock gears and get the ott tune
  8. Apr 27, 2022 at 9:21 PM
    RatDaddy
    RatDaddy Well-Known Member
    Roy
    2017 Tacoma TRD O/R Premium pkg
    None
    I would think your mileage went seriously down with the 33" tires you added. Just wondering, did you measure the actual mileage between truck changes?
  9. Apr 28, 2022 at 3:47 AM
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    Bigger tires = more rotational force needed to spin them.... gets worse the faster you go. More gas needed. This is physics.
    In all your gearing and tires, did you get your speedo adjusted? Usually the same input is used for calculation of mileage.
    My tires near doubled in weight from stock 32lbs to 63lbs..... mpgs dropped from 23ish to 17ish.
    shotgunbilly420 likes this.
  10. Apr 28, 2022 at 4:15 AM
    shotgunbilly420
    I'm running 64lbs a tire add my method wheels 25.4lbs comes to 89.4 lbs a corner.
