Re gear question I haven't seen asked
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Color_Me_Taco, Jul 31, 2022.
  1. Jul 31, 2022 at 2:27 PM
    Color_Me_Taco
    Color_Me_Taco [OP] Well-Known Member
    Doug
    Utah
    2022 TRD OffRoad, 2019 TRD OffRoad, 2021 Subaru STI, 2021 Kawasaki ZX6R
    ADD, Rigid, ToyTech, DBcustomz, Methods, Nittos, Powertank, Morimoto
    So, with 500 miles varying speed and RPM before a fluid flush...how are you breaking in the FRONT diff??
    Surely not going down a paved highway at 60mph? Best advise for the fronts?
    TIA
    Toki likes this.
  2. Jul 31, 2022 at 2:54 PM
    snakeplissken
    snakeplissken Call me Plissken
    I’m driving down dirt roads in 4 high on mine. You can drive on hard ball in 4 high on a straight road just don’t turn.
  3. Jul 31, 2022 at 2:56 PM
    Bishop84
    Bishop84 Well-Known Member
    The front diff spins regardless, just no load. It's actually actuating, so the spiders are actually always spinning. Use 4hi on straight lines on a gravel road.
    Chew and Color_Me_Taco[OP] like this.
  4. Aug 1, 2022 at 7:23 AM
    k20pham
    k20pham Well-Known Member
    KP
    2019 taco
    An email response from Paul at ECGS:
    You don't have to put exactly 500 miles on the front differential before you change the fluid. I would put it in 4wd a few times during the break-in and then change the fluid. Or you can change the fluid up front after several trips where 4wd was used quite a bit.
    I was also curious so I emailed them.
    Color_Me_Taco[OP] likes this.
  5. Aug 1, 2022 at 1:04 PM
    Blueberry.Taco
    Blueberry.Taco blueberry.taco (IG)
    Ryo
    Fulltime Overlanding
    Long travel house on 35s with a custom aluminum utility bed and FWC
    some welding required
    i just ran with the air locker locked up
    but i understand that isn't typically possible.
    just run 4hi on straighter roads.
    true statement but spinning the spiders isn't going to help the ring and pinion
