Re-gear Question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AgingDisgracefully, May 8, 2019.
  1. May 13, 2019 at 9:20 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    If I were you, I would go to 5.29s and pass on the front locker. A front locker will usually just pull you into situations you don't want to be in to begin with especially with limited armor and low round clearance.
    The 4.88s will work just fine as well but the 5.29s will give you a little more on the low end when you are weekend wheeling
  2. May 13, 2019 at 9:26 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    Second gen truck........I definitely pondered the 4.30's. When it came down to it the 4.30's didn't offer enough step up from the stock 3.73's when factoring in larger tires. (if I recall the stock ratio correctly). everyone I consulted was saying 4.56 or 4.88, and I am conservative by nature and was also considering the 4.30's. ECGS said 4.56 was right for my setup. Glad I went 4.56, it worked for me and my truck which I no longer have.
  3. May 13, 2019 at 9:28 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    After watching that video above on the 4.88's in the third gen, I would go 4.88 on stock tires without a doubt. 5.29 if 33's are in the plans for the future.
  4. May 13, 2019 at 9:49 AM
    AgingDisgracefully
    AgingDisgracefully [OP] Well-Known Member
    Peter
    2016 Tacoma SR5 V6 4X4
    I have armor. But yeah, both on this forum and the two mechanics I spoke to seem pretty skeptical of front lockers. Thanks.
  5. May 13, 2019 at 9:54 AM
    AgingDisgracefully
    Peter
    Man, I was hoping this would not turn into as tough a decision as the suspension....Maybe I should just go 4.88. I just wonder about 5.29s when I am probably not going to go for big tires.
    JimboAnz likes this.
  6. May 13, 2019 at 10:05 AM
    El Chivo Norteño
    El Chivo Norteño Well-Known Member
    Central Oregon
    2020 White DCLB 4X4 Off-Road
    If you have any inclination of sizing up on tires then 5.29 all the way. If not 4.88s will do you just fine for what you discribed in your OP :thumbsup:
  7. May 13, 2019 at 10:13 AM
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    What's the elevation where you live? That's something I like to take into account as well. As you go higher up, your engine produces less power and needs more gearing. I live at 5000ft and usually only go up from there on trips so I like to over gear when in between two choices.
  8. May 13, 2019 at 10:20 AM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Rather than a hidden winch maybe consider just a receiver mount. Then you can use a receiver cradle instead. Cantilevered weight has far more affect on sag and clearance than the same weight stowed between the axles and this allows recovery from either end as well. The reciever adds more flexiblity without as much effective weight.
  9. May 13, 2019 at 10:32 AM
    AgingDisgracefully
    Peter
    So, that's an interesting angle to this. I live in the Southern coastal plain flatlands (the Triangle of NC to be specific). But this truck is mainly for mountain adventures. It could go to 4,000 feet. Maybe even 5,000.
  10. May 13, 2019 at 10:34 AM
    AgingDisgracefully
    Peter
    So you are thinking maybe something like this?:
    https://mobtownoffroad.com/product/toyota-tacoma-front-recovery-bar/
  11. May 13, 2019 at 10:34 AM
    tcjacado
    tcjacado Well-Known Member
    See if there are any locals that have done the conversion and may let you take a test drive. Local threads.
  12. May 13, 2019 at 10:35 AM
    AgingDisgracefully
    Peter
    That's a good idea.
    JimboAnz and tcjacado[QUOTED] like this.
  13. May 13, 2019 at 10:50 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    tagged you over in the Raleigh thread :thumbsup:
    tcjacado likes this.
  14. May 13, 2019 at 11:23 AM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    First and foremost: Have you gotten stuck before on these back roads? What is your justification for NEEDING lockers? Why not add a winch now instead? Why not add winch + bigger tires first and re-gear + lockers later?
    I think you need to take a step back and truly evaluate your needs and explore other options before you go spending $3k++ adding gears and lockers front and rear.
    IFFFFFFFFFFFFF you did decide to go ahead with gears, I would not go more than 4.88's.
    Your truck is plenty capable in stock form, I would look for better recovery options at this time rather than lockers.
  15. May 13, 2019 at 12:23 PM
    #35
    AgingDisgracefully
    Peter
    There is not tradeoff between recovery and lockers for me: I can do both.
  16. May 13, 2019 at 12:23 PM
    #36
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
  17. May 13, 2019 at 1:01 PM
    #37
    Bubba503
    Bubba503 Well-Known Member
    PNW
    2022 Tacoma TRD ORP Lunar Rock
    A locker is the best thing you can buy for off roading. I can't tell you how many times my locker has helped me in tough situations on a trail, and also...i'd much rather be able to get through an obstacle without having to get out of my truck and winch every time. Also, Gears and a locker shouldnt cost 3k. Get a Yukon grizzly and call it good!
  18. May 13, 2019 at 1:22 PM
    #38
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    Your money. Do both then.
    Seems counterproductive to do all that work and spend so much money only to roll on 32's though.
  19. May 13, 2019 at 1:50 PM
    #39
    AgingDisgracefully
    Peter
    I am not really sure I follow where you are going with this. The tires I am on have done well for what I drive through. But I could still have traction issues, and still get stuck altogether, and in either case it could happen in a very remote area. And that's true no matter what size tires I am on.
  20. May 13, 2019 at 1:51 PM
    #40
    Chunk
    Chunk I smell Ice Cream!
    2016 DCSB OR
    Baby Ruth
    This... but I ain’t scared of 5.29 vs 4.88!
